It does doesn't it like deja vuKnoxville_Jay wrote: ↑Thu Sep 20, 2018 8:05 pm Oh wow, that all looks strangely familiar...
Everything is looking awesome!
Keep those pictures coming!
C17 in the bayou
Re: C17 in the bayou
Check out my build----C17---- hit the link https://forums.bateau2.com/viewtopic.php?f=2&t=63575 ,OD18 build link Nola OD18 - Boat Builder Central - Builder Forums
viewtopic.php?t=65341
Nice work Salty!! Just call me when you are ready!! Jeff
Hopefully this week had some delays but should be back on track this week more pics coming soon
Good stuff Salty!! Jeff
I was curious as what that max hp is for this boat I did the coast guard calculations and I would seem that it is 130hp this cant be right would you be able to answer this question ? For me
Salty, Jacques calls for a 50HP outboard motor for the C17. He will likely respond later but that is what his notes call for!! Jeff
I had saw that but I didn't think that that was the max hp and one more ? About how much primer would I need to cover the hull ? Thanks Jeff for the quick responses
Salty, we believe a Gallon Kit of the SystemsThree Yacht Primer will get you two coats on the C17 Hull! Jeff
Salty,
I would put three coat of the System three high build primer on before you sand.
Spray a guide coat also before sanding.
Is this the same as the yacht primer or some thing different
And what about using graphite on the bottom would I still need the primer there or do I just apply the graphite with the primer or by It self
