I agree, I think that may cause a drag problem on the water though!
FS18 Straight Sheer, Round Chine
Re: FS18 Straight Sheer, Round Chine
- Steven Wright
- Steven Wright
It's looking good Reid!
You did a great job on the stitching, so you're off to a good start. You should brace the legs on the strong back. I would run long 2x4's along the bottom tying the legs together, as well as port to starboard, than some diagonal bracing. The hull doesn't weigh anything now, but believe me, when you get further along, 250-350 pounds is more than you think and will wrack the hell out of a poorly braced platform, especially if you're going to be rolling it around. Mike
Mike,seaslug wrote: ↑Thu Apr 13, 2017 9:48 pm You did a great job on the stitching, so you're off to a good start. You should brace the legs on the strong back. I would run long 2x4's along the bottom tying the legs together, as well as port to starboard, than some diagonal bracing. The hull doesn't weigh anything now, but believe me, when you get further along, 250-350 pounds is more than you think and will wrack the hell out of a poorly braced platform, especially if you're going to be rolling it around. Mike
I thought about bracing the legs when I added them on to the strongback. This was an old strongback that Jacques had lying around the shop. I just happened to work perfectly for this build and I added legs to it. I just got done with the masking tape on the inside hull and not having braces in way made it easier to get under there. I think I will brace the legs once the outside of the hull is completed and we are ready to flip. Thanks again!!!
- Steven Wright
- Steven Wright
Looking good Reid!
Thank you everyone for the positive feedback!!!
Today I finished up the epoxy glue welds in between the zip ties. Next I will cut out the zip ties and finish off the fillets. I will have a little work to do on the chine and bow tip to get that nice and smooth and ready for glass. I will also be working to bow tip to add a flat spot for my bow eye. All of my fillets will be quarter rounded in order for the glass to lay down without any air pockets. Once the glassing is done I will go back in with fairing compound and make the edges sharp again.
- Steven Wright
- Steven Wright
Looks great Reid!
Today I was able to get the seams completely filled with fillets. Prior to filling in the gaps where the zip ties were, I did some sanding. I did a little quarter round sanding where the bottom panels and the side panels meet towards the transom so I can ensure a good quarter round when tape and cloth get laid down. I also did some sanding on the rounded chine in order to give the chine a nice smooth round transition for when cloth goes on. I figure that the more work I put into getting the shape right now, the more work I will save myself later when it comes to fairing. I mixed up more wood flour and MarinEpoxy and filled the rest of the gaps. I also used it as kind of a "Bondo" for making the rounded chine nice and smooth. Once this sets up I will come back with my sander (60 grit) and sand out any imperfections. Very close to getting some tape down on the seams!!!
- Steven Wright
- Steven Wright
Nice work Reid!
Users browsing this forum: Google [Bot] and 5 guests
