Corecell vs Divinycell
What is the differences between the two? I see the Corecell is about half again more in price so what do you get for the extra cost
Re: Corecell vs Divinycell
The hdt is the primary difference with Corecell M.
There might be some other engineering differences iirc, but probably not worth the money.
Gurit is considered the best, so command the best price. Honestly, not sure it is worth it.
But I am using all Gurit; so there you go..
Yes, CoreCell is superior especially when it comes to shear strength but, what if the Divynicell core is already 2 times better than what you need?
You can't reduce the skin specs because you use CoreCell.
Users browsing this forum: Google [Bot] and 11 guests
