FS14 Low Sheer Tampa Bay
Re: FS14 Low Sheer Tampa Bay
So! I fixed the gap near the bow with a few layers of tape. I will do the same on the inside for strength. Finished filleting the outside and tried to smooth off the edges. I did run into a few problems... I only secured the frames to the jig on one side and the frames warped under the weight of the hull in the heat and humidity. I flipped the hull and flattened the frames. I am going to replace the frames, pull in the hull against them using ratchet straps, and glue them in place next!
Peejay1023, send us some recent photo's of your build!! Thanks, Jeff
GA Jeff,
Backup one page.
Backup one page.
LOL I was a bit confused. I just posted today.
So I could use an opinion. There is a supplier that has 17 oz biax cloth on the cheap. should I use this to cover the hull? will it make a significant difference? opinions?
- topwater
Its going to add weight over something like 6 oz or 10 oz and use more epoxy.
Novi 23 finally launched !
Correct 17 oz. is too heavy plus, it will double or triple the amount of resin compared to 6 oz.
That will more than double the cost too.
I got a deal (free) when decking my OD18 of some 16 oz woven. While the deck is certainly "solid", I lost more money in the epoxy that it took to wet it out than I gained in the "deal". One reason my boat is 300 lbs heavier than Jacques' plan.
