C12 - TL70 - Brazil
Re: C12 - TL70 - Brazil
Nice progress!!!! Jeff
Some updates of our catboat
Fiber glassing the inside part of the hull
Finishing the centerboard trunk inside part after turning the hull
We have then begun to sand and paint the hull bottom part
and worked on the rubber fixations... testing first
Nice weeks to all,
Durval & Audrey
Nice weeks to all,
Durval & Audrey
jacquesmm wrote: ↑Thu Jun 27, 2019 11:20 am About the painter. It is just a cable or even a metal rod. I prefer a cable (line, rope). It's attached to the CB and goes through a hole with slot like this:
http://bateau2.com/howto/centreboard.php
Bamboo mast: that will not work, sorry.
For the CB being able to swing 120 degrees, the solution is simple: adjust the length of the painter (lifting rope) so that it does not go further than 80 degrees.
JM, DuEholic had this question:
Regarding the bamboo mast, could you just explain why you say it won’t work?
We really have no idea, but are studying a lot about this possibility, so any additional information is really relevant for us?
Eric (aka, piperdown)
Bamboo mast: not strong enough. It could work with a small chinese lug sail. I tested that in Haiti on a boat similar to the FL14 but the setup was different.
Manu thanks Eric and Jacques !
We will follow your recommendation and make the mast in wood.
What would be the easiest way to build it considering we need to do it in 2 parts?
The total weight of the mast does impact the whole structure?
Regarding the fabric of the sail? Would you have some suggestion, as we will have to make it by ourselves?
Many thanks,
Hi guys, good night to all.
Here are some of our last pictures...
still working on the mast construction.... lots of interesting wood works.
beginning to adapt a cart for the boat:
more fotos and videos: https://www.maripoulain.com/projeto-tl-70/
Very nice work!!!! Jeff
So many good pictures, love this one,
Also love your chess board and map, lots of great detail and art going into your projects
