Page 1 of 2
some coloring inconsistencies
Posted: Thu May 15, 2014 9:45 am
by DB Michel
Hello,
I have applied a second coat of Sterling top coat today but I still have some coloring inconsistencies, every where where I applied new paint with the roller there is a difference in color then the previous spot I painted.
Does anyone knows how I can prevent this ?
I tried to take a picture but you don't see it, to much reflection.
Re: some coloring inconsistencies
Posted: Thu May 15, 2014 11:03 am
Do you mean difference between two paint cans or from the same?
Posted: Thu May 15, 2014 12:57 pm
by DB Michel
From the same can, but the difference in color is where I start with the roller . so every time I load the roller I put some new paint (2inch) on the previous paint that is brushed and after brushing the new load it remains different at the starting point.
I hope you understand , it's a bit difficult explaining .
Posted: Thu May 15, 2014 1:18 pm
Sterling takes several days to fully cure. The colors will probably even out over time.
Posted: Thu May 15, 2014 1:33 pm
by DB Michel
Mmmmm probably keeps me a wake ,Larry
Let's hope you are right.
will give it a light sand and apply a 3 coat .
Posted: Thu May 15, 2014 2:35 pm
by pee wee
I haven't used Sterling, but based on my other painting experiences I'd think it is flashing off too quickly- is there an additive recommended that would give more working time?
Different animal, but with lacquers you sometimes need to go to a slower evaporating thinner to get the right finish.
Posted: Thu May 15, 2014 4:19 pm
by DB Michel
I 've used the sterling brushing reducer and thinned it 35% ,maybe for the next coat I thinned it some more .
Posted: Thu May 15, 2014 5:10 pm
by pee wee
DB Michel wrote:I 've used the sterling brushing reducer and thinned it 35% ,maybe for the next coat I thinned it some more .
I see the manufacturer says reduce 10% to 33% (another souce said up to 35%) for brush/roll application, don't think I'd try more reducer . . . is the weather there hot? Very dry? They say it works best between 21 and 29 degrees. I don't see an Awlgrip retarder offered for roll/brush application, the T0031 should be slow enough. Working by yourself not to roll more than 6 sq. feet(~1/2 sq. meter) before tipping with brush . . .
Posted: Thu May 15, 2014 5:57 pm
by Aripeka Angler
I have painted Sterling on 3 different boats.
Especially if you are using a color other than white, you may be seeing the primer on the first coat.
Be patient, it will be evenly colored by the third or fourth coat
Posted: Thu May 15, 2014 8:23 pm
Yes, that maybe it.
It takes many coats to have a deep constant color. Nothing wrong, it doesn't take much paint per coat. I remember Joel painting the FS12 prototype with it and it took 4 coats before the color became uniform.
4 coats but less than a quart of paint total.
