K2FS18
Re: K2FS18
Coming along great. Just put all decks and soles on to see how she is gonna look. Still working on transom/bilge area and cleats, plus all those little details that take time and thinking.
Re: K2FS18
Wish I had super human boat building powers like yours. I'd be fishing in mine by now. I've got 4 months and I'm still fairing my hull.
Re: K2FS18
Well MrPaul, I skipped that part. I am thinking I want to finish some of the inside first. It is light enough to flip back over to fair and finish later I think.
I am just taking advantage of some free time I have between jobs.
Re: K2FS18
That's looking great I like the lay out.
Re: K2FS18
Slowly coming along the past week and half. The cleats just about did me in. If, IF, I ever do this again, I will glue cleats to stringers and possibly bulkheads before I install. I think this would speed the process and make it easier.
Got the sole down in compartment "A" and "B". Finally all cleats are installed. The structure is complete in the transom/bilge area and surface drain from cockpit to transom/bilge area is all but complete.
Was planning on finishing foaming and installing remaining souls, BUT, ran out of material. This has been the case from day one. Always running out of something. Caused either by waste, adding something not on plans or just lack of experience. Oh well, lots of other stuff to do while material is shipped.
Re: K2FS18
Day late and a dollar short If you build another boat you might think about trying this on the stringers. I cut a 2x the width I needed and then cut a dado down the middle of it. Puddy up the slot and drop it over the stringer. Done deal It does raise the level a little but you can work around that.
Like the others I am enjoying your build, keep it up.
Re: K2FS18
Got my shipment of extra foam and got to work. I wanted a full fill sole. I first tried using the pillow tops as filler and pouring around. I did not like the results; as seen in the forward cavity. Once cured, it seemed to be more waste. I just bit the bullet and ordered an additional 4 gallons to pour so that cure was full fill and pillow tops where cut and discarded. I have about a gallon left over. I added additional cross members to help stiffen sole as well.
Got the sole glued down as well. Once cured, I was finally able to stand in the skiff. One thing that I noticed was the flex and the air that pressed out from around the sides. I figured with full fill foam and additional cross members that the sole would not flex. I am sure it is minimal flex, just noticeable.
Also laid down a layer of 4oz cloth on the sole. And once again ran out of epoxy. This time I reordered 3 gallons because last reorder of 1.5 did not get it done. The worst is running out of something. I would rather have extra left over than for work to stop. I used some peel ply as well to remove some extra resin. Yep, that is where it is all going.
I have taped (4oz) all the joints from hull to soles, bulkheads, etc. I am sure this is not needed, but I don't want any water to get below sole. There is no way for it to get out once in. Maybe the 4oz is really 6oz, I cant remember at this point.
Re: K2FS18
K2FS18, looks nice!! Send me some wider shots of the boat!! Jeff
Re: K2FS18
So here is 1.5 quarts of S3 Quick Fair. That did not last as long as I hoped. Ordering 3 quarts more and hopefully will have some left over. I don't think I am using too much. Just filling in the low spot created by the glass tape at edge and keel and filling weave at front section. Looks like I got another week or so of no boat building time on my hands.
