C19 New pics of console and foredeck
Re: C19 - flipped and have now added upper side panels
I like it!!!!! Now why didn't I think of that method of shaping the top panel????
You have one fine build going. She's going to be a beauty! John
- peter-curacao
Those upper panels did you customize them to a higher bow? looking great
Topwater - no problem flipping the hull, just made sure everything was well "spot welded" in place and I reinforced the bow where the bow eye was and just used 3 pulleys to slowly rotate it using the bow eye as the pivot and 2 transom eyes at the back. I didn't reinforce the sheer or anything. The hull does have "lifting strakes" so is quite stiff and held its shape well.topwater wrote:Tom the boat looks great Did you have any problem flipping the boat that way ?
I plan on flipping mine the same way this weekend. Was there much flexing or twisting
of the hull ?
I added about 3 inches to the original panels at the front end and tapered them to the original lines at about half way... I have now shaved quite a bit off though.peter-curacao wrote:Those upper panels did you customize them to a higher bow? looking great
I will see how it looks with the molds out and some floorboards in to get an idea of cockpit depth...
- peter-curacao
I like it I like it a lotTomD wrote:I added about 3 inches to the original panels at the front end and tapered them to the original lines at about half way... I have now shaved quite a bit off though.peter-curacao wrote:Those upper panels did you customize them to a higher bow? looking great
I gotta say, I really like the look of the hull before you added the top side panels...
Hummmm.... (wheels turning....)
Jerry
Jerry
Fishing from a paddle boat...
I was thinking the same thingI gotta say, I really like the look of the hull before you added the top side panels...
- gstanfield
I'm thinking it would make a great inshore boat without that top panel, never thought about that. I wonder what it ouwld save on the BOM to build without the extensions
Current build: FL14 (+10%)
- peter-curacao
Are you both pulling pork? those customized upper panels looks great! if you're both serious in the remarks you made I think you both lost taste in the progress sorry about thatCracker Larry wrote:I was thinking the same thingI gotta say, I really like the look of the hull before you added the top side panels...
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 12 guests
