Nice-looking stand. I would cover it with a tarp or some kind of sheet of plastic or like that quarter inch melamine I was talking about earlier to keep the epoxy from sticking to it because you're going to get a lot of epoxy on it over the build. And as for gilding the Lily, if you reinforce the legs a little bit you might be able to put casters on them and roll the boat around the garage to make accessing various corners easier too.
How long is your garage? It looks like your stand is almost as long as the garage itself like you have just a few feet behind the back of the stand and you'll have to have the garage door open in order to work on the boat. Please keep posting pictures this project. I'll be watching it. I'm thinking about making a GF 16 for my next build (or an FS 17 or a GF 18 or a CK 17; who knows, too many good plans to choose from.... Now how big is my garage? )
GF16 In The PSL
Re: GF16 In The Pizzle
-Aaron
"A-Ron the relentless"
Soli Deo Gloria
Semper Reformanda
Soli Deo Gloria
Semper Reformanda
The garage is 20x20 and the frame is 16x4. I may need to move the compressor, table saw and welder off of the back wall but maybe not.
I will probably cover it with visqueen when the epoxy starts flying. A tarp is a good idea, I have some left over from the twin hurricanes we had in 04 that were covering our blown off roof.
I thought about casters still kind of up in the air on them. $$$ is adding up quick.
I hear ya on all the different possibilities here. I actually had a set of FS18 plans and a partial FG and plywood kit. I bought it from a guy on Microskiff. I ended up selling it because I wanted to start with something easier first, I didn't want to build it outside and SWMBO refuses to park her ride outside . I would need the whole garage to build an 18 footer...
Gary
GF-16 Completed
GF-16 Completed
I'm using scrap tarp material on my work bench and other places. Cured epoxy comes off of tarp pretty easily.
-Aaron
Soli Deo Gloria
Semper Reformanda
Soli Deo Gloria
Semper Reformanda
I'm in the process of laying everything out. Do you cut out each frame then lay out the next or lay it all out and cut it at one time? I guess I'm really asking is if the width of the saw blade requires you to lay out and cut each panel individually? I ask because some of the seat frames touch each other on the nesting diagram.
Thanks
Thanks
Gary
GF-16 Completed
GF-16 Completed
Re: GF16 In The PSL
Definitely add some casters...and get 3" or bigger. You're going to want to roll that thing outside for sanding, cutting, sanding, sanding, getting it out of the way, sanding, sanding, and sanding.
Re: GF16 In The PSL
I'm local, give a shout if you need a second set of hands during your build.
- Walkers Run
Re: GF16 In The PSL
X2Matt Gent wrote:I'm local, give a shout if you need a second set of hands during your build.
Re: GF16 In The PSL
Thanks for the offer Matt and Walker. I may very well take you up on that.
Gary
GF-16 Completed
GF-16 Completed
Re: GF16 In The PSL
Nothing really exiting to report. I have most everything laid out. I hope to finish that and get everything cut tomorrow.
Feels good to finally be started.
Gary
GF-16 Completed
GF-16 Completed
Users browsing this forum: Amazon [Bot] and 9 guests
