FS18 Straight Sheer, Round Chine
Re: FS18 Straight Sheer, Round Chine
Got the fuel gauge, USB Plug, and Fusion stereo installed into the console today.
- Steven Wright
- Steven Wright
That is one nice and clean looking console.
Wish I could think in clean and simple.
Very nice!! I do not see a tach to dial in the prop? Tom
Fish won't bite if that radio is thumping...
Going to have to wing it a little I guess. I will use a portable GPS unit to help gauge my speeds. The motor (Suzukit 25 HP w/ electric trim/tilt) can be adjusted with the trim/tilt feature as well as adjustments with the jack plate. Tom, I will definitely rely on your expertise if I need to make any prop adjustments! I assume I will eventually get a nicer prop to replace the factory prop that comes with the motor but I will have to cross that bridge once the boat is fully rigged and I do some test runs with it fully loaded.
-Reid
- Steven Wright
- Steven Wright
Don't worry buddy, the "Flats Stalker" will be in full stealth mode when lines are in the water. The stereo is so I can play my victory music as I idle up to the dock to weigh my trophy catch!!!
-Reid
- Steven Wright
- Steven Wright
Tiny tach?Reid wrote: ↑Wed Dec 14, 2022 8:47 amGoing to have to wing it a little I guess. I will use a portable GPS unit to help gauge my speeds. The motor (Suzukit 25 HP w/ electric trim/tilt) can be adjusted with the trim/tilt feature as well as adjustments with the jack plate. Tom, I will definitely rely on your expertise if I need to make any prop adjustments! I assume I will eventually get a nicer prop to replace the factory prop that comes with the motor but I will have to cross that bridge once the boat is fully rigged and I do some test runs with it fully loaded.
-Reid
https://www.tinytach.com/gasoline-tinytach
I also recommend the Tiny Tachs when someone does not have a tach on their boat. Tom
Ok, good advise. Maybe I will get one and mount it next to my electrical panel.
Thank you TomW1 and Fallguy!
-Reid
- Steven Wright
- Steven Wright
- glossieblack
Elegant FS18.
