Interesting, I've never glued cloth upside down (nor down under...) so interested to see how it goes.
Did you consider a keel guard or keel shield type protection ?
BarraMan's Mangusta 21 barraboat in Townsville, AUS
Re: BarraMan's Mangusta 21 barraboat in Townsville, AUS
Building C17: app.php/gallery/album/262
Built canoe, GF14, Devlin Bella 16.
Sails a 30ft Wrighton Biloup sailboat.
- BarraMan
Its awkward, but doable! I used an engine crane to lift the front of the boat so that I could get to the affected area.
Now I am on to graphite, high-build priming, and painting!
I had a Keel Guard on the boat when first built. At that time the boat was on a bunk trailer so the keel was not resting on anything. Unfortunately, one fishing trip to the remote north of Australia destroyed the torsion bar suspension on that trailer, so I had a new custom built trailer made with roller-rocker spring suspension. The builder convinced me to go with roller support for the boat. As that meant to Keel Guard would be sitting on a roller ladder, I removed it as they say not to use Keel Guard with rollers.
I now intend to fit Keel Guard to the boat again, but only run it to just before the keel touches to first roller - which should protect the vulnerable area. Where we fish mostly has a sand or mud bottom, so I think the damage occurred at the dam where we ski at Xmas time, which has a stony bottom. I will be more conscious of that in future. We'll see how it goes, in the meantime I am happy to have an additional 6x layers of glass between the external hull and the wood core.
3x coats of graphite/epoxy 1/3:2/3 by volume!
Lee how many layers of glass did the hull have where it was worn through?
I'd rethink that keel guard idea. The FAQ for Keelshield says that if there's weight bearing rollers, even if just when loading or unloading that it can become an issue.
I glued an aluminium strip to mine. Just a bunnings 2mm by 30mm profile. Glued with gflex. On the sides I have UHMWPE flame treated then also glued with gflex. Both of which should be a lot more resistant to rollers than a Keelshield, at a fraction of the cost.
- BarraMan
9 x layers of 12oz biax
4 x coats of graphite/epoxy
4 x coats of epoxy primer (sanded back somewhat)
2 x coats of 2 pack polyurethane under coat
2 x coats of 2 pack polyurethane top coat
The rubs are only 2 areas each about 2” long - so my repairs are probably overkill!
95% of the ‘at risk’ area now has 15 x layers of 12oz biax to get thru before the wood core is exposed!
- BarraMan
I already have the Keel Guard so I’ll give it a go. If it doesn’t work out I’ll run an aluminium strip when I have the boat out on hard stand!OneWayTraffic wrote: ↑Sat Aug 19, 2023 6:53 am I'd rethink that keel guard idea. The FAQ for Keelshield says that if there's weight bearing rollers, even if just when loading or unloading that it can become an issue.
What about getting rid of the front rollers and making some glide bunks..you know where to put them!BarraMan wrote: ↑Sat Aug 19, 2023 8:49 amI already have the Keel Guard so I’ll give it a go. If it doesn’t work out I’ll run an aluminium strip when I have the boat out on hard stand!OneWayTraffic wrote: ↑Sat Aug 19, 2023 6:53 am I'd rethink that keel guard idea. The FAQ for Keelshield says that if there's weight bearing rollers, even if just when loading or unloading that it can become an issue.
I glued an aluminium strip to mine. Just a bunnings 2mm by 30mm profile. Glued with gflex. On the sides I have UHMWPE flame treated then also glued with gflex. Both of which should be a lot more resistant to rollers than a Keelshield, at a fraction of the cost.![]()
Seems like a lot of glass to rub through. Are you sure you have not been "rubbing" on some rocks at 30 knots or so
- BarraMan
Well, I have had two big “hits” with the boat on unknown rocks/pinnacles in the middle of nowhere, but they were taken by the skeg not the hull!
I guess I should have taken pics of the rubs, but they were only 2x spots about 2” long each, separated by 1x foot or so.
I have run aground unexpectedly many times but only on sand or mud!
My only explanation for the rubs is that they have happened over a number of years during our annual Xmas holidays when we spend a week or so waterskiing at a dam where the shoreline is stoney where I park the boat when launching and retrieving - no pontoon!
Some other rub areas down to the graphite only, but like you, I am surprised at the rubs through 9 layers of glass!
My experience too, glass is not so resistant to rubbing. Waves impact, torsional forces yes, but for rubbing kevlar cloth will likely be more efficient.
