GF16 Inside Complete
Thanks for the kind words and looking with one eye closed.
As they say in the South, That there is Aerospace grade Polyeurothane.
I work in Aerospace and we can only keep paint for a year. So there just happened to be 3 gallons of Epoxy primer and three gallons of white gloss polyeurothane that went out of date. No cooincidence either. Why pay the EPA to haul it away when I could use it on the boat. It is sold by Lord Corporation, it is called Aeroglaze. We use it on stuff that mounts to wings so I assumed it was good enough as long as I don't leave the boat in the water to long.
I rolled the first coat of primer with a foam brush to get thick coverage. Then I sanded with 100 grit and sprayed the second coat of primer. I sanded that with 180 then shot the first coat of paint. I sanded that with 220 then shot the second coat of paint. Two coats of paint, two coats of primer. I have an old Binks2000 spray gun that worked real well.
I spent a lot of time fairing the inside before I did anything. I used almost 3 gallons of Dry Fairing Mix on the inside and bottom.
Users browsing this forum: Ahrefs [Bot], Google [Bot], Yandex [Bot] and 20 guests
