This has been discussed many times but to avoid repetition, I will make it a sticky announcement and maybe later, move it to the HowTo files.
Builders of our small boats often ask if they can have a marconi rig instead of a sprit or lug rig.
The sprit rig has a sail with 4 sides, the marconi rig has a triangular sail.
Let's see what are the differences, pros and cons.
Marconi sail:
Pro:
- familiar look
- sail closer to the wind
Cons:
- longer mast = more expensive and cannot be stored in the boat
- less sail area, slower except close hauled
- more difficult to raise the higher mast
- requires shrouds and forestay (cables)
- requires heavier mast step
Sprit rig:
Pros:
- very simple set up of the mast
- no shrouds
- simple mast step and partner.
- store in the boat
- made from small spars, inexpensive, easy to make
- sail can be made by an amateur
- faster downwind and reaching
- often, there is no boom to hit you in the head while tacking
Cons:
- does not sail as close to the wind as marconi ( 5 to 10 degrees difference)
- a couple more lines to hoist the and set the sail.
I design many small boats with a sprit rig. Those are in general row boats that can be sailed, not pure sailboats.
If the builder wants to install a marconi rig, he must do the following:
- keep the center of the sail area in the same longitudinal spot (simple geometrical center of area)
- reinforce the mast step, the partner and the frame that will take the shrouds
- install some plate for a forestay.
- plan for some type of boom vang
Conclusion, if you want a marconi rig, keep it simple and build a boat designed for it like our CR11, CR13 or the excellent C12.
sail plan changes, marconi rig
Users browsing this forum: Bing [Bot] and 2 guests
