EvilD & DrBones, thanks for the replies.
I am installing a second 3" rigging tube (already have the 3" material) on the PORT side which will carry the electrical from the console area. The Starboard side chase tube will be carrying the Throttle & Steering cables.
Where are you guys planning on installing the battery?
Do you think a 1 1/2" livewell discharg is enough?? and should the exit be more towards the transom or bulkhead??
Thanks,
(anflyer) OD16 Started Today........
anflyer,
I can't see the pics either. I noticed that your image open tags and image close tags are in the wrong place. If you go back and edit your first message placing the [img]tag%20at%20the%20beginning%20of%20the%20URL%20and%20the[/img] at the end of the url, it should work, unless you're over your host's access limit.
-Dave
-Dave
Modified GV13- Mad Russian
I can't see the pics.
I have a livwell installed in front of my console feed by 3/4 water feed that is mounted on the transom and a 1.5" outlet that's dumped thru the transom. It works fine.
Where the outlet line goes is pretty much up to you side would be easier to install but clutters the side view of the boat. No matter where you put it keep it close to the water line to reduce noise while fishing.
I finally resolved the picture issue, by using a new image server. I also made some changes with the layout according to some of the recomendations.
The fuel chase tube (red dot) is now moved over to the port side so I will have a chase tube for the fuel line on both side of the boat which will enable me to place this away from the electrical.
Gpratt I porbably will do the same and route the livewell outlet & feed through the transom. (do you have pics of your livewell setup??)
Were has everybody mounted the battery??
Tonight I will finish and send some of the updated pics.
Anflyer
Anflyer
- TimeWalker
Your baitwell overflow should be 2 times as large as your, largest inflow IE: if your largest inflow is 3/4" then your outflow needs to be 1.5 if your largest inflow is 1" then 2" should be your MINIMUM outflow
It is never a bad idea to go a size larger then double never the same or less it COULD cause overflow and sinking
- TimeWalker
- Andrec4016
- New Poster
