I'm using foam core to rebuild my Banana River and am about to start cutting foam for the interior of the hull. I know I need to wear safety goggles to prevent dust from getting into my eyes and a respirator to make sure I don't inhale it but do I need a tyvek suit or the like? It's standard 1" divinycel.
I can't find a good answer.
Thanks.
Cutting foam core- safety measures?
- New Poster
Re: Cutting foam core- safety measures?
All I wear is sometimes gloves to reduce skin exposures.
The product you are using would have an msds. Look for it in the manufacturers website.
Can you use a hot knife to cut it? No dust just smoke if it burns. When I set up my hot wire to cut large blocks (as high as 24" blocks) of Styrofoam very little smoke and zero dust. It would be like using a band saw but easier to use a fence to make straight cuts.
Some core's produce toxic fumes when cut with a hotwire, some do not. It is best to use the appropriate method depending on the core.OrangeQuest wrote: ↑Tue Aug 07, 2018 8:07 pm Can you use a hot knife to cut it? No dust just smoke if it burns. When I set up my hot wire to cut large blocks (as high as 24" blocks) of Styrofoam very little smoke and zero dust. It would be like using a band saw but easier to use a fence to make straight cuts.
- Evan_Gatehouse
Yes, I've thermal formed Corecell and if heated too much it gives off nasty smelling fumes.
For cutting it - score with utility knife and just snap it like drywall / gypsum board. Or cut curves with a jigsaw. It's quite benign.
SK17,MM21/MT24
SK17,MM21/MT24
There is always a fan blowing across my work bench to keep fumes away. I also use a variable voltage/current regulated power supply that I adjust the temperature to just able to cut through the foam. I use a Nichrome wire that does a nice job of keeping the same heat all across the cut. Easy to adjust the temp by increasing the voltage till it's to hot to touch. Styrofoam melts at such a low temperature. Things smoke when to hot and burn.
I have to push the blocks through very slowly because the wire is so thin and temp so low that to fast and it breaks. Because I build the cutter every time I can adjust the angle of my cuts and cut up to 40" or buy the wire in a spool and go even wider. To make my cutter I have a small hole in the center of my work bench and feed one end through and attach to a brass nut and bolt. Clamp a board to the table top that I screw an upright to. 1/4" bolt and nut to allow the upper arm to pivot on. Another brass nut and bolt to attach the cutting wire to. Adjust a bungee cord just enough to keep the wire tight. Wire gets longer when it heats up. Use a protractor to set angle. Clamp long board to table for fence. Can stack multi sheets for repeat cuts or patterns.
That sounds like a slick setup. Do you have any pictures of it?
