Looking great. The fairing of the hull is a tedious process, sand on.
Just to give you an idea of how the boat floats here is a picture of mine on the first float test. The engine weighs 230 pounds and the 12 gallon fuel tank is under the front bench.
Roman´s OB15 (First Time Builder)
Re: Roman´s OB15 (First Time Builder)
- Attachments
- 8D37D9DD-5B7A-4C77-BF0E-AD2B010185A4.jpeg (113.48 KiB) Viewed 1737 times
Thank you for thr picture. It realy helps.
Since the boat is in the barn of my parents in law, building is on hold for a longer time. Our government encouraged us to stay at home, so I am in homeoffice right now. We also would never endanger my parents in law, both above 60.
I am a journalist by profession, so I also read alot of US-media. When I read about young people partying at springbreak, I think you are making the same mistakes, we made. Through february here in Europe we were thinking, it is a chinese problem. Even with first cases in Italy, there were still Apres-Ski-Parties. And one infected barkeeper at one bar infected many Partyguests, tourists from all over europe. I fear the same could happen to the US.
So be prepared - mentally - for what there is to come. Protect the elderly people, help each other but keep the distance. The good thing in free societies: In times of crises we stand together. The sun always sets, evev after a dark night.
best wishes from Austria
Things are getting normal here in Europe. So the last few weeks I could go back on working on the boat again. I did more sanding and filling. But I had to realize, that I am not the prefect craftsman. There are some spots, that are not perfectly even. But as I see it: It is my boat, build with my own hands. That´s something to be proud of.
After sanding priming it the 4th time, my wife said, I developed a strange passion for sanding and priming. So I decided, the hull is ready for some color. In the city near the house of my parents-in-law is a color-factory, where I could buy my colors. It is ivory (RAL 1014) for the bottom and brown-red for the side (Ral 3011). I had 4 layers of primer, 2 layers of ivory and for the side another two layers of brown-red.
So, the next big step is turning the boat. My idea is keeping one of the molds (nr. 4) in the boat and securing the side with straps.
The next step would be glassing the inside. Here I have a question. The OB15 has horizontal stringers. Should I glue them on before glassing the inside or after glassing?
Stay safe!
Stay safe!
Glass the entire inside before tabbing in your stringers
I could manage to work four days in a row on the boat. On one day a friend of mine came to help me with the glass.
But first I had to turn the boat. It lies on some old mattresses. had help from my nephew and father in law. I turned it with the molds inside, mainly because I glued the molds to the boat at some places
Once turned it was no problem to get rid of the molds and i could start glassing the keel and the inside of the chines.
I had very view bubbles, which i filled later with a syringe.
I also startet glueing the rubrail and protected the outside with a foil.
Friend of mine came and we did the main job: Glassing the Inside.
Working together, we could do it in five hours.
After cutting the edges, I could not help it and boarded my boat for the first time. It was a really great feeling!
In september I have another week reserved only for the boat. I hope I can do the stringers and the two constructive frames on some weekends. In september I will make the foam. Since I decided to do a middle-bench, i can put all cables above ground and won´t need tubes.
But regarding the foam. For me it is difficult to find out, which one is the right one. In Europe they are not really labeled "flotation foam". After reading a lot about foam and how water can get into it, it did become sceptical. Then I found a foam, which could work. But I would like to hear your opinion
https://www.yachtshop24.com/epages/6329 ... ts/126.338
It is a german website. But I have a pic of the description.
Is this the right foam?
Congratulations on the flip! That is always a big step to get done. Having help for the big glass jobs sure is nice.
You boat looks good as does your glass work. From what you posted the foam seems to be the right stuff but it is hard to know for sure.
The first sentence in the GB section indicates that it is correct. Specifically
* closed cell
* floatation
Jeff might ask Jacques to weigh in on the density specifications but I’m pretty sure that foam will do the job.
* closed cell
* floatation
Looking great. It’s nice seeing another OB being built.
Ruben
Ruben
Thanks a lot! Your positive reactions really motivate me!
That foam would be listed as 3 pound foam here (50kg/m3 = 3.2lb/ft3). Perfect for what you are doing.
Users browsing this forum: Amazon [Bot] and 20 guests
