Tip & Roll dry time
sterling L.P. topcoats and primers
Boater45
Tip & Roll dry time
Post by Boater45 »
I'm starting to paint tonight and want to know if anyone can tell me the recommended times between coats and how long it should cure before splashing?
viewtopic.php?f=12&t=19337
OB17 - Will White, Broken Arrow, OK
tech_support
Re: Tip & Roll dry time
Post by tech_support »
what brand?.... it depends on the paint.
It will either say it on the can, or in the case of the "professional" products, in the paint literature/application guide.
Cracker Larry
Post by Cracker Larry »
I'd go about 12 hours between coats, assuming warm weather, longer in cool weather, and probably 5 days cure before splashing.
Edit: since this was under the Sterling thread, I assumed Sterling paint :?
tech_support
:oops: did not see what section it was in.
You can get two coats in one day if its warm, and that is without using the accelerator.
Depending on temps, the application guide says that you have up to 36 hours to re-coat without sanding.
Boater45
Post by Boater45 »
It is Sterling! Temps here will be in the 90 degree range.
Boater45
Post by Boater45 »
I understand that Sterling is a 2-1 mixture of the paint(U-220) to U-2964 brushing converter and you can thin that out as much as 25% with the U-2965 brushing reducer.
How much accelerator should be added to a 12 oz batch? Will this help with the curing time?
tech_support
thats right, and if its hot, you will probably want to add a tiny amount of reducer as you go (the paint will thicken)
Application guide says anywhere from a few drops to 1/8 oz for a whole quart, it depends greatly on the temp and the humidity. My advice it to not use the accelerator this time of year unless your really trying to make it tack free quickly. Paint in the morning or when humidity is lowest
Boater45
Post by Boater45 »
Where can I get the application guide? And am I correct to think that the induction time is 30 minutes after mixing?
tech_support
we have a whole stack of them and we can mail one to you.
Please email your name/address to orderdesk@e-boat.net - say you need a sterling application guide mailed to you :wink:
Boater45
Post by Boater45 »
Email sent!! Thanks!!
