PY12 Build - NC
Posted: Tue Jan 08, 2013 12:48 pm
Hi,
I'm building this as a test of my boat building skills before I start on a 19-20' center console hopefully later this year. Or a 2-seater kayak if my wife decides to steal this one..
I got my fiberglass and epoxy kit in yesterday and will be picking up the wood in a few days so am ready to get started. I want to outfit this as a fishing kayak so will gladly take any advice on rigging. I want to get this finished up in a month or three so I can take it out this spring.
I've got a few questions:
Is cypress a good wood for the cleats? I've got a lot of that laying around, it's light and rot resistant so I figure its a good wood.
I'm thinking of using a pair of these for the drains and having a channel between them behind the seat to drain the water as needed instead of the open holes in the side. I assume the plug is on the outside with these?
http://www.basspro.com/Replacement-Kaya ... /10225363/
For the stitches, I have some bulk twist tie material that's used for tying up tomatoes, I figure it should work on this little boat but may not be strong enough for a larger one. Anything wrong with that thinking?
I've seen some partially finished threads of the PY12 but nothing completely rigged out, did I miss someone's build?
I'll post some pictures once I get started.
Thanks,
Steve
Thanks,
Steve
