Fishgitr,
Thanks!
I just used some 3M painters tape and crawled under the bow. I had built the strongback approx 2' off of the ground for the ease of working under it. These were all great suggestions that I got from Seaslug.
-Reid
Fishgitr,
Seaslug,seaslug wrote: ↑Thu Apr 20, 2017 8:38 pm Hey Reid, I know we've talked about the chine cuts in the plywood, but until now I wasn't aware that you guys cut the slits with a 1/4" router bit. For the builders that do not purchase the CNC cut kit, it would be very helpful to include in the plans a notation to cut the strips with a wide gap. I had an awful time shaping the bow section because I used a thin kerfed jig saw blade for the cuts. It was the hardest part of the build, and looking at your pictures I can see how nicely yours came together. If I had known beforehand, I would have avoided about 20 hours of extra work. Mike
Yes, we need that note.seaslug wrote: ↑Thu Apr 20, 2017 8:38 pm Hey Reid, I know we've talked about the chine cuts in the plywood, but until now I wasn't aware that you guys cut the slits with a 1/4" router bit. For the builders that do not purchase the CNC cut kit, it would be very helpful to include in the plans a notation to cut the strips with a wide gap. I had an awful time shaping the bow section because I used a thin kerfed jig saw blade for the cuts. It was the hardest part of the build, and looking at your pictures I can see how nicely yours came together. If I had known beforehand, I would have avoided about 20 hours of extra work. Mike
Bajabugs,
Absolutely!!! I will take that compliment. I just figured I was setting myself up for a comment on how weak us south Floridians are when it comes to the cold weather.
Users browsing this forum: Ahrefs [Bot] and 19 guests
