Thanks Antonie,antoniekruger wrote:Hi Biscuit - that's looking good. Good momentum.
And its good to see you have hand planes. They do come in handy.
She's a big boat - according to Larry, sanding is therapeutic.....not so sure about that. Are you intending to use quickfair?
Just one note - if you do replace a tool(power or not) replace it with the best you can afford.
Are you using Acetone to clean your brushes? My composite supplier sold me a water soluble brush cleaner. Very cool stuff. I'll post a pic of the container. I was even able to revive those brushes that has gone a bit hard at the top....
Cheers,
Antonie
I'm in a bit of a hurry to get the hull on the forms and spot welded together. I have a really crazy work schedule and once I go back the momentum will definitely drop off some. Mostly though the excitement is keeping me going.
I think Cracker Larry is most knowledgeable about building these boats but I don't know how therapeutic sanding this monster will be. There's always the possibility that the Biscuit and the Cracker have two different understandings of the word therapeutic.
I'll probably use the micro-balloon/ glass mixture provided with my epoxy kit first. Then move to the quickfair. Honestly though the micro-balloons in epoxy do a great job by theirself so I'll keep you updated on that.
I've been using vinegar and sometimes acetone. I've never tried anything else. The acetone works best if you have something that's started to harden over but if you're cleaning up epoxy that's not kicked yet, then vinegar is the best value, does an amazing job and well, here we can pick up a gallon at almost any grocery for next to nothing. The vinegar is essential to remove any epoxy mixed or in parts that may contact your skin. The vinegar doesn't absorb into your skin the way acetone does, thus the harmful epoxy chemistry stays out of you.
Bottoms not ready to be rolled over yet.
Jeff
