FS14 OZ
Re: FS14 OZ
a bit more done, jig is done
bottom hull is on, edges bevelled and nice fit, ready to tac the seam together tomorrow morning
the transom is sitting about 10mm inside the hull panels, i cant move the hull panels any further forward because of the butt blocks joining the panels and the seat frame, not sure yet if i should trim the back of hull panels flush with the transom or if i should move the seat frames forward.
all in all though im happy with the fit and how it looks, might have to reshape the stringers at the bow end to fit but no biggie.
i will get the side hull panels on tomorrow and make sure everything looks good before things get permenately glued.
all my electronics have turned up for the steering and throttle, ive started programming the micro controller but it is still a work-in-progress considering i have to get the hardware working before i can start testing. looking at changing the gearing of the llinear actuator to moke the steering more responsive.
Re: FS14 OZ
Hull is together, probably put too many stitches in, but everything came together nicely and with fair lines
spent today filling the stitch holes and making the joints smooth with the plane and epoxy.
tomorrow i will be finish of smoothing the hull and filling low points and holes in the joints. with the heat at the moment i should be able to give the whole hull a light sand in the evening read to precoat the hull with epoxy ready for fibreglassing.
Re: FS14 OZ
Looks real good
Based on other pics, you've used just the right number of stiches
Re: FS14 OZ
hi just an update.
seams glassed and sanded ready for glass
the outside of the hull is glassed
putting on the rub rail and will be fairing soon hopefully.
also got quote and advise on paint and might be going with dulux high build epoxy primer and dulux 2pack polyurethane topcote. if anybody has used dulux i would like to hear how you got on with it. it is a bt cheaper but apparently norglass paints are made by them... its meant to be good to brush.which is also a plus.
Re: FS14 OZ
forgot to show where im upto with the electronics.
ive programmed the servos that control the gearbox and throttle which are awesome, and the LEDs just need calibrating to show the throttle position(not sure if i will use them yet because they dont glow through the touch sensitive potentiometer).
upto getting the gps and engine water temp guage(cylinder head temp would probably be better with the 2stroke) talking to the LCD screen.
Re: FS14 OZ
Your boat is looking great. Glad it is coming along. You computer thingy looks... I don't have a clue what anyof that stuff is! Good luck with getting it all wired and stuff...!
Mike
Matthew 4:19
Matthew 4:19
Re: FS14 OZ
Looks great!
Re: FS14 OZ
I love innovation!
Re: FS14 OZ
Beautiful 'glass work
