I promise I have searched the threads and read the tutorials before posting this very basic set of questions. Thanks in advance for you patience... I just want to make sure I get this step right before purchasing paints and trying to apply them...
First set of questions relates to graphite. I have heard two applications discussed for graphite / epoxy mix. One is to create a harder layer than epoxy without graphite. It sounds like people recommend doing 3 to 4 coats. And, the second reason I have heard, is in order to create less surface friction on the hull - both in the water as well as when beaching.
Q1: Should graphite be used in most applications discussed on this board? What would be the reason not to have several coats of epoxy/graphite?
It seems like the idea of a harder coating and less drag is a good thing in most boats....
Also, I believe I have read some people say that they
(A) Do epoxy/graphite on top of a primer coat
(B) Do epoxy/graphite under a primer coat
(C) Do epoxy/graphite as the only coat on the outside of their hull.
Q2: Are all options for the sequencing of primer and epoxy/graphite correct? What are the pros and cons of each?
Finally, as it pertains to Sterling. I am a bit unclear on the pros / cons of using the High Build Epoxy Primer versus using the Polyurethane primer.
Q3: Does one need to use either the High Build Primer -OR- the Polyurethane Primer? If so, what are best applications for each. Or... am I really missing the boat and are they used in concert together on a boat?
Thanks for your input and help!
Newbie Questions (OB19)
Track my adventure with my OB19 wooden boat plans here.
Re: Newbie Questions (OB19)
hi All.... any ideas on questions above? Thanks in advance! Rich
Q1. Yes, if you want the toughest bottom coating possible, no reason not to unless you don't like black. If not, see question 2
Q2. All 3 are valid methods. If you don't like black, you can prime and paint over the graphite. It will probably get ugly looking over time though.
Q3. I just use the S3 high build primer under Sterling, with very good results. Haven't tried any others.
Thanks Cracker Larry! Rich
agree 100% with above, I will only add to this question...
If you using sterling paint, the finish primer goes on very smooth and is the best way to get a yacht quality finish. That being said, you can get to a very high level of finish and gloss by using only the highbuild.Q3: Does one need to use either the High Build Primer -OR- the Polyurethane Primer? If so, what are best applications for each. Or... am I really missing the boat and are they used in concert together on a boat?
