The mast partner was installed easy, per plan, from three panels glued in position one by one.
Next thing to do was the window openings on cabin sides.
Sanding and new layer of epoxy gel
A light fiber cloth on rudder
And I had to cut and fit again the cabin sole because the foam caused deformation on it.
AD14 - Ciulnita
Re: AD14 - Ciulnita
Your boat looks real good you should enjoy it once you get it going keep up the god work added another one to the fleet
Re: AD14 - Ciulnita
Wow, that's great! Your pictures show really high quality work. Good job. I liked how your real boat looks like the model you made.
Re: AD14 - Ciulnita
Thank you all!
For a first time builder i'm satisfied with the result. Working outside and with limited time and tools for the build it's all I could get from this.
Now, I have some issues with the access on water as there are so limited places in country where I could put the boat in water. I need minimum 4 people to help me get the boat in and out of the trailer and I would like to do it alone when help not available.
Back to the build:
Painted the cabin sides and cover the windows with lexan
I was thinking that some silicone will seal the leaxan in place but I ended up with a mess. I've put a rubber band on the other window and looks good. I will replece this silicone next year.
Cut the seat hatches
You can see the boat used as storage for all the tools and materials
Inside paint (the cabin sole needs sanding and a cot of epoxy/paint)
Back to the build:
Re: AD14 - Ciulnita
At the end of 2018 I've started making the mast and boom.
Mast from 4x4cm pine 4m joined 4 for a 6ish m long post. Rounded and tapered to 4-5 cm at the top with 8cm base.
Boom was constructed from 3m long thinner stingers resulting in a 4x8 cm. Sanded and fiberglassed with 2 layers light tape.
I don't have pictures from construction but here it's the mast with plastic wrap after glassing. Almost straight and round
When making mast I did what every newbie carpenter can do: hurt myself.
On the second day of using an electric planer I've decided to disable the safety switches as it was hard to work pressing 2 buttons. As a result I end up cutting the top of my middle finger of the left hand. No bone affected but say goodbye to guitarist profession
The mast and boom were finished and fitted for photo-session
In one day I had to do something on the cabin interior and I've come up with a shelf. Not great, not terrible
That was all for 2018
Re: AD14 - Ciulnita
Very nice work (except for the finger part)
Re: AD14 - Ciulnita
I don’t know. He still HAS the finger so it wasn’t “bad”. I know a few “8 finger Bob” woodworkers.
Re: AD14 - Ciulnita
Thanks, but I'm glad that I still have all 10 fingers. I have some relatives that have similar issues with fingers but none with missing ones.
Until recent years all the woodworking, as a hobby or as a professional, were made exclusively on hand tools and work was relatively safe.
I'm so scared about the power tools, especially the ones with rotary blades, and I always work with care. But sometimes accidents happens. I have a lot of scars from cuts, burn marks, I always hit things with my head and step in nails.
Re: AD14 - Ciulnita
First time I put the mast in place, on the boat, I was really hard to do it by myself as it's heavy and long. That time I was thinking to have a more practical solution to rise the mast and I end up with a tabernacle system.
So, I've cut the mast 30 cm above the mast partner and glued plywood battens. This first mast part it's secured with stainless screws from the inside.
The first design was not great and it snapped when I raised the sail on the first time. Now I've made it out of hardwood and steel plates.
From galvanized steel I've made a semi-detachable support, don't know the name of it, for the standing rigging.
Then I've glued and cutting the sail track
Next thing was to construct a bowsprit, not per plan, but detachable.
Light dacron purchased and with the sew the sail out of it.
Some time lapses of mast track construction:
[youtube]https://youtu.be/WwQoy_cJTfM[/youtube]
[youtube]https://youtu.be/VJYLNQTq1Kc[/youtube]
