Sorry, I am still learning how to post pictures.
Once again here is the Sole with cross braces:
(anflyer) OD16 Started Today........
Today I began the installation of the Chase Tubes.
Yellow Dot:
3" Chase Tube (Starboard Side) for the Throttle & Steering Cables. I tried using the 3" electrical sweeps but could not get them to fit within the chine. I hope the way they are installed it will not give me any problems. If somebody has them installed in this manner and you have not experienced any problems PLEASE let me know so I can sleep better at night.
Blue & Red Dots:
Possible Fuel Chase Tubes - the plan is to install the fuel tank under the casting deck or possibly have a triangle shaped tank to fit in the location of the anchor locker (still undecided)
Blue Line:
another 3" chase tube for any other cables. (I already have the the materials so might as well have another tube just in case)
Green Line:
1 1/2" livewell return ( the livewell will be under the console seat)
Red Line:
3/4" Livewell water feed
??Should the livewell feed and return be more towards the transome or towards the bulkhead??
Yellow Line:
Bow Light Chase Tube
Sorry for the long post, just wanted to post an update and I am always looking for constructive advice.
Anflyer
Yellow Dot:
Blue & Red Dots:
Blue Line:
Green Line:
Red Line:
Yellow Line:
Anflyer
Anyflyer,
I had the same problem with the electrical sweeps being too close to the chines and thus didn't use that. Now, EvilD. did manage to use them I believe - so, I guess you can get it to work in some fashion.
My chase tubing looks pretty much the same as yours. You did a really nice and clean job though
Btw, I see you have your fuel lines coming out in the same drywell as your control harness chase tubing. Remember, that you might have to put electrical stuff through that same chase tube. If you do, it would share the area with the fuel lines. Question is whether you are confident enough that no gas fumes from fuel lines will collect in an area where you have electrical wiring. Don't know if that's really a good idea. Just keep that in mind when you do the final rigging.
