NV23 Build
Posted: Tue Apr 03, 2012 8:59 am
by odwyerjb
Does anyone know the position of the stringers on the molds of the Novi 23. Or, where to cut the notches on the molds. I can't seem to find it on the plans.
Re: NV23 Build
Posted: Tue Apr 03, 2012 9:28 am
It's on the plans.
See drawing E239/5.
It shows the spacing of the stringers on frame B.
It is the same for all frames.
Re: NV23 Build
Posted: Thu Apr 05, 2012 9:12 pm
by Hope2float
Welcome Od
Topwater is building a NV23 he can probably help with some questions on that build. Good luck and enjoy the sanding
Dave
Re: NV23 Build
Posted: Mon Apr 09, 2012 6:11 pm
by odwyerjb
Thanks very much. I found the numbers for frame B. This is a great forum!
Re: NV23 Build
Posted: Tue Apr 10, 2012 8:17 am
by topwater
Dont forget to post pic's, at the rate i am moving at you will catch and pass me
Re: NV23 Build
Posted: Wed Aug 08, 2012 12:38 pm
by odwyerjb
Ok folks,
I am building and ready to share some pictures.
I understand I need to first put them in or on the gallery. but don't know how.
Re: NV23 Build
Posted: Wed Aug 08, 2012 3:18 pm
by Mad Dog
odwyerjb wrote:Ok folks,
You can also use a host like Photobucket to link in the pics. That was easier for me and allowed me to share images on other forums and such.
MD
Re: NV23 Build
Posted: Sun Aug 12, 2012 12:59 pm
by odwyerjb
Thanks Mad Dog. Lets see if I can get this thread going and do something useful.
First picture:
This is how It started on April 2nd 2012. I needed a place to build and didn't have a shop big enough. So I have to build outdoors. This is my back yard with my shed to the right. The trees to the left are just about 16 feet from the shed so there should be just enough room for the flip. You can see the sprinkler head whidh I moved so it wouldn't spray the boat each day.
This is the strongback made from 2 x 10's and on 4 inch posts.
The yard has a bit of a grade, which you can see here in this picture.
The strongback is 3 ft wide. I have seen this question asked in some other threads.
I have more pics posted on an album., but it is time to work on the boat!
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:12 am
by odwyerjb
Still having trouble posting some pictures from the gallery, so this is a test.
First station installed on the strongback
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:15 am
by odwyerjb
Ok, but the picture is small. Secondtest
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:20 am
by odwyerjb
Note that the wood is exterior AC, I am going the route of potentially disposable stations. Will deide if this is good as work progresses. Here is the middle station again. Note the use of scrap wood. Not pretty, but it works.
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:30 am
by odwyerjb
Gluing up the ransom. First use of Meranti on the boat. Nice stuff. pretty where the resin shows the grain. Too bad it will be painted.
Here is the glueup of the outside stringers. The clamps are scraps screwed to the shops wooden floor.
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:38 am
by odwyerjb
Re: NV23 Build
Posted: Tue Oct 09, 2012 10:45 am
by odwyerjb
here is a pic of one of the center stringers. Wasn't happy with how the notches lined up so I recut them. Didn't get a picture of the glueup on these, but they extended past the shop floor.
Re: NV23 Build
Posted: Tue Oct 09, 2012 12:23 pm
by Uncle D
Looks like my shop but cleaner.
Nice work..build-on
