We will clean up the tutorial when we are finished.shine wrote: I was experimenting on ways to keep frames/stringers square, ended up not using any clamps. Well, I guess I did use the 4 tiny C clamps at the transom
In the end, after some testing, Joel did not use any clamps between the frames.
Once finished, we will weigh the SUP and we are almost certain that we will use 1/4" framing instead of 1/8.
It will only weigh a few more ounces if I cut enough lightening holes but will be much stiffer.
