SK14 Build
Re: SK14 Build
Yes, that is how we built the last prototype.
However, it is a fact that the sides try to pull out more than expected and strap will help.
If you use a strap, clamp a temporary rubrail along the sheer, just to keep it fair.
When you pull the sides together, the hull shape changes a little bit, the deadrise increase which is good.
Re: SK14 Build
Thanks for the links. We got it as good as we could today. Forward bow frame still won't sit down so I went ahead and spot welded everything from B back to transom. All in all everything else fit good.
Capt. TW
Re: SK14 Build
Still ended up with a 1/4-1/2 gap on frame, filled it up with thickened epox and went on with it.
Capt. TW
Re: SK14 Build
Capt. TW
Re: SK14 Build
Frame A looks much better now.
Great fast progress.
Re: SK14 Build
Thanks Jacques, pretty pleased with it so far... Frame A is not installed yet, I could not get it to lay down without knocking everything else out of its place. I figured I could pull and bend were needed after it cured to get the bow straight, no big deal I hope. The only thing I can remotely figure out is the two side panels have opposite grain direction and causing it to twist in the bow, if that even makes since..
Capt. TW
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 19 guests
