It does, you just tape the center seam of the top and then remove it to take care of the inside.Vanagod wrote:Does this boat not have taped seams on the inside of the hull?
I think this calls for flipping because the kayak parts completely enclose the frames and mold, I'm not sure how well that would work with a canoe.I should have read your build over as I have been progressing on mine, I may have saved some effort. I think I would have been well served flipping my canoe after initial stitching and tack-welding. There is alot of shaping sanding I will have to do now instead where boards did not line up exactly where I wanted them to.
I want to get a heat lamp or something to get the epoxy up to ~80 degrees for the big layups. I can deal with a few extra ounces for taping but doing the broadcloth can suck up some epoxy if I can't get it to flow well.I also have a colder work area. Typically my garage is about 40*F in the morning. What I will do is keep the epoxy jugs indoors so they stay warm and fluid and then light up the propane heater to bring the shop up to 55 or so. (I am using fast hardener.) Once I am ready for stuff to cure, I move the heater closer to the boat and let the garage warm up and things seem to cure up in 24 hours. Of course today, I let the garage get up to 70+, and that fast epoxy lit off twice before I was ready for it to. Good reason to keep the batches small.
I was shooting for last May. This May would be nice.Please keep up the posts. By when do you think you will have her splashed?
