GV10 - Fast Garvey 10 - Waiting to fish in Salt Lake
Posted: Mon May 27, 2013 11:05 pm
This is my first build. I really like the support from Bateau given the forums and resources provided to the builder. This ultimately led to my decision to buy the plans from this site.
I needed a boat that I could car top. Our family vehicle is a GMC Yukon XL so we have a little extra room on top. The S.O. wants a pop-up camper soon, so I needed an alternative way to transport the boat given the fact that the hitch will be taken. Another factor is weight - hence the GV10 and not the GV11 and budget is somewhat of a concern as well.
Fortunately, Salt lake has a local macbeath's hardwood retail outlet. I called them first and figured it would cost $200 in plywood using aquatek 6566. I spent 3 weeks trying to find a cheaper source of acceptable alternatives with no luck. Actually their current prices for 1/4" at 43.00 are comparable to ultraply XL, which I cant find in salt lake anyway. There really isn't much savings using that stuff compared to the quality difference with true marine grade ply. I'm not saying quality boats cant be built out of ultraply (heh I read those posts too) - just that at 30 - 40 bucks a sheet anyway, why not use aquatek? - Provided you have a local source of course.
While looking at the nesting for the plywood cuts I did notice that sheet four is mostly structural. I.e. the transom, thwarts and frames are cut from the 3/8" ply and the hull and bow transom are cut from the 1/4". I decided to use 3/8" AC doug-fir for this sheet and use the 1/4" aquatek sourced from macbeath's for the hull. That saved me about 50 bucks. We'll see if I regret this decision later on.
So week 1: Made the cuts in the plywood leaving frame 3 for later. It just seemed I didn't need it to form the hull and I could check measurements before cutting when needed. The aquatek meranti I have is pretty good stuff. I read the blog on bateau about the quality of their aquatek being hit or miss. This one has good, clear faces, 5 plys and absolutely no voids. The only issue seems to be this stuff likes to check a little on cross cuts. All the seams will be taped and filleted anyway. I don't see this as a problem just yet.
Here's a pic of the stamp that came on the aquatek:
This is washed out a little. The stamp says "Marine Ply. Dragon. Aquatek 6566"
Here's all the cuts laid out:
After the first couple of days of back ache I decided I needed saw horses. I built some knockdown ones for about 18 bucks worth of 1x4 furring strip from the local box store and some decking screws I had on hand. Here's all the pieces up off the floor and laid out on the saw horses:
Total time of actual build thus far is about 15 hours.
Planning and research is about 4 weeks. Haha.
Up next: gluing the frames and the hull together. I'm waiting on 6 oz woven fiberglass tape coming by mail.
