FS14_LS - CSotelo - Brazil
Re: FS14_LS - CSotelo - Brazil
Great job on your FS14 LS!!! Good flip as well!! Jeff
Wow! That is looking good.
Thanks, Jeff and Eric!
After fairing, everything looks easy and fast. I did the fillets and tapes on inside.
Now getting ready to glass the inside. By now I spent 14kg of epoxy, I used too much on outside working just with squeegee. I´ll try roll on inside.
Thanks!
Thanks!
Hello,
Inside glassed. I used less epoxy than outside using nap roller to spread it.
I filled the weave in some points that will not have frames and stingers with fairing putty after glass got tacky. Less things to sand.
Now waiting everything cure to sand.
I´m considering extend the cockpit to 140cm or 150cm. I think it will more comfortable more around. Any ideias?
Thanks!
Thanks!
Hello,
I glued and glassed the stingers, one round, no sanding. I´m doing evething is possible to avoid sanding
After a lot of measuring and considerations I extended the cockpit to 150 cm. The original size was ok for one guy, but for two was to short in my opinion. Two large guys like me
Now i´m dry fitting the stations.
We don´t have the 2 part closed cell foam here, so i´m planning to fill the sole with high density styrofoam and fill the gaps with expanding foam.
Is that a good idea??
Thanks!
Thanks!
I don't think I would do that. I believe it absorbs water and leads to rot.
By the way I pray I can build as nice as you have after the flip! That looks really Nice!!!
Hi Eric,
I´m reading about EPS, looks it absorbs about 4% of it´s weight if it´s high density. XPS absorb much less, it´s my second choice because it´s hard to find. I´ll look for other alternatives.
I´m seen you dedication in fairing, I gave up much earlier!! I´m sure you will do even better than I, my friend!
Thanks!!
Thanks!!
Hey,
How goes the build?
How goes the build?
Hey Eric,
I made the fillets and glassed the stations.
Started dry fitting the cleats for sole and decided dry fit everything before glue. So I got the ply to soles and decks and cut then.
Now I´ll get the wood for hatches frames. I´m thinking about 2,5x5,5 cm timber. Looks strong enough stand my weight.
This will keep me busy until I decide how to fill the under sole.
I´m seen your fairing job, It´s getting good! The boat is so smooth that you will not even need primer
Regards, man!
Some Pics:
Regards, man!
Some Pics:
WOW! You are moving right along!!
