sin city D15
cj3a
New Poster
New Poster
sin city D15
Post by cj3a »
I have the hydrotech, plans and kit...........now if i can find the skills. :doh:
I already have an 18 horse 'rude to push it.
Locally I have found 25/32 Honduras mahogany; will this work on the transom or is it too thin?
Is there a preferred wood for the splash rails?
How much Quick fair will I need to do all the fairing?
I'm getting rather stoked.
Fuzz
Re: sin city D15
Post by Fuzz »
I do not know anything about building that boat but I can tell you not to worry about the skills part. If you want to build it and stick with it then you will build it. I am pretty sure my woodworking skills are at the bottom of the list but this method is forgiving enough it did not matter.
Fuzz
jacquesmm
Re: sin city D15
Post by jacquesmm »
I can't answer about the plywood, I must look at the plans. What do the plans say?
Watch out for the weight of the engine, that puts stress on a transom while on the trailer.
cj3a
New Poster
New Poster
Re: sin city D15
Post by cj3a »
"Outboard clamp: hard wood (mahogany) 10" x 1", one 5' piece.
Locally I have found 25/32 Honduras mahogany; will this work or is it too thin?
Thank you
jacquesmm
Re: sin city D15
Post by jacquesmm »
'll look at the plans tomorrow.
When I designed that boat, mahogany was reasonable priced. Not anymore. You can use plywood but thicker.
Tomorrow :wink:
cj3a
New Poster
New Poster
Re: sin city D15
Post by cj3a »
If my outboard is shorter than the 20" as in 15", should I lower the clamping board, or leave it flush with the sheer and cut it down?
jacquesmm
Re: sin city D15
Post by jacquesmm »
Please read this:
http://www.bateau2.com/howto/shaftlength.php
That is how an outboard should be installed.
Almost all engines are either 15 or 20" but some are in between and you have to adjust the transom height.
cj3a
New Poster
New Poster
Re: sin city D15
Post by cj3a »
thank you for putting me right!!
i measure 18"shaft length on my motor.
time for more measuring and cutting.
:D :D :D
cj3a
New Poster
New Poster
Re: sin city D15
Post by cj3a »
frames are together need to get pictures.... :D
cj3a
New Poster
New Poster
Re: sin city D15
Post by cj3a »
Ok, it is flipped and I'm almost ready to glass the bottom..... anyone have any advice on a trailer? :doh:
