My plywood came in today and I got to measuring quickly after work. I cut the stern panel of the sides with a fine tooth blade on a 7 1/4" circular saw and found out quickly the blade was dull. I'm not very happy with the cuts but I have no doubt I'll be able to remedy that issue when I start putting everything else together. I then switched to a different blade and the cuts were much better.
My rub rails, spray rails, runners, and cleats all ripped to the correct width. I used 1" x 4"s and 1" x 6"s of Southern Yella Pine and ripped them to the specified widths for each piece.
I'm using Meranti BS6566 and got 4 sheets of 1/4" and 3 sheets of 1/2".
My bow floor all measured out and ready to cut.
My side panels stacked, measured, marked and ready to cut.
This is when I cut the bow side panels. I fine toothed blade was dull so it made cutting hard and I got some pretty crooked and nasty cuts. I figure that with all the extra epoxy and whatnot I ordered, I'll be able to fill it in to the point it's 100% structurally sound and when it's all done, no one will know but me (and you...) about the crappy cuts. I switched over to another sharper blade for the rest of the cuts. I'm not impressed with using the bigger saw and will try to get a smaller one for the rest of the cuts even though I'm pretty much done with most of the curved cuts.
I got my side and bottom panels all lined up with the butt blocks ready for glue.
I have the butt blocks glued and weighted and am looking forward to see how they turn out.
Crooked cuts on the stern side panels.
I found this bad boy floating out in front of our island this afternoon! It's a 110 acre undeveloped barrier island so we get anything and EVERYTHING washing up on our beach. I've found a few plugs, good 5 gal buckets, 1 pair of matching flip flops a couple months apart, message in a bottle, hypodermic needles, etc.
I'm already looking forward to tomorrow afternoon and getting back at it!
