Drain tube flaring tool
Re: Drain tube flaring tool
Richard needs a flaring tool for the FS18. Who has the one that Cracker Larry started sending around years ago?
I have them.
Richard,
PM me and I'll send them to you.
Steve
Richard,
Steve
I replied to quick before I realized who you were talking about. I PM'd him.
Steve
Steve
Capeman, don't know what happened to Cracker Larry's, these are the ones I had and put them up for use.
I sent them to Dutch1
Completed: FL14, OD18
Good on you! Might be worth a search for the Cracker's...
Found the last posted location... Chopper Man!
Hi Dutch,
I sent you a pm, thank you!
Larry and Craig, thanks.
Richard
viewtopic.php?f=12&t=62146
Could I possibly borrow this flare tool?Aripeka Angler wrote: ↑Sat Dec 16, 2017 8:40 pm Hi Dutch,
AA, We spoke before and you are going to do drains out of the sides of your sole.. Are you putting a brass drain tube there or just drilling the plywood?
Fishgtr,fishgitr wrote: ↑Fri Dec 22, 2017 2:04 pmCould I possibly borrow this flare tool?Aripeka Angler wrote: ↑Sat Dec 16, 2017 8:40 pm Hi Dutch,
I have drilled the drains through the sides of the hull. I have sized the holes for 1" id drain tubes. I beefed up the thickness of the hull where the hole is drilled so the plug doesn't protrude through the hull side when the drains are plugged. I am really happy with the setup.
Dutch wants the flaring tool back after I finish using it tomorrow. If he is not quite ready for the tool, I'm sure he will let us know so I can send it to you first.
Richard
Thanks AA..can you send post a picture on how you did that drain area? Thanks man!
