Hey folks
Making some more progress on the P21. I got all the windows and deck hardware installed. Started some wiring and put the first coat of paint on the hull.
I also had the Boat Surveyed for insurance purposes. I was pleased with the results of the survey. The surveyor was very impressed with the boat design and construction. Everthing was ABYC compliant and done corectly so far.
However I was not real pleased with the dating of the hull. The year starts when the keel was laid witch was back in 2008. So I have a brand new 4 year old boat. The value was placed at 33K in its current state. Not bad considering I don’t have nearly that much into it.
Here are some more pics. The first coat of paint is pettit easypoxy that was roiled ant tipped. Came out good. we plan on at least 3 more coats.
*EDIT*.. I used S3 Yaught Primer. The hull was primed over a year ago and when it came time to prep for paint i could barely scratch it!. I tried a hand block and DA then a palm sander all with 80 grit. The palm worked the best but the sheets went flat in just a few moments. The primer is tough stuff once it fully cures!
