panga 22 build hull assembly
Re: panga 22 build hull assembly
So I've come to classing the hull when it comes to gel coat are there any tips I could use to achieving a smooth glass like finish and do I need to apply a type of primer coat before applying the gel coat ? Also do I sand the last layer of glass before applying the gel coat ?
Paint, not gelcoat.
The process is simple:
- QuickFair until the surface is fair
- High Build primer like the System Three one and sand down to 300
- paint with an LPU like EMC or Imron, Awlgrip.
That will give you more gloss than any gelcoat and a much harder surface.
Ok so no gel coat what do you mean by sand down to 300?
Also what resin should I use for my glass polyester resin or epoxy resin ?
300 grit sandpaper. Epoxy resin only!
Ok Il use epoxy , also when it comes to marine paint how much will I need to cover the pangas hull roughly
A gallon should do it.
How do i achieve a smooth finish with the glass ?
. sanded on a canoe, bought a used boat, stayed at a holiday inn last night
You get real friendly with your R/O sander and long board, and about every other sanding method known to manHow do i achieve a smooth finish with the glass ?
