PNW CX 25 scaled up
Re: PNW CX 25
Purchased some OSB to do a test transom. First one is port side transom edge, second is top of transom - at 9% scaling it's a go.
Re: PNW CX 25
4 sheets of aquaplas III, seams to flimsy to support a couple of motors on a bracket.
Re: PNW CX 25
PNWCX25, is that 1/2 inch sheets of AquaPlas III? Jeff
Re: PNW CX 25
This does not like being cut with a jig saw, the blade get to hot and melts the path back together.
Re: PNW CX 25
Thanks, I'm have a lot of fun with it so far.
Re: PNW CX 25
Decided to put the blocks that attach the furring strips on. I'm not sure if the placement is right - most likely will have to make adjustments. I'm about 1/2 done with the pre cut blocks starting to feel like I'm making progress.
Users browsing this forum: Bing [Bot] and 1 guest
