28 Bertram Restoration Boat 2
Re: 28 Bertram Restoration Boat 2
Spray fair is something I discovered on my last boat. It is a 2 part epoxy fairing compound that is thin enough to spray thru a 2.2 tip. It fills well and is easy to sand. I use it to get a smooth surface and fill small holes. once i sand it it is easy to see the low spots that need a more aggressive fairing with a conventional compound. I have even thickened it with silica or glass bubbles and put it on with a spreader. it is made by Alexseal. I recently purchased a Hutchins 17" orbital file sander. This thing works great for getting a flat and smooth surface but it is an air hog. I had to add a second compressor to use it continuously but it was well worth the money
Is this the stuff? https://www.alexseal.com/exterior/high- ... y-fair-328Mbiggerstaff wrote: ↑Thu May 23, 2019 10:45 am Spray fair is something I discovered on my last boat. It is a 2 part epoxy fairing compound that is thin enough to spray thru a 2.2 tip. It fills well and is easy to sand. I use it to get a smooth surface and fill small holes. once i sand it it is easy to see the low spots that need a more aggressive fairing with a conventional compound. I have even thickened it with silica or glass bubbles and put it on with a spreader. it is made by Alexseal. I recently purchased a Hutchins 17" orbital file sander. This thing works great for getting a flat and smooth surface but it is an air hog. I had to add a second compressor to use it continuously but it was well worth the money
Eric (aka, piperdown)
Thats it
Progress continues. Top is on and first round of spray fair applied
Nice mike! Looking good my man
You do some outstanding work for sure.
That is one neat looking boat! Very nice
Follow up questions on spray fair...
Mil thickness?
If you had to choose between a neat coat on slightly sanded through glass and spray fair which would it be.
Glass on foam core that is...
Mil thickness?
Maybe a real dumb question - Did you spray the spray fair or roll it?
from the pictures it looks like you rolled it on........................
