sin city D15
Posted: Sat Apr 04, 2015 9:20 pm
by cj3a
I have the hydrotech, plans and kit...........now if i can find the skills. :doh:
I already have an 18 horse 'rude to push it.
Locally I have found 25/32 Honduras mahogany; will this work on the transom or is it too thin?
Is there a preferred wood for the splash rails?
How much Quick fair will I need to do all the fairing?
I'm getting rather stoked.
Re: sin city D15
Posted: Sun Apr 05, 2015 1:38 pm
I do not know anything about building that boat but I can tell you not to worry about the skills part. If you want to build it and stick with it then you will build it. I am pretty sure my woodworking skills are at the bottom of the list but this method is forgiving enough it did not matter.
Re: sin city D15
Posted: Sun Apr 05, 2015 5:26 pm
I can't answer about the plywood, I must look at the plans. What do the plans say?
Watch out for the weight of the engine, that puts stress on a transom while on the trailer.
Re: sin city D15
Posted: Sun Apr 05, 2015 6:58 pm
by cj3a
"Outboard clamp: hard wood (mahogany) 10" x 1", one 5' piece.
Locally I have found 25/32 Honduras mahogany; will this work or is it too thin?
Thank you
Re: sin city D15
Posted: Sun Apr 05, 2015 7:47 pm
'll look at the plans tomorrow.
When I designed that boat, mahogany was reasonable priced. Not anymore. You can use plywood but thicker.
Tomorrow :wink:
Re: sin city D15
Posted: Mon Apr 13, 2015 4:17 pm
by cj3a
If my outboard is shorter than the 20" as in 15", should I lower the clamping board, or leave it flush with the sheer and cut it down?
Re: sin city D15
Posted: Mon Apr 13, 2015 5:14 pm
Please read this:
http://www.bateau2.com/howto/shaftlength.php
That is how an outboard should be installed.
Almost all engines are either 15 or 20" but some are in between and you have to adjust the transom height.
Re: sin city D15
Posted: Mon Apr 13, 2015 7:55 pm
by cj3a
thank you for putting me right!!
i measure 18"shaft length on my motor.
time for more measuring and cutting.
:D :D :D
Re: sin city D15
Posted: Tue Apr 21, 2015 10:55 pm
by cj3a
frames are together need to get pictures.... :D
Re: sin city D15
Posted: Mon May 25, 2015 7:32 pm
by cj3a
Ok, it is flipped and I'm almost ready to glass the bottom..... anyone have any advice on a trailer? :doh:
Re: sin city D15
Posted: Mon Sep 07, 2015 11:05 pm
by cj3a
OK, the bottom is as good as i'm going to make it. I have one question that i cant seem to find the answer to: the hole for the drain plug, what size hole-saw do i use? is it necessary to use the brass sleeve?
Re: sin city D15
Posted: Tue Sep 08, 2015 8:19 am
Any size to fit the plug. I don't use a brass in a small boat, juts a hole.
Get the plug first then drill to the diameter of the plug, a little oversized, coat the hole with epoxy and that's all.
Re: sin city D15
Posted: Tue Sep 08, 2015 9:00 am
When putting in a 1" drain tube I use a 1" hole saw. It will be a little small, but a 1 1/8 is too large, so I use a Dremel tool to slightly enlarge the 1" hole for a snug fit.
Re: sin city D15
Posted: Tue Sep 08, 2015 9:33 pm
by cj3a
thank you for the information and motivation!!
Re: sin city D15
Posted: Tue Oct 20, 2015 9:25 pm
by cj3a
still work to be done, but i have a 6 week military school until just before thanksgiving.
my thanksgiving will consist of rebuilding the carb on the old 'Rude 18 fastwin. :D
