Michael, I had to go back through your build to see if you had painted the exterior hull. It appears that you have (?).
That being the case I don't see a problem taking it for a run from the build point of view, but I would make sure that everything you can get at topside has a good coating of epoxy on it.
I understand your dilemma, but a bigger issue may be the legalities. Should the boat be registered and does it need to be insured before you water test it, or do you just take a punt?
To register it do you need a builders plate? Technically you don't require one for an owner-built boat but I figured it would be easier to just get one - so I did.
Insurance is trickier and maybe you don't need comprehensive insurance but third party cover is probably essential. I think its gonna be hard to get insurance without taking to the point where its looks reasonably complete. In my case I had finished painting the exterior hull and had the decks and cockpit to the primer stage. As I was going to trailer my boat I just wasn't game to take it out of the yard without insurance.
For me, fairing the decks and cockpit was quick and easy - not the chore that fairing the hull was, so getting to the primer stage was relatively easy. I am still working on finishing painting the decks and cockpit, the hatches, rub rail, side rails etc - some 6 months after I splashed the boat.
Now the selfish part of me is hoping that you don't splash it before the end of September because I will volunteer to be the "chase" boat - but I am pretty busy before then.
- glossieblack
Re: ST21 Hybrid Powered "SKINNYDIP" Noosa Australia
apologies, duplicate post deleted.
- glossieblack
Thanks Eric, Jaysen, Fuzz x2, cape man, Mr Paul, Tom, and Lee.
Cupla things, based on your valued comments gents.
She's already faired and primed externally. And she's not going to be officially splashed until she's finished.
But in the meantime she may have a quickie it-never-happened full moon rat rod test run. Too see if things work the way they are meant to, are in the right place for ease of operation, etc.
My latest thinking is to get a coat of anti foul over the primer and up to a 3" line above the anticipated waterline before any rat rod test run.
My boat painting guru friend and his partner are coming for to lunch and a few cool ones tomorrow, so this will be explored further then.
- BarraMan
Why mess it up with antifoul if you aren't going to leave it in the water?
- glossieblack
You may have a point there. I'll see what the paint man says.
Hi glossieblack,
Anti foulings - the ablative kind anyhow have to be in the water fairly soon after applying from my understanding and kept wet. Since mine needed to be coated while inverted and not seeing water anytime soon, I went for Pettit (I think Unepoxy) anti-fouling which can stay dry for an extended period. I will give it a fresh light coat prior to launch. From my research back then, it was the only type I found. And to boot, not all antifoulings out there are available in Canada.
Build on
Marc
Build on
Marc
- glossieblack
Thanks Lee and Marc.
My paint man reckons the etch primer and high build primer he’s sprayed on will handle rat rod test runs fine, so long as the boat is not left in the water for any length of time, because what’s been applied is slightly porous.
His recommendation is to pull the boat out of the water between rat rod test run sessions, so that the hull can dry out while modifications are being made, before putting her in the drink again for the next test session.
When testing is finished, he recommends thoroughly cleaning, degreasing, and letting her dry out for a few weeks, before final fairing and painting.
Because scows are usually flat bottomed and blunt ended, whereas Skinnydip is pointy bowed and with a sculptured bottom, from here on in I'm going to describe her as nothing more than an oyster workboat and camping platform.
Pithy, amusing, and very close to the mark cape man.
- BarraMan
Sounds almost easier to fair and paint the exterior hull before any rat rod test runs! (Says he who is about to lift the motor off so he can finish the transom and some plumbing in the bilge).His recommendation is to pull the boat out of the water between rat rod test run sessions, so that the hull can dry out while modifications are being made, before putting her in the drink again for the next test session.
Pithy...hmmm. Been awhile since I was called pithy. I'll wear it.
Barraman has a point on the paint. Know you need to run it to test her, but if your painting her anyway, why not get the outside done first? Especially if you have a "paint guy"...
Loving this thread. Sorry for the occasional attempt at humor.
- glossieblack
Please don't stop, you hit the funny bone sweetly each time.
