Phew!Dan_Smullen wrote: ↑Sat Jul 30, 2022 9:52 pm Chopped 2” off of the leaning post legs after a last minute lean check.
C19 in Richmond, VA
Re: C19 in Richmond, VA
Tragedy averted!VT_Jeff wrote: ↑Tue Aug 02, 2022 12:59 pmPhew!Dan_Smullen wrote: ↑Sat Jul 30, 2022 9:52 pm Chopped 2” off of the leaning post legs after a last minute lean check.
Was just reminded that I started this thread on 8/23/19. Looking unlikely I get it painted before the 3 year mark. Oh well. Progress continues.
Time has been spent fairing around the bottom of the leaning post, epoxy coating bright work and sanding with 320. Also fixed a flub that had been bothering me on the rub rail at the bow. A tough spot that’s wedged up in the corner of the garage, but I took the time today to fill it in with a few strips of 1708 and thickened epoxy against a batten covered with packing tape. A little more sanding required…
Anchor locker hatch opening needs some love. The ready for primer.
64oz of Alexseal surfacing primer on the top, insides, console and leaning post. Got me 2-1/2 coats on the cap, and a solid 2 on everything else. I’d like to do 3-4 coats to be sure there is enough material to sand smooth, but still leave a layer behind, but I’m saving the 1/2 gallon I have left for the outside of the hull.
Enjoying the build...
Am I an arse if I ask why you did not go full height transom? I suppose the boat is unsinkable, so less important..
Thank you! Me too!fallguy1000 wrote: ↑Sun Aug 21, 2022 8:13 pm Enjoying the build...
I’m definitely not calling it unsinkable. Bad juju goes along with that phrase.
Not an ass. Good question. Early on, Jacques advised against a full transom and bracket on the 19, although I’d love it with a fish box across the back. With hindsight, I would have cut it for 25” shaft, but that ship had sailed and dont have the stomach for the mod.
No, that's not why you're an arse.fallguy1000 wrote: ↑Sun Aug 21, 2022 8:13 pm Am I an arse if I ask why you did not go full height transom?
Looking great Dan (Smullen)!
I think FG1K might have meant full height motorwell bulkhead, not transom. In that case, i am also a little curious.Dan_Smullen wrote: ↑Sun Aug 21, 2022 8:19 pmThank you! Me too!fallguy1000 wrote: ↑Sun Aug 21, 2022 8:13 pm Enjoying the build...
Phil
Nice moose rack!
Yeah. I mean the motorwell full up.
I hate backing into oncoming waves and filling the boat.
Sorry I didn't see it sooner for timelier dialogue.
But backing does happen now and then; especially if trolling or drifting and snagging bottom..I always end up putting on fishing bibs, soaking my shoes, etc
And if you are priming; you could sneak it in, yet!!
Users browsing this forum: Ahrefs [Bot] and 16 guests
