A quick update:
OK, so I've glassed the hull on the outside. I started around 10am in the morning and only finished around 8pm. My right arm went into cramps a few times(Squeegee)
, but a Bells sorted that out after 8
. She is huge to do on your own. This was the layup of the first layer.
After my jigsaw deserted, I had 2 more desertions(old tools giving up. I'll have them repaired for little carpentry jobs.). I went out and bought 2 Bosch pro orbital sanders. The 150mm and 125mm for smaller spots. My shop vac arrived as well and it makes a huge difference having the vac on the sanders. My word, they work great. They 150 brute comes with a hard box. Very nice.
Anyway - I was very busy laminating that some areas were already gelling and hardening. By the time I reached them with the peelply, it was too late.
. I managed to get some peel ply down on the layup. The rest I cleaned off with a quick sand for the second layer of biax.
The second layer of biax cloth went on the bottom without event. Its easier to place since youre nor working on a vertical plane. I found that rolling on the resin and then using a squeegee to work it through gave me the best results.
I had a discussion with my fibre supplier about using a 280g carbon fibre from the keel to the chine (whole bottom) as a final layer instead of fairing that part. Firstly, its expensive and then the strakes is an issue as well. What he did suggest is that I use a 300g woven as a final over the whole boat. It will add around 10 to 12 extra kilogram, but the benefits would be a better abrasion resistance in woven than biax. Apparently it is possible, when the outside layer is penetrated, that a single fibre in the biax can be lifted and cause a peel-off. Made sense. The second reason was that it provides a bit of sacrificial layer during the fairing process. If you sand into the glass, you should not get down to the biax. So, I layed another 300g over the whole boat...except the transom. I had enough time to peelply this layer and was happy with the results.
I did a bit of cleaning off before I started with the fairing: First the left hand side. This is taking quite some time, but the results are looking good.
I started with run 1 on the right hand side:
Ok, so it is still a lot of fairing to get the flair smooth and the rest to my liking. I have a small recess where I joined to long panels on the bend towards the bow. If I fill it with fairing compound the layer would be around 3 to 5mm thick. Is this acceptable?
BTW - The hardener of the fairing compound smells like someone peed in it. Is this right?
Ammonia, I suppose.
Cheers, Antonie
