Jacques,
The engine shaft length is 508mm. Yes I believe we can get brackets if needed.
PC24 Engine placement
Re: PC24 Engine placement
That's a 20" shaft in the US, good.
Yes to the brackets, that is the easiest and strongest way to handle this.
I will sketch some transom knees and a clamping board. Give me a couple of days.
Thank you
Any luck with these yet Jacques?
Also, I guess we'll still need to build the engine pod? Does it play any part in holding the boat together?
Users browsing this forum: Google [Bot] and 7 guests
