All stitches removed, holes filled...
Now to fill in the chines.
OB15 Downunder
- AussieBoater
Re: OB15 Downunder
Paul - located at
31 degrees, 27.6 minutes South
152 degrees, 45.0 minutes East
- sitandfish
Re: OB15 Downunder
I suspect that you are taking an interesting and 'different' approach to joining the chine panels to the bottom panels? They are not butted together, are they?
- AussieBoater
Re: OB15 Downunder
No, they don't butt up on an OB15. The sides go past the bottom panels, they are then filled level to create the reverse chine effect...
Paul - located at
- sitandfish
Re: OB15 Downunder
Fascinating. I never noticed that before about the OB15, until now. Certainly makes the reverse chine easier to make. Looking really nice. And clean (lines).AussieBoater wrote:No, they don't butt up on an OB15. The sides go past the bottom panels, they are then filled level to create the reverse chine effect...
Re: OB15 Downunder
Sit&fish the OB15 is Jacques little trick on the reverse chine. It's a neat little design!
C17ccx, Mirror Dinghy
- AussieBoater
Re: OB15 Downunder
spent the day filling in the reverse chine...
it was raining and cool, so I needed some heat to get things moving
now just some sanding, round off the edges and I can tape the joints and apply the glass on the outside tomorrow...
Paul - located at
- AussieBoater
Re: OB15 Downunder
At last, the glassing is finished on the outside...
I have to say that taping the joints was easy enough and happened without incident. Laying the cloth was not so easy or enjoyable Having faired many a boat hull, I think I'd say laying the glass mat was and will be the most unenjoyable (new word) part of the build.
I had the photographer mixing for me, I only have admiration for any person who does this by themselves.
The best part??? It's done
Paul - located at
Re: OB15 Downunder
Beautifully done!
- AussieBoater
Re: OB15 Downunder
Thank you, I found the glassing to be a very stressful job...
I've ordered fairing compound (powder) and high build primer. So the next few weeks are bound to be fun.
Paul - located at
Users browsing this forum: Google [Bot], TommyD and 18 guests
