Tip & Roll dry time
Posted: Wed Jun 26, 2013 10:23 am
by Boater45
I'm starting to paint tonight and want to know if anyone can tell me the recommended times between coats and how long it should cure before splashing?
Re: Tip & Roll dry time
Posted: Wed Jun 26, 2013 10:27 am
by tech_support
what brand?.... it depends on the paint.
It will either say it on the can, or in the case of the "professional" products, in the paint literature/application guide.
Posted: Wed Jun 26, 2013 10:29 am
by Cracker Larry
I'd go about 12 hours between coats, assuming warm weather, longer in cool weather, and probably 5 days cure before splashing.
Edit: since this was under the Sterling thread, I assumed Sterling paint
Posted: Wed Jun 26, 2013 11:04 am
by tech_support
did not see what section it was in.
You can get two coats in one day if its warm, and that is without using the accelerator.
Depending on temps, the application guide says that you have up to 36 hours to re-coat without sanding.
Posted: Wed Jun 26, 2013 11:13 am
by Boater45
It is Sterling! Temps here will be in the 90 degree range.
Posted: Wed Jun 26, 2013 11:20 am
by Boater45
I understand that Sterling is a 2-1 mixture of the paint(U-220) to U-2964 brushing converter and you can thin that out as much as 25% with the U-2965 brushing reducer.
How much accelerator should be added to a 12 oz batch? Will this help with the curing time?
Posted: Wed Jun 26, 2013 11:41 am
by tech_support
thats right, and if its hot, you will probably want to add a tiny amount of reducer as you go (the paint will thicken)
Application guide says anywhere from a few drops to 1/8 oz for a whole quart, it depends greatly on the temp and the humidity. My advice it to not use the accelerator this time of year unless your really trying to make it tack free quickly. Paint in the morning or when humidity is lowest
Posted: Wed Jun 26, 2013 12:31 pm
by Boater45
Where can I get the application guide? And am I correct to think that the induction time is 30 minutes after mixing?
Posted: Wed Jun 26, 2013 2:31 pm
by tech_support
we have a whole stack of them and we can mail one to you.
Please email your name/address to
orderdesk@e-boat.net - say you need a sterling application guide mailed to you
Posted: Wed Jun 26, 2013 7:31 pm
by Boater45
Email sent!! Thanks!!
