The temperature got up to about 70°F today so it was build, build, build!
The skeg was cut and the edges were all routed to 1/2" radius. It is just over 6' in length and ends about 18" from the transom. Epoxy + wood flower glue was applied and a few screws were used to hold it in place. After it set, the screws were removed and the holes filled with epoxy + wood flower. I still might still add a piece of 6 oz. tape:
Next up: sharpening the back 6' of the chine and the transom edge. I picked up a few 7' lengths of cheap composite molding at Lowes, covered them in packing tape, and screwed them in place to form dams for a mixture of epoxy + milled fiberglass. After removal of the molding it looks pretty good, although there are still a few holes to be filled - here it is after a quick hit with the RO sander:
The rub rails were cut 1.5" high from 6 mm plywood - there will be two layers total (it will have scuppered inwales also). Then I prepped the surfaces to be glued: a quick sanding and acetone wipe down of the hull followed by a brushed on coat of neat epoxy on both the hull and rub rail. Next, I mixed up some epoxy + wood flower glue, applied it to the rub rail strip and clamped it in place. Since I had to splice together two strips, I made a matching slanted diagonal cut on both pieces. The ends will get trimmed after the clamps come off the second layer. Here are a couple of pictures of the first layer glued and clamped:
I'm getting closer to fairing. Just a few more touch ups to the sharpened edge and a second rub rail layer, then on goes the first layer of fairing gloop!
