Jeffs FS14 LS
Posted: Fri Nov 01, 2019 3:50 pm
by VT_Jeff
Hello,
I just bought plans for the FS14 LS, will be picking up plywood in Boston in a couple weeks. The support on these forums was a big part of my decision. Really great user-base here, hats off to all of you.
This will be my second build, I built a SnG drift boat from plans last winter, still putting some final touches on it but my wife and I fished hard from it all summer. She's a recent convert to fly-fishing after a 15 year obsession with whitewater kayaking, the fly-fishing obsession appears to be just as strong or stronger. We have no experience with flats fishing but am not going to let that small detail slow me down building a dedicated flats boat and getting started. We both work from home, have an RV and plan on spending some time in FL, already have trip booked to Homosassa in March/April to start scouting. Will bring the driftboat with a trolling motor, some SUPS and try our luck.
I think the FS14 LS is probably a bit small for the two of us but it will fit out my basement door, it will go good with a honda 20hp 4cycle I have lined up, it will fit on the trailer I currently use to haul the drift boat and motorcycle together, and it should be no less stable than the SUP's we fish on regularly, in whitewater.
I've been studying the plans and drooling over Seaslugs build. I don't expect mine to be anywhere near that build quality but it's good to have a benchmark. Giving myself about 18 months to get it splashed, goal is to bring it to florida on next years spring trip.
I have a couple questions which will not actually be pertinent for quite a while.
First question: Plans show a motor well. I noticed seaslug did not put one on his boat. The plans do not indicate if the motor well should be closed to the bilge or open. My preference would be to skip it if it looks like the motor can be tilted without it(no plans for jack plate presently, and not sure if that even matters), otherwise sealed from the bilge with scuppers though the transom. How critical is it and what's the recommended configuration?
Second question is about the self-bailing cockpit. I actually built the driftboat as self-bailing but went the super-simple method of adding a pluggable scupper just above the deck: no hoses, no throughhulls etc. I normally plug it while drifting and open it when left on the trailer/dock to drain rain, but I can leave it open in heavy whitewater to drain waves etc, which was the goal. That particular function has not really been tested yet. The The FS plans don't specify where to run the drains, how big, if they should cross(I have a sailboat and the cockpit drains cross to prevent flooding while heeling) and if they should drain below the waterline of in that small gap between the waterline and the sole-top.
Any thoughts more than welcome.
Thanks,
jeff
Re: Jeffs FS14 LS
Posted: Fri Nov 01, 2019 5:59 pm
1. Motorwell: it depends. If you install the motor on a bracket, you don't need a motorwell. For a motor bolted to the transom, you need the splashwell in order to tilt the motor and to provide room for the steering IF you have remote steering.
If you have a motorwell, drill a drain hole through the transom in each corner.
2. The plans show a limber hole in the middle bottom of each frame and you need a drain plug in the transom.
This boat is like a big paddle board, she will float even with the small cockpit filled with water. If you want, you can cut drain holes in the rear corners of the cockpit. She will drain at rest, with nobody in the boat. With one person onboard, the cockpit should drain: the displacement at the designed waterline is 610 lbs but there is a 120 lbs safety margin built-in. That means water will reach the level of the top of the sole at 730 lbs total weight. That could be enough for two persons and reasonable engine and gear.
It is a small boat and we are faced with the usual choice: raise to sole and reduce the stability or get a stable safe boat that may not drain when overloaded. If you want to drain, use scuppers that can be plugged.
Re: Jeffs FS14 LS
Posted: Fri Nov 01, 2019 9:33 pm
by seaslug
Hi Jeff, thanks for the compliments on my build, and welcome to the group. You've already built a beautiful drift boat, so the FS14 will be a breeze. My personal belief with these smallish flats skiffs is a fairly simple build with no wet bilge and minimum accessories. Tiller motor, running lights, a few switches for whatever, and that's about it. If you have properly built hatches with deep gutters and adequate drains, below deck stays completely dry, so no need for a wet moldy bilge. This design is self bailing at rest, so a drain plug in the cockpit, with a hose or pipe exiting the lowest point you can drill in the transom, and that's all you need. I've only been caught out in a heavy rain once in my FS18 while poling a shallow flat, so a little water was in the cockpit until I was deep enough to run the outboard. Even if the cockpit filled entirely the boat would stay afloat, and you could always use a bailing bucket or hand pump in that situation. As long as your transom is a few inches higher than the aft deck there is no need for a motor well either. The low sheer version finishes out at just under 14 feet, with a 58-60" beam. It should fly with a 20, and I think it could be a fun little skiff with just enough room for 2 anglers, 1 poling, and 1 fishing on the bow. 9 foot fly rods could be a challenge, not sure if there's enough boat length for storing in rod tubes. You might have to break them down, or store them on deck. Have to go for now. Nice group of guys willing to help out with advice here on the forum, so don't be shy, ask as many questions as needed for a successful build. Mike
Re: Jeffs FS14 LS
Posted: Sun Nov 03, 2019 11:57 am
by Fair WX Pilot
Hi Jeff, looking forward to following your build. You’re boat looks great by the way. I don’t know if you have ordered your ply yet but Goosebay Sawmill and Lumber is a marine lumber yard in Concord NH and stocks Meranti and Okoumi. It’s closer to you and you won’t have any Massachusetts sales tax to pay.
Re: Jeffs FS14 LS
Posted: Sun Nov 03, 2019 2:48 pm
by VT_Jeff
Alan, great suggestion, will check them out! Boulter in Medford has been great but good to have options and pay less tax, for sure!
Mike, Thanks so much for the info. Glad you like the drifter.
Regarding hatches, I spent quite a while studying photos of your gold-standard hatches as well as some other peoples and at the end of it, I decided that simple, "wet" hatches that are strapped down(no hinges hardware is my current thought) and a wet (and moldy) bilge with a bilge pump would be the simplest way to go. I made some sketches of hatches like yours but my thought was to build the gutters from 3 pieces instead of routing them from a single piece to cut down on the labor. Will not easily allow for the nice curves/shapes you got and I can't decide if they my be problematic carrying the loads they need to. I'll continue considering it but at the moment I think I'm leaning towards the dead-simple wet ones and deal with the mold as I do on my other boats.
Jacques, 10-4 on the motor well/self-bail considerations, thank you.
Unless convinced otherwise, I'm going to upsize the boat 10%, (66" is literally the max I can get through my basement slider, which is perfect)and my thought is to change the stringers from 6mm to 9mm unless it's deemed unneccessary. Plan is to double the transom for the heavy 4-stroke. I read on another thread someone say that the frames did not need to be increased, not sure I understand this. I'm going to scale everything except the thicknesses of the ply and the height of the transom. Occurred to me that scaling the lofting stations from 12" to 13.2" inches would be the simplest way to loft the scaled curves. Also have an autocad resource who can just scale the plans/remeasure for me if required, though I THINK I have a handle on it, time will tell.
Thanks again,
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 8:54 am
by pee wee
On the subject of dry vs. wet storage, one approach is to assume water will get in, and allow for it to get out via drain holes. You can further simplify things by doing away with hatches entirely, and cut access holes in the bulkhead, maybe use netting to contain the contents. Good ventilation and drainage should minimize mold growth; your build will be faster and simpler, and the weight is (hopefully) kept down. When Jacques is calculating hull weight for a design, he typically does not assume hatches, so most of us go over the weight shown in the study plans.
It does seem that without going to great pains, compartments will leak (sometimes they still do). The builder's goal is to figure out how to deal with that fact.
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 9:49 am
Scale everything by the same factor in CAD. It's easy and safe.
No need to increase the hull skin thickness but OK to go up one notch with the stringers.
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 11:00 am
by VT_Jeff
Hank, thanks for the thoughts. I am seriously considering your idea as well: no hatches at all, just access through the bulkheads. All three options are on the table at the moment: No hatches, wet hatches, and SeaSlug hatches, which I'm slowly gaining confidence about building as I think it through it more. My router experience/skill/confidence is limited but I'm thinking I can channel the members ahead of time on my table saw with a to-width dado blade, eliminate the drill press/rough routing, leaving me with just a flush-trim operation to get the cut edges of the hatch opening flush with the gutter sides. The inner lip would not penetrate the bottom of the hatch lid as Mikes do, so not quite as water-proof. Also thinking about some lightweight gutters if I can figure out how to make them work and still carry the load of someone standing on the hatch. My guess is that Mikes gutters are designed to support the load on the inside lip, which is why they need to be so beefy.
Jacques, thanks for the confirmation on the upsize, appreciate it! I suspect that when I re-nest, it will be possible to get the stringers out of the extra 9mm sheet.
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 11:42 am
by joe2700
Fair WX Pilot wrote: ↑Sun Nov 03, 2019 11:57 am
This probably doesn't matter in NH or VT but in MA when I register the boat I need to show I paid sales tax on the materials to avoid paying sales tax on the whole boat. The plywood(from Boulter) and the motor purchased locally are the main things I'm going to show for that.
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 12:18 pm
by VT_Jeff
joe2700 wrote: ↑Mon Nov 04, 2019 11:42 am
Interesting. When I registered my driftboat in VT, I showed them my receipts and paid tax on the total of the receipts I showed, I did not consider the fact that I had already paid tax on those materials, that's an excellent point! Why should I pay taxes on a boat that I built with materials on which the tax was already paid? I'll pay more attention next time, thanks for the heads up!
Re: Jeffs FS14 LS
Posted: Mon Nov 04, 2019 10:26 pm
by Fair WX Pilot
VT_Jeff wrote: ↑Mon Nov 04, 2019 12:18 pm
Just goes to show that every state is different. My GV10 cost $25 to register which was the processing fee and they hardly looked at the receipts.
Re: Jeffs FS14 LS
Posted: Thu Nov 07, 2019 9:38 am
by VT_Jeff
Alan,
I was about to make a circular saw guide when I came across yours in your build thread, looks like exactly what I want. Any updated thoughts/recommendations?
Thanks,
jeff
Re: Jeffs FS14 LS
Posted: Fri Nov 08, 2019 1:38 pm
by Fair WX Pilot
Hi Jeff, mine could do with being a little wider on the safe side of the fence to make it easier to clamp down. The motor on my Dewalt hangs out a fair way and sometimes interferes with the cut by catching on a clamp . It’s not a big deal, just annoying. I made it from an offcut so not much choice when I put it together. Certainly have used it a lot though.
Re: Jeffs FS14 LS
Posted: Sun Nov 10, 2019 5:58 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Fri Nov 08, 2019 1:38 pm
Thanks Alan.
I put about 6" on the safe side on mine and it seems to work well, I've been using weights(rubber-coated barbells) on the safe side instead of clamps so far and it works really well. I used some HD fiber board that has a smooth side and a rough side(partly your suggestion and partly what I happened to have lying around). The rough side sticks to the object piece quite well, no slippage, and I'm not running around the table clamping between cuts.
I have a question on the order of operations. Most builds I see at least fair/prime the bottom before starting the inside. I'd prefer to put off all sanding/fairing/priming/painting until early summer when I can move from the basement to the garage. Any reason I can't flip the boat after glassing the bottom and work on the inside/decks/hatches/etc until it's warm here?
Thanks,
Re: Jeffs FS14 LS
Posted: Sun Nov 10, 2019 6:15 pm
by Fuzz
All it means is a couple extra flips. With a smaller boat I do not see it as being any big deal.
Re: Jeffs FS14 LS
Posted: Sun Nov 10, 2019 8:24 pm
by VT_Jeff
Thanks for the confirmation Fuzz. A few extra flips doesn't concern me.
Quesiton 5/10,000+:
Is the deck intended to rest on top of the sheer or be flush with the top of the sheer? I read somewhere that the deck should not be cut ahead of time, wait until the hull and frames are done, put the deck panels on top and trace the sheer onto the underside of the deck panels. I think this would imply that the deck sits on top of the sheer. If that's the case, it would either a) be proud of the gunwale height or b) need to extend out to the outer edge of the gunwale, covering it. Maybe this will be clearer to me once I see where the frames line up with the top of the sheer but for the moment, I can't envision how these will all fit together.
Thanks again (and again)
jeff
Re: Jeffs FS14 LS
Posted: Mon Nov 11, 2019 8:15 am
by VT_Jeff
Part 2 to that question above about how the deck joins the sheer: the sheer is not vertical, so when I add the rubrail, it will also not be vertical on the sides/horizontal on the top. So if I laid the deck on top of the hull with the rub rail on it. the horizontal deck would not join the top of the rub rail flush, there would be a wedge-gap. Do I plane the top of the rub rail horizontal before laying/tracing the deck and extend it out to the edge of the rub-rail? Or just fill the gap with fillet blend? My last boat did not have a deck at the sheer so the question never came up.
Re: Jeffs FS14 LS
Posted: Mon Nov 11, 2019 1:20 pm
Page 5/12 of the building notes explains it;
We show the deck extending over the sides and epoxy welded to a rubrail. That rubrail acts as a spray rail.
Some builders may prefer to install a sheer clamp (= a batten on the inside), it is optional, either method is fine.
The deck is in one plane, flat.
The construction drawing shows the rubrail and an optional sheer clamp which is a batten running along the inside edge of the sheer.
The preferred construction method is to drop the deck on top of the rubrail and sheer clamp. You can skip the sheer clamp and glue only to the rubrail but the 1st method makes a stronger edge.
Re: Jeffs FS14 LS
Posted: Mon Nov 11, 2019 6:36 pm
by VT_Jeff
Thanks Jacques.
The horrible drawing attached shows an exaggerated version of what I was referring to, but I'm guessing the "gap" will be too small to be concerned with and will get filled when i weld the deck on.
Re: Jeffs FS14 LS
Posted: Mon Nov 11, 2019 7:00 pm
by VT_Jeff
Easy one: Do butt blocks need to be of the same thickness as the pieces being joined?
Re: Jeffs FS14 LS
Posted: Tue Nov 12, 2019 9:59 am
by Dougster
If memory serves me right, I dealt with that gap on the LB22 by planing it flat. I used a power plane and it took no time at all. Filling it with goop before glassing over it seems good too..
Dougster
Re: Jeffs FS14 LS
Posted: Tue Nov 12, 2019 10:45 am
by VT_Jeff
Dougster wrote: ↑Tue Nov 12, 2019 9:59 am
Dougster
Appreciate the info, Dougster, I'll plan on that approach.
Re: Jeffs FS14 LS
Posted: Fri Nov 15, 2019 5:32 pm
by VT_Jeff
I just came across a post
https://forums.bateau2.com/viewtopic.ph ... &start=460 by capt UB that addresses the same question I was asking about the gap between the deck and rubrail/sheer clamp.
His illustration is a lot better than mine, used without permission:
He is using a sheer clamp where I'm going to only use a rubrail, but the geometry is the same. I still think I'm going to add the rubrail proud of the sheer and plane it horizontal to avoid the need to fill the gap with goop. Good to see alternatives in action though.
Re: Jeffs FS14 LS
Posted: Sun Nov 17, 2019 8:49 pm
by VT_Jeff
Starting over with this post, learning the ways of photo attachments......
Re: Jeffs FS14 LS
Posted: Sun Nov 17, 2019 8:54 pm
by VT_Jeff
I have a lot of work to do figuring out how to efficiently post photos. Embedded photos from google drive dont appear to work, could not find any posts related to it. This leaves manually uploading via the add files button, which is tricky from my phone. Any input appreciated.
Re: Jeffs FS14 LS
Posted: Sun Nov 17, 2019 9:17 pm
by Jaysen
Use the gallery here then just use the BBCode to include in a post.
Re: Jeffs FS14 LS
Posted: Sun Nov 17, 2019 9:56 pm
by VT_Jeff
I'll try that approach Jaysen, thanks.
Re: Jeffs FS14 LS
Posted: Sun Nov 17, 2019 11:28 pm
by Fair WX Pilot
Looks great, bet it feels good to be past the planning and into the building.
Re: Jeffs FS14 LS
Posted: Mon Nov 18, 2019 8:21 am
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Nov 18, 2019 8:23 am
by Jeff
Really nice progress is what I had intended to say!!! I will check on your kit (UPS) shortly and give you a call!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Nov 18, 2019 8:45 am
by VT_Jeff
Thanks Alan/Jeff, appreciate it! Definitely nice to have some momentum going!
Re: Jeffs FS14 LS
Posted: Tue Nov 19, 2019 2:32 pm
by VT_Jeff
Ok, take two on progress report:
I picked up the plywood at Boulter Plywood in Medford. I had to have it trimmed from 98.5 to 96 inches to fir in the Sienna. Chris at Boulter helped me out getting it ready before I got there so I could load and go.
I had the jig pretty much ready to roll before I picked up the plywood. I may need to add wheels and I may need to lower it. I added some storage space underneath that will probably also need to be removed so I can stick my wife under there to help with the stitches.
Thanks to Alan (Fair Wx Pilot) for his saw guide idea. Mine is made from 1/4" fiberboard and some fir I had, 8' long. Next time I'll use thicker MDF, maybe 3/8, and glue sandpaper to the bottom to prevent it from sliding during cuts since I normally use weights instead of clamps. This Rockwell saw makes cutting very easy and accurate, I usually guide it along with my left hand fingers on the saw "table".
Once I got the frames cut and the stringers cut and glued up, I put the rest of the jig together, using a laser level to keep things square. I know JM says it's a self-aligning jig and for the uber-confident, I'm sure it is. For me, it's a very manual aligning jig, but the laser makes it much faster.
After cutting out all the frames, I got the transom laid up. I used 2 pieces of 9mm plus a 9mm clamp. I'm going to be using a Honda 20hp 4-stroke so figured I'd go beefy on the transom. I pre-wet all mating faces with epoxy and glued with epoxy thickened with fillet blend.
I cut grooves for the stringers on the inside piece of the transom instead of cutting the stringers short. I saw others do this, and saw where some others weren't so keen on the idea. It made mounting the transom to the jig really easy, and should make installing the stringers easy, but will require some amount of hassle while glassing the inside to ensure the grooves remain clean.
I used dowels to keep the pieces aligned while gluing.
Once cured, I cleaned up the squeeze-out with a block plane. I should have cleaned this up before it cured, this is a lesson I seem to have trouble learning.
I added a jack to the transom to keep it's weight off the stringers. The stringers were upsized to 9mm from the plan spec of 6mm but they were still pretty wobbly with the hefty transom.
For the bow mold, I used some offset stabilizers to keep it centered, which have already paid off as I bump it about every time I walk around the bow.
When I glued up one of the stringers I didn't get it completely straight so it rises from Frame B to the bow, I'll need to fill the gap with some TE wen i install the stringer, and it made it a little tricky getting the stringer to sit correctly on the jig.
Here's the finished jig:
I didn't follow the correct nesting for the stringers so the butt blocks ended p in the middle of Frame B I had to double-wide the notch in that frame to accomodate them, and the notches in the stringer went through the butt blocks:
I got the hull panels cut out pretty quickly and threw them on the jig for a dryfit, they seem to fit quite well, the truth will be revealed when I actually start pulling the stitches tight at the bow.
Next step is to figure out where I'm going to get the wood for the rub rail, I have SOME leftover 6mm since the stringers moved to the extra of 9mm I had to buy, we'll see if it's enough. I read someone's nightmare tale of trying to piece together scraps so will look to avoid that. Since the sheer is not straight on this design that the rubrail idealy needs to be cut to follow the curve of the sheer, that's going to be my plan, we'll see how it goes.
The Epoxy/glass kit arrives tomorrow night(Wed) after which I can join the hull panels and start stitching. need to remember to trace the sheer for the rubrail before hanging the sides.
Re: Jeffs FS14 LS
Posted: Tue Nov 19, 2019 3:19 pm
by Jeff
Really nice prohgress Jeff!!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 10:35 am
by VT_Jeff
Thanks Jeff!
Got the rubrails cut out last night.
I up-sized this boat 10%, as I've mentioned, and decided to up-size the thickness of the stringers from 6mm to to 9mm. In order to do that I needed to buy an extra sheet of 9mm. Moving the stringers to the new 9mm sheet left some extra space on the 6mm hull panel sheets, just enough to get these 4 rubrails. If I had not up-sized/moved the stringers, I would have had to buy an extra sheet of 6mm for the rubrails, or else pieced them together from scraps, which I've heard is a bit of a goose chase. So my .02 is that if you're going to build the FS14LS at planned dimensions, buy an extra sheet of 6mm(5 instead of 4). I'd be interested in hearing any other opinions on it.
I took one of the sides and traced the sheer line onto my rubrail material. I made this marker to scribe the other side at 1.5", cut out the piece, then used it as a template to trace the other three. I offset the splice on 1 pair by as much as i could, there is not a lot of extra room as these rubrails are close to 16 feet.
Some wobbly cuts here, it'll buff out.
anti-warpage defense till they're needed
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 10:40 am
by Jeff
Good planning and nice work!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 1:46 pm
by Fair WX Pilot
Looks great, can’t wait to see it stitched together.
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 2:21 pm
by VT_Jeff
Early Christmas present.
Thanks again Jeff Morrow for turning that around so quickly!
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 2:29 pm
by Jeff
Thank you for your business Jeff!!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 2:39 pm
by VT_Jeff
Quite welcome.
Finally finished the seat/battery box and oar risers for the driftboat, may be a little while before they get installed.
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 2:44 pm
by Jeff
Good looking pup!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 3:04 pm
by VT_Jeff
Thanks Jeff, that's Brook. She's getting on in years(14+) but still doing very well. She was a rescue from Puerto Rico, we got her at about 8 weeks old. She's a mutts' mutt, little bit of everything in her.
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 3:14 pm
by Jeff
Wow Jeff, We have a rescue from Puerto Rico. He was an abused dog there and a local Florida rescue brought him over at about 1 year old. His name is Thor and he is nearly 14 himself!!! Crazy stuff!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 6:20 pm
by Fair WX Pilot
Well, I hate to comment on how much I like your workmanship on the drift boat with all this talk of aging four legged workshop supervisors. I have a 14+ helper as well so totally get what you’re both talking about.
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 6:39 pm
by VT_Jeff
Jeff wrote: ↑Wed Nov 20, 2019 3:14 pm
That's awesome Jeff. Maybe they will meet when we come down in March/April, they may be long lost relatives!
Re: Jeffs FS14 LS
Posted: Wed Nov 20, 2019 6:41 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Wed Nov 20, 2019 6:20 pm
I'm jealous, Alan. Brook won't come near the workshop, she was in the photo because I dry stuff near the woodstove in the family room, too cheap to get the basement warm enough!
Re: Jeffs FS14 LS
Posted: Thu Nov 21, 2019 5:34 am
by Eric1
Your build looks really nice! Great workmanship!!
Re: Jeffs FS14 LS
Posted: Thu Nov 21, 2019 8:49 am
by pee wee
VT_Jeff wrote: ↑Wed Nov 20, 2019 3:04 pm
I can tell by looking at her she's a purebred Curb Setter!
Re: Jeffs FS14 LS
Posted: Thu Nov 21, 2019 12:54 pm
by VT_Jeff
pee wee wrote: ↑Thu Nov 21, 2019 8:49 am
Curb Setter.
Re: Jeffs FS14 LS
Posted: Thu Nov 21, 2019 1:08 pm
by VT_Jeff
Eric1 wrote: ↑Thu Nov 21, 2019 5:34 am
Appreciate it Eric, yours as well, quite impressive!
Not sure if you already have an idea for the sole but I used this trick to create a template for the floor of my driftboat: I rought-cut a piece of fiberboard that was within an inch or two all the way around and then taped posterboard 'cards all the way around to the edge, which gave me a super-easy way to get a very accurate template. occurred to me after that a few decks of cheap playing cards would have been easier than cutting up all the poster board.
I liked your use of the marker-on-the-level to mark the line, btw, I cheated and used a laser-level.
Re: Jeffs FS14 LS
Posted: Thu Nov 21, 2019 2:23 pm
by Eric1
VT_Jeff wrote: ↑Thu Nov 21, 2019 1:08 pm
Nah that ain't cheating. I would've used mine but Between it and my big butt I figured it was gonna be a PITA.
Re: Jeffs FS14 LS
Posted: Tue Nov 26, 2019 9:06 am
by VT_Jeff
Eric1 wrote: ↑Thu Nov 21, 2019 2:23 pm
[Nah that ain't cheating. I would've used mine but Between it and my big butt I figured it was gonna be a PITA.
Nice!
I started gluing up my long panels. Wasn't sure how much of a gap to use, I ended up using a 3/8 washer as a spacer, seems to look about right. This is my first experience with Gel-magic and bi-axial tape so I've been moving slow and trying to get things right. I ordered slow hardener because my goal is to do the whole hull wet-on-wet, this may mean some extended wait times for the glassing table. I'm trying to speed up the cure with some lamps and insulation board. At this point I can probably move these panels on top of the jig to finish curing and start gluing up the other panels. The gel-magic seems to be pretty hard/holding the panels together, the resins is still pretty tacky.
Re: Jeffs FS14 LS
Posted: Wed Dec 04, 2019 4:51 pm
by VT_Jeff
Eric, I was just looking through some of your food photos. I am now starving and completely understand your big butt comment, I'd weigh 300 lbs with that delicous stuff lying around! When most people say "I've been doing some baking" they mean cookies or a pie, you go straight to artisanal breads. I guess when most people say they are building a boat they mean a rowboat or a dinghy, you go straight to a serious, beautiful 21' skiff! Super impressed, keep up the great work, on all fronts!
Re: Jeffs FS14 LS
Posted: Wed Dec 04, 2019 6:52 pm
by Eric1
VT_Jeff wrote: ↑Wed Dec 04, 2019 4:51 pm
Wow! Thanks For those kind words. I'm holding steady at 204 but Doc say I should weigh 165.
What does he know? LOL
Re: Jeffs FS14 LS
Posted: Mon Dec 16, 2019 10:30 am
by VT_Jeff
On Sat we glassed the bottom, went pretty well. Here were my complete steps for the hull:
Panel assembly:
1. Stitched panels together. Did my best to "float" them, get them fair and avoid pinching. Used nails to maintain a gap and pvc pipe for alignment.
2. Taped the gaps on the inside with blue painters tape
3. Used an epoxy syringe to fill the gap with Gel-magic. Instead of spot-welding, I got as close to the stitches as I could. On the transom, there was a natural gap on the inside but the outside edges were flush, so I used the syringe to fill the gap on the inside.
4. Allowed welds to cure overnight, removed stitches, completed taping gaps inside with blue tape where the stitches were
5. Filled in the welds where the stitches were, Allowed that to cure for a few days
6. Used a block plane to radius all edges to at least 1/2" radius. This resulted in removing some wood from the edges. I'm not sure I understand how other people can get a good radius just by adding thickened epoxy to the outside of the joint, but I read about people doing it all the time so I assume it works.
7. Sanded the radius all the way around with 80 to ensure that the glass/epoxy would bond(secondarily) to the cured Gel-magic.
Hull Glassing:
1. Measured and cut all tape and fabric a few days ahead of time and put guide-lines on the hull with a sharpie. The sharpie was a mistake as the ink ran when we applied the epoxy, lesson learned.
2. Got the shop warmed up to 65 and turned the crockpot on low to get the epoxy warm.
- ready for glassing, I taped off the rub-rail area so I can glue the rub-railto bare wood as much as possible
3. Pre-wet the transom seams, the keel and the chines
4. Laid the tape on the transom seams, the keel and the chines, did not wait at all once pre-wetting was done
5. Wet out all the tape
6. Pre-wet the rest of the hull and transom
7. Rolled on the fabric (from cardboard tubes) and wet it out
With Elaine and I, it took a solid 4 hours from start to finish, which felt like about 15 minutes, could not believe it when we looked at the clock. We used slow hardener and never felt like we were getting behind, everything stayed greasy as desired.
The guidelines we drew on the hull, outside of the fact that the sharpie ran and will surely cause the boat to sink the moment it gets wet, worked great, made it really easy to get the tape and the fabric in the right place on the first try, or at least close. Working on greasy epoxy instead of tacky epoxy also made it possible to make small adjustments, if I had gone with my original plan of letting it get tacky, we probably would have gotten in trouble.
It all went pretty smoothly so not a ton of other lessons learned. We used bondo spatulas and glue brushes. When I do the inside I'll get some epoxy rollers to make it a little easier to get the air bubbles out. Fallguys recommendation to wet out the layers individually was spot on; if we had gone with my plan of laying all the glass down and the wetting out the layers together, we would have ended up, I suspect, with a lot more air and a lot more work. As it was, the areas with 3 or more layers of glass ended up a little milky but not too bad in my completely amateur estimation. Efforts to get them any clearer usually resulted in upsetting the glass layers so we figured best to leave them.
Last night I put another coat of raw epoxy on just the bottom and hit the sides with quick fair to start filling in the weave. System 3 gives a theoretical 72 hour re-coat window, my goal is to keep it under 48 hours and get the weave completely filled in the next day or 2. I used quick fair on the sides because it doesn't sag and I figured it would be easier than dealing with dripping epoxy, which was true, but it's a lot more work to mix and apply. What I thought was going to be a quick 1 hour job last night turned into a 4 hour job by the time I got it done.
I'll add some photos, there are some in my gallery now of the hull assembly etc, need to upload the rest.
Thanks again Jacques and Fallguy for the input!
Re: Jeffs FS14 LS
Posted: Mon Dec 16, 2019 10:57 am
by Jeff
Nice progress Jeff!!! What are your temps up there? Jeff
Re: Jeffs FS14 LS
Posted: Mon Dec 16, 2019 11:53 am
by VT_Jeff
Jeff wrote: ↑Mon Dec 16, 2019 10:57 am
Thanks jeff.
Sat was 32-34 outdoors, today it's back down to.....20s?
My basement has electric baseboard heat, I expect the bill will be a decent line item in my final build cost.
Re: Jeffs FS14 LS
Posted: Mon Dec 16, 2019 12:00 pm
by Jeff
OK, that is cold!!! At least you have a heated work space!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Dec 16, 2019 12:54 pm
by VT_Jeff
Jeff wrote: ↑Mon Dec 16, 2019 12:00 pm
You said it! Not sure I'd be able to do this in the winter up here otherwise. Mad respect to those guys working in garages with a kerosene heater in cold weather climates, I have it easy!
Re: Jeffs FS14 LS
Posted: Sun Dec 29, 2019 7:54 pm
by RiggsWNC
What temp you reckon your basement sits at when your working with the slow hardener? I can get the shop to about 60 when it’s freezing or below and want to try the slow hardener, the med and fast is kicking fast.
I feel you on the heat bill. I have a separate electric service for where I work and it’s typically less then twenty bucks a month. Bet it’ll be over a hundred while I’m building.
Re: Jeffs FS14 LS
Posted: Sun Dec 29, 2019 8:44 pm
by VT_Jeff
RiggsWNC wrote: ↑Sun Dec 29, 2019 7:54 pm
60-65 is typical, rarely higher. I went with slow so I could glass wet on wet, so far so good, probably more time spent waiting than others may like. The quikfair, I think, is single speed, no issues yet using it in the same temps.
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 1:11 am
by Fuzz
I work in 60 degree temp all the time. I have used a lot of both fast and slow. When I glass I plan on not being able to do anything with it until the next day. The fast is always good to go. The slow is still just short of sand ready the next day sometimes. I like slow for the no blush and long working time. One problem with slow is you can get some drain out if you are not careful.
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 8:11 am
by RiggsWNC
Fuzz, what’s drain out and how is it prevented?
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 11:13 am
by VT_Jeff
RiggsWNC wrote: ↑Mon Dec 30, 2019 8:11 am
Ditto!
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 11:19 am
by VT_Jeff
Fuzz wrote: ↑Mon Dec 30, 2019 1:11 am
I try to wait a week, which may seem insane, but I learned on my last boat that sanding week-long cured epoxy was a "joy" compared to sanding epoxy that had only cured for a day or two. This was why I was so intent on glassing wet-on-wet, to avoid the need to sand between and wait long periods between steps. This worked well on the hull bottom, we'll see how it goes on the inside where there are a lot more steps involved to get the bilge/seams glassed, get the stringers and the frames all in wet-on-wet. May be undoable.
QuickFair I sand a day later, no issues there.
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 12:40 pm
by Fuzz
VT_Jeff wrote: ↑Mon Dec 30, 2019 11:13 am
Ditto!
Slow can take so long to gel that it can drip/run out of the glass especially on vertical surfaces. You can add a little thickening agent if needed. I only thicken things up after my glass is mostly wet out. This is only a problem if you have a long gel time.
Re: Jeffs FS14 LS
Posted: Mon Dec 30, 2019 3:36 pm
by VT_Jeff
Fuzz wrote: ↑Mon Dec 30, 2019 12:40 pm
Ditto!
Interesting. I have tried to hang around long enough to catch drips on the verticals but inevitably miss some, maybe this is why. Great info Fuzz, thanks.
Re: Jeffs FS14 LS
Posted: Wed Jan 08, 2020 3:51 pm
by VT_Jeff
Sanding just got a lot easier!
Re: Jeffs FS14 LS
Posted: Wed Jan 08, 2020 3:53 pm
by VT_Jeff
I think I'm dealing with more reverse rocker than hook: if I use a shorter straight edge, there is little to no hook towards the stern:
Re: Jeffs FS14 LS
Posted: Wed Jan 08, 2020 7:41 pm
by Dan_Smullen
I love the sanding rig. Seems legit...
What is reverse rocker? From the pic, this seems like good news.
Re: Jeffs FS14 LS
Posted: Wed Jan 08, 2020 10:40 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Jan 08, 2020 7:41 pm
Reverse rocker is just hook spread over a longer distance. The rear panels are pretty flat in that area as shown in the photo. The keel itself has a bit of hook/reverse rocker over the 4 feet. May be that my D frame was low or that I jacked the transom up too much when I used the 2X6 jack to keep it from sagging, may have err'd in other direction. I'm sure the performance-minded would add layers of glass etc to get it flat but I'm not going to bother with it, it's fairly slight and I can't believe I'll notice on anything but pure glass, time will tell. At hundreds of dollars/gallon for epoxy, $50/quart of fairing compound, and already having bought twice the design qty, I need to pick my targets carefully. This ain't one.
Re: Jeffs FS14 LS
Posted: Thu Jan 09, 2020 8:21 am
by Dan_Smullen
I like the way you think.
Build on!
Re: Jeffs FS14 LS
Posted: Thu Jan 09, 2020 8:22 am
by Jeff
Agree!!! Jeff
Re: Jeffs FS14 LS
Posted: Thu Jan 09, 2020 2:56 pm
by VT_Jeff
Jeff wrote: ↑Thu Jan 09, 2020 8:22 amAgree!!! Jeff
Thanks Jeff
I saw the Bateau spread in the latest issue of Small Boats, great exposure!
Re: Jeffs FS14 LS
Posted: Thu Jan 09, 2020 4:44 pm
by Jeff
Yes, they do a great job!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sat Jan 11, 2020 4:41 pm
by VT_Jeff
Warm temps made for a nice day of not-boat-building down the street in western ma, deerfield river.
Re: Jeffs FS14 LS
Posted: Sun Jan 12, 2020 9:04 pm
by PapaDave
Hi Jeff,
Nice looking fish. It was a nice warm weekend. Good luck with the boat. Looking great!
Dave
Re: Jeffs FS14 LS
Posted: Mon Jan 13, 2020 9:18 am
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Jan 13, 2020 4:08 pm
by VT_Jeff
PapaDave wrote: ↑Sun Jan 12, 2020 9:04 pm
Hi Jeff,
Dave
Jeff wrote: ↑Mon Jan 13, 2020 9:18 amNice!!! Jeff
Thanks. I "cheated" and used an egg pattern under an indicator(aka bobber) which I basically just let drift around an eddy until this fish bit. Not exactly purist-level fly-fishing, but in January in western mass, 20-30 mph winds right in the face, it was about the only bearable way to fish.
Re: Jeffs FS14 LS
Posted: Tue Jan 14, 2020 7:28 am
by Jeff
That is some tough fishing Jeff!!! Jeff
SUP/Driftboat fishing in Homosassa
Posted: Thu Mar 05, 2020 7:53 am
by VT_Jeff
As I threatened in my first post, wife and I are headed to Homosassa in a few weeks to get our feet wet fishing in Fla. The FS14LS is still about a year from completion(I'm in the middle of putting the rubrails on and fixing the mess I made trying to square the edges on the aft chines/transom edge, more on that later). We're bringing the driftboat I built last year and some SUP's. Wife works for a SUP company and she'll be doing some product testing while we're down there.
From the maps I've seen, appears we'll mostly be in mangroves, looks like any flats are a fair distance from town for a driftboat or a SUP. If anyone has any info they'd be willing to share I'm all ears. We're treating this as a scouting mission so no real agenda beyond escaping mud season for a few weeks, trying to hook a few fish on a fly line and gaining some knowledge on flyfishing saltwater and the area. Next year and beyond we'll hopefully be bringing the FS14LS and get more into true flats fishing, start the learning process over again.
Thanks,
Re: Jeffs FS14 LS
Posted: Thu Mar 05, 2020 9:18 am
by VT_Jeff
Quick update:
I got it into my head that sharp chines, like the cool kids have, would be awesome. And I wanted to slow the build down a bit for budgetary reasons. I put packing tape on a 4' piece of scrap, clamped it to the side, then poured some slurry into the gap. The slurry was too thick and did not get into the crack well enough, and then I pulled the scrap off the transom too early and basically wrecked that one. So just when I thought I was done fairing I gave myself plenty more to do, which achieved my goal of slowing the build down, so maybe not not all was lost. I will say that I think clamping the form on worked fine, I don't think it's neccessry(IMOVHO) to drill/screw the form on.
I got most of the rubrails put on, I have 2 more strips to go out of 8. I used a pretty simple method. For the inner strips, I clamped it on, adjusted, traced it onto the hull, applied GelMagic, and then clamped it in place, one strip at a time. Then I just glued the outer strips to the inner strips, again one strip at a time. It took some time but was easy, no guide holes/dowels were needed/used, I'm generally happy with the alignment. The strips were not cut perfectly to begin with so the alignment was not going to be perfect regardless.
Once I'm done with the rubrails and fixing my sharp chine F-ups, I'll be coating the bottom with expoy/graphite, then will need to order some primer and prime the sides. We are now in full prep-mode for a month-long road trip so I don't expect too much more progress in the short-term.
Re: Jeffs FS14 LS
Posted: Thu Mar 05, 2020 9:22 am
by Jeff
Nice work VT_Jeff!!! She is really looking good!! I hope you guys enjoy your trip. I don't know that area for fishing but I am confident the locals will guide you in the right direction. You guys enjoy the Florida sun and catch some fish!!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 12:56 pm
by VT_Jeff
So, I got the hull painted. Super un-happy with how it turned out, unfortunately.
I used oyster white and largo blue, the oyster white is way too beige for my taste but it was hard to determine that until I could see it altogether. I also used what I thought would be a cool design but once the masking tape came off, it was not very cool. It was not cool at all. So I'm going to re-do the oyster white in pure white and I'm going to wrap the blue all the way around the transom instead of having the the border at the back of the sides and the sides of the transom. Also, there are some areas where the blue shines and looks great and others where it looks flat and not very good, so that will need some re-work as well.
In the transom photo, I lit it from the floor and flipped the photo upside down to try to give an idea what it will look like right-side up.
This is a mock-up with paint.exe showing a vast improvement in the graphic:
This photo was with the lighting overhead so it looks a little weird. I'm not unhappy with the design on the bow and am going to leave it as is(except the color)
The good news is that each time I paint a coat I need to wait 3-4 days for it to dry enough to scuff effectively, so I can probably eat up the rest of the summer fixing this. So at least I have something to do! First-world problems, I'll take em!
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 2:02 pm
by Fuzz
You might be unhappy but it looks good in the pictures
Remember we are own worst critics.
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 2:13 pm
by Jeff
I agree with Fuzz, I think it looks good!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 3:05 pm
by BB Sig
I've had the same thoughts about oyster white.
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 3:27 pm
by VT_Jeff
Fuzz wrote: ↑Wed Jul 08, 2020 2:02 pm
You must not be married!
Thanks Fuzz.
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 3:29 pm
by VT_Jeff
BB Sig wrote: ↑Wed Jul 08, 2020 3:05 pm
I think if the whole boat was going to be a solid color with some bright-finished wood, the Oyster white would work ok or maybe it would be great. But in this scenario, yeah, too beige/yellow. Esp when my plan is to do the deck non-skid in light grey, I think only pure white makes sense. Hindsight!
Re: Jeffs FS14 LS
Posted: Wed Jul 08, 2020 3:30 pm
by VT_Jeff
Jeff wrote: ↑Wed Jul 08, 2020 2:13 pm
Appreciate it as always Jeff!
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 10:04 am
by VT_Jeff
Made the decision to live with the oyster white and move on. After reading a few other painting nightmare stories on here and struggling mightily with it myself, figured it was best not to tempt fate. My nephew helped me flip it so now it's on to glass the inside.
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 10:09 am
by Jeff
VT_Jeff, I know you are not completely happy with the paint but I really like the look. Quite custom!! Jeff
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 10:54 am
by lelandtampa
That boat looks great. If you aren't happy with it set it by the curb I'm on the way.
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 11:19 am
by VT_Jeff
lelandtampa wrote: ↑Fri Jul 17, 2020 10:54 am
It's growing on me but I'll keep the offer in mind!
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 11:23 am
by VT_Jeff
Jeff wrote: ↑Fri Jul 17, 2020 10:09 am
Thanks Jeff. As I said, it's growing on me and the wife thinks it looks fine. Wrapping the blue around the transom made a big difference in the look so I'm happy with that and I'm counting my blessings that it's not coming off in sheets or doing anything else that may make me want to scream. I need to stop looking at photos of seaslugs boat!
Re: Jeffs FS14 LS
Posted: Fri Jul 17, 2020 12:59 pm
by Coach
I think its sharp looking! Build on!
Re: Jeffs FS14 LS
Posted: Mon Jul 20, 2020 12:41 pm
by narfi
Looks are so subjective to the individual. You do what makes you happy
It looks good either way IMO, but the rounded ends gave it a cool unique look.
Re: Jeffs FS14 LS
Posted: Mon Jul 20, 2020 3:37 pm
by VT_Jeff
narfi wrote: ↑Mon Jul 20, 2020 12:41 pm
Appreciate it Narfi, we'll see where it ultimately ends up!
Re: Jeffs FS14 LS
Posted: Mon Jul 20, 2020 5:28 pm
by PapaDave
I think your paint layout looks great. Keep up the good work.
Dave
Re: Jeffs FS14 LS
Posted: Tue Jul 21, 2020 12:59 pm
by VT_Jeff
PapaDave wrote: ↑Mon Jul 20, 2020 5:28 pm
Dave
Appreciate it Dave. I now understand completely why other builders complain about paint jobs that look perfectly fine to me! Proximity effect.
Re: Jeffs FS14 LS
Posted: Mon Jul 27, 2020 9:46 am
by VT_Jeff
Picked up my barely used honda 20hp four stroke. A little shocked at the weight, glad I doubled my transom.
Re: Jeffs FS14 LS
Posted: Mon Jul 27, 2020 10:39 am
by narfi
looks brand new
Re: Jeffs FS14 LS
Posted: Thu Jul 30, 2020 3:14 pm
by Dan_Smullen
Congrats on the flip, Jeff! Paint job looks fast!
Looks like a good place to put it down for a month.
Re: Jeffs FS14 LS
Posted: Sat Aug 01, 2020 8:00 am
by VT_Jeff
Dan_Smullen wrote: ↑Thu Jul 30, 2020 3:14 pm
Thanks. Very interested to see how fast she'll be with the honda 20. As long as it planes with me and the wife I'll be happy, I suspect it will.
Re: Jeffs FS14 LS
Posted: Mon Aug 17, 2020 8:17 pm
by VT_Jeff
Great night on the local pond with my two favorite girls! Brook got to lick 3 nice browns before they got thrown back.
Re: Jeffs FS14 LS
Posted: Tue Aug 18, 2020 1:10 am
by Fuzz
So what did the dog do
Sorry the devil made me ask
Re: Jeffs FS14 LS
Posted: Tue Aug 18, 2020 5:50 am
by VT_Jeff
Fuzz wrote: ↑Tue Aug 18, 2020 1:10 am
Shoulda seen that coming!
Re: Jeffs FS14 LS
Posted: Tue Aug 18, 2020 8:09 am
by Jeff
Beautiful area!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Oct 12, 2020 10:07 pm
by VT_Jeff
That sweet pup a few posts back died a day or two after that trip, she was 14 and had a good number of health issues. Crazy how heartbreaking losing a pet is! We decided to rescue another a few weeks ago, this is 'Bow, as in Rainbow Trout(Last one was Brook Trout).
Hes about 15 weeks and a total handful. When hes good hes great and when hes bad hes demonic, typical pup from what I'm hearing. We love him despite his occasional tantrums and finish-nail teeth.
I made an oar to mark Brookies ashes site and our friends young daughters did the artwork for us, they'd known Brook all their lives.
So the new pup has been taking up an astonishing amount of time but I look at it as a dog building project and hope he floats when I'm done sanding him. I did manage to get my stringers glassed in with the help of my nephew who was visiting to fish the local rivers with us over the weekend. Tough weekend for trout but the stringers came out ok.
Frame fitting is next, between sits, stays, heel, don't eat dogshit, stop chasing the cat, try not to bite my face and other pup training sessions.
Re: Jeffs FS14 LS
Posted: Mon Oct 12, 2020 10:11 pm
by VT_Jeff
P.s. 2020 officially off my christmas card list for good!
Re: Jeffs FS14 LS
Posted: Mon Oct 12, 2020 10:45 pm
by Dan_Smullen
Awesome outlook and sentiment, Jeff. Great metaphor for sure.
I also respect how you leveraged labor out of a nephew who wanted to fish.
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 7:30 am
by Jeff
Jeff, Very sorry to hear about your loss!! Our pets are part of our families and are dearly missed when they leave us!!! Nice oar!! Jeff
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 12:20 pm
by VT_Jeff
Thanks Jeff, she sure was part of the family, with us all day/everyday for 14 years straight!
The oar worked well as a prototype/practice for me to eventually make a new set of oars for my driftboat, it was a lot simpler than I had anticipated.
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 12:24 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Oct 12, 2020 10:45 pm
Absolutely! Luckily he did finally get a "trophy" brookie(14" or so) on a dry on Monday after getting skunked sat and sun. He had more luck without us than with us, go figure!
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 2:33 pm
by PapaDave
Hi Jeff,
Sorry to hear about your dog. Hope that new pup is able to fill the loss a bit. Your boat is looking great.
Dave
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 5:16 pm
by VT_Jeff
PapaDave wrote: ↑Tue Oct 13, 2020 2:33 pm
Hi Jeff,
Dave
Thanks Dave, appreciate it!
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 8:54 pm
by Fair WX Pilot
Hi Jeff, very sorry to hear about your dog. I lost my workshop helper (supervisor) almost a month ago and it is very quiet without him. The new pup looks like pure mischief and energy as all puppies should be.
Re: Jeffs FS14 LS
Posted: Tue Oct 13, 2020 9:46 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Tue Oct 13, 2020 8:54 pm
Thanks Alan and I'm saddened to hear about yours as well, I was jealous that your pup liked to hang around the shop, I would have loved that company in my dank basement! Pure Mischief and energy is spot on, he's perfect by that measure!
Re: Jeffs FS14 LS
Posted: Sat Oct 17, 2020 6:25 pm
by VT_Jeff
Spent the day laying out and prepping frame D. Took some time to decide exactly where the flyrods would store best, space gets tight quick. The large holes at the top of the frame are for the butt ends of the rods, the smaller holes are for the fuel line in one side and electrical on the other. The half circles are the scuppers. Long day just to get a single frame prepped but it also involved a lot of decision making so I'm quite happy with the progress.
Re: Jeffs FS14 LS
Posted: Mon Oct 19, 2020 11:55 am
by Fair WX Pilot
Boat looks great, neat idea for the scuppers.
Re: Jeffs FS14 LS
Posted: Tue Oct 20, 2020 3:11 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Mon Oct 19, 2020 11:55 am
Neat idea for the scuppers.
Thanks Alan! The new pup doesn't like to get his paws wet so I'm doing whatever I can to ensure the cockpit sole will stay as dry as possible.
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:00 pm
by gstanfield
I'll bet that pup is jumping in enjoying the water before long, not worrying a bit about getting his paws wet!
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:17 pm
by VT_Jeff
gstanfield wrote: ↑Fri Oct 30, 2020 6:00 pm
I just got his feet wet, literally, in our local creek yesterday, did not seem to mind at all. He seems like he's gonna be an awesome dog all the way around! Just got his last Lepto booster so we can actually start introducing him to some real water, now that it's 28 degrees!
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:20 pm
by gstanfield
VT_Jeff wrote: ↑Fri Oct 30, 2020 6:17 pm
Great to hear! (not the weather, I'm bummed with winter being here and tired of snow and sub zero temps already.)
Re: Jeffs FS14 LS
by VT_Jeff
My updated plan for poling platform and console. Dan Smullen recommended Fusion 360 for modeling and I am totally addicted! Free for personal use. Took a bit to get the base concepts but really fun/powerful!
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:23 pm
by gstanfield
Looking good, Jeff.
Question for someone unfamiliar with this type of rig. I know the poling platform is to get you higher, obviously, but is it for the purpose of being able to see better down in the water by having a higher vantage point? When I lived and fished in shallows I was doing it all from an old aluminum John boat so the poling platform thing is something I have zero experience with.
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:32 pm
by VT_Jeff
gstanfield wrote: ↑Fri Oct 30, 2020 6:20 pm
I hear that! I am very glad that I have a half-built boat( and a new pup) that will occupy a lot of my time and attention as the weather turns. Once the clocks turn, it's critical to have some indoor stuff to look forward to. Wife is turning her attention to baking and maybe learning fly tying now that fishing is turning off and ww kayaking is getting scarce.
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 6:42 pm
by VT_Jeff
gstanfield wrote: ↑Fri Oct 30, 2020 6:23 pm
Looking good, Jeff.
Great question! I suspect that anyone else on the site could tell you more about poling platforms than I can. I believe the idea is improved visibility, and fishing for carp and bowfin on Lake Ontario has proven that height offers a real advantage. But as far as actual poling, never done it and not sure if height above deck provides a lot of benefit or if it's primarily about the visibility. Our thought when I started this build was to spend some time in FLA each spring with the RV and the skiff and learn how to redfish and maybe bonefish. My wife is newly-consumed with fly-fishing and obsessed with learning those species, amoung others. Now, with the world a little off it's axis, hard to tell how much time we'll be spending in Fla in the next few years but we can use the boat locally and in lake ontario, though the poling platform is admittedly a nice-to-have in the immediate. Fun to think about and design though!
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 7:01 pm
by Browndog
The poling platform does provide height for aid in looking into the water and a vantage point for looking beyond the boat as well as providing some mechanical leverage for using the pole to push.
Poling is hard work and a light skinny skiff is better to pole than a heavy wide one.
Marsh hen hunting around my area is typically done with one person in the bow shooting and the person in the rear poling and scouting for birds from atop the poling platform.
The added height of the poling platform is also helpful on occasion to see over the spartina grass at low tide for navigation purposes as our daily tides range from 7 to 10 feet.
Re: Jeffs FS14 LS
Posted: Fri Oct 30, 2020 8:15 pm
by Dan_Smullen
VT_Jeff wrote: ↑Fri Oct 30, 2020 6:20 pm
Whoa! Looking good Jeff! Stoked Fusion is working for you!
All you need now is a cnc.
Re: Jeffs FS14 LS
Posted: Sat Oct 31, 2020 10:50 am
by Bob D
Just wanted to add my name to the list of those following this thread VERY closely. I plan on building the same boat with much the same mods. You're just more organized and beat me to it. I anxiously await your progress posts and hope to learn from your experience. Looks fantastic so far.
Bob
Re: Jeffs FS14 LS
Posted: Sat Oct 31, 2020 10:56 am
by Bob D
Would moving the poling platform support posts outboard of the stringers give you more tiller clearance?
Bob
Re: Jeffs FS14 LS
Posted: Sat Oct 31, 2020 3:44 pm
by VT_Jeff
Bob D wrote: ↑Sat Oct 31, 2020 10:56 am
Bob
Yeah, I may ultimately have to go that route. The only downside is some extra work to get them through the deck, where as designed they are in the motor well. I need to mock them up, hang the Honda and see how it looks. Thanks!
Re: Jeffs FS14 LS
Posted: Sat Oct 31, 2020 3:47 pm
by VT_Jeff
Bob D wrote: ↑Sat Oct 31, 2020 10:50 am
Bob
Glad to have you aboard Bob! I'll endeavor to stay current and look forward to seeing your progress as well!
Re: Jeffs FS14 LS
Posted: Sat Oct 31, 2020 6:59 pm
by VT_Jeff
Dan_Smullen wrote: ↑Fri Oct 30, 2020 8:15 pm
Would love one! We'll see how red the budget is once I'm splashed.
Re: Jeffs FS14 LS
Posted: Sun Nov 01, 2020 8:22 am
by VT_Jeff
VT_Jeff wrote: ↑Sat Oct 31, 2020 3:44 pm
Bob
Moving it just outside the stringers doesn't change the basic design: the shoes are still tied directly to the stringers, which is what I'd like. If it turns out I need to move them further from the center, I will probably need to add some new, short stringers and attach to those, or just create the shoes out of those short stringers directly. Maybe I should just commit to that now and stop wishing for the simple route.
Re: Jeffs FS14 LS
Posted: Sun Nov 01, 2020 8:26 am
by Jaysen
VT_Jeff wrote: ↑Sun Nov 01, 2020 8:22 am
I hate to be “that guy”, but that statement is the right one.
Re: Jeffs FS14 LS
Posted: Sun Nov 01, 2020 11:05 am
by VT_Jeff
Jaysen wrote: ↑Sun Nov 01, 2020 8:26 am
As long as you keep this site up and running you have unlimited "that guy" rights!
Choice has been made for me!
Pretty stoked to see that the transom didnt immediately buckle/fall off under the weight of this ginormous 20 hp 4stroke! Suddenly this boat looks a lot smaller!
Re: Jeffs FS14 LS
Posted: Sun Nov 01, 2020 7:27 pm
by VT_Jeff
Nice milestone today. Got the last 2 frames glassed in. Not the neatest glass work on the forum but serviceable, and DONE!
Re: Jeffs FS14 LS
Posted: Wed Nov 04, 2020 3:45 pm
by VT_Jeff
Ok, here's some boneheadedness that maybe someone else can learn from.
Once I flipped my hull and installed the stringers, I more or less lost any reference surfaces I had to measure from. The stringers did not go in completely level stern to bow, nor were they exactly level with each other. At the time I was not too concerned as I felt I could just shim the cleats here or there to get the floor level. Then when I installed my frames, I trimmed the tops down a 1/8 or a few 16ths since they were now high due to the glass/epoxy on the inside floor, but I didn't trim them straight since my sheerline was not matching side to side. Due to a lot of splay and some wavy cut rubrails, the sheerline was not exactly perfect. Add all that together and it creates a reference nightmare. The only semi-solid reference edge I have is the clamp on the transom. At this point that edge is driving the rest of the level measurements on the boat: I get that as level as my 4 foot level will allow me to, then level the frame tops by whatever means necessary, then measure down from the leveled frametops to set the floor cleats on the frames, then use those to set the cleats on the stringers and the sides. Theoretically this will all result in flat deck and a floor that is parallel with it. But I think it all could have been avoided if I had. among other things,
1. cut the stringers correctly originally.
2. Checked for and corrected splay before glassing
3. Ensured the stringers were perfectly level before glassing
4. Been more precise when trimming the frames, though the reality is that the glass/epoxy on the floor was not exactly laid precisely so there was going to be some wobble in the frames regardless.
I'm only dealing with 1/8ths of inches in terms of being off, so it's not dire, but def worth re-working till those differences are gone as much as possible.
P.s. I had to knock some incorrectly glued cleats off a frame. The gel-magic had been curing less than 24 hours in my cold basement. When I knocked them, a layer of plywood came with it off of the frame. I was not expecting that. That is some sticky !@#$
Re: Jeffs FS14 LS
Posted: Thu Nov 05, 2020 8:46 am
by pee wee
I've come to believe that the ability to find solutions to (even self-generated) problems without getting panicked is the mark of an experienced builder. It sounds like you've got things under control, even though it wasn't the path you'd choose. Thanks for sharing some reality with us!
Re: Jeffs FS14 LS
Posted: Fri Nov 06, 2020 9:48 am
by VT_Jeff
pee wee wrote: ↑Thu Nov 05, 2020 8:46 am
Thanks pee wee, glad to contribute in any way I can!
Since a boat is essentially a collection of compromises, I figured I'd better start adding some or I'll never finish. To wit: I have a very strong affinity for a sealed bilge: no plug, no holes though the deck, no screws in the deck, no chase tubes, nothing. Each chamber will theoretically be sealed from any other chamber providing theoretical unsinkability without the dreaded foam. That's the theory. One item making that utopian dream more difficult is the rebar-esque steering cable and the need/desire to get it from the motor to the grab rail without it A) being a tripping hazard and B) ruining my plan of a sealed bilge. My thought is to compromise and use a subfloor "channel". I'll do my best to keep water out of it but a worst case scenario will be less than a cup of water getting trapped in the channel. I keep going back and forsth between leaving it open on top and flooring over it. If I leave it open, it will collect water but that water will also evaporate in the right conditions. If I floor over it, it will be less likely to get water in it but once in there, much slower to come out. I may go out of the gate with it open and if I hate it like that, just 5200 in a strip of sealed plywood to cover it and seal around the cable.
This is the mockup, which has me pretty encouraged it will all work.
Edit: just occurred to me that I can floor over it in the cockpit but leave it open under the rear deck. Any water in the channel should collect at the aft end of the channel, under the (accessible) rear deck, where I can remove it with a sponge/suction bulb, or just let it evap. I'm liking this idea!
Re: Jeffs FS14 LS
Posted: Fri Nov 06, 2020 10:46 am
by Fair WX Pilot
Interesting idea. I agree that water under the deck is a major player in the longevity of these boats. I'm doing the same this as you and trying to avoid any obvious ways for it to get in.
The channel idea sounds interesting as its something that is currently used on aircraft to run IFE looms etc through cabins. Works in the same way as your idea and has been used for years so you know it works in that situation. Water getting in wouldn't be a problem as you say but I would be nervous of crud building up in there and causing a blockage. If you made the track cover removable like seat track capping then you could get in there and clean it out periodically.
I am not sure about your boat but on mine the sole is very structural and carries loads over and above just walking on it. Might be worth running it past Jacques to see how he feels about the split in the panels. I was going to put a deck drain across mine and decided against it because of the stress raiser I would have induced.
Re: Jeffs FS14 LS
Posted: Fri Nov 06, 2020 11:12 am
by VT_Jeff
Fair WX Pilot wrote: ↑Fri Nov 06, 2020 10:46 am
Great point Alan. This is another thing I like about flooring over it in the cockpit and leaving it open below the aft deck, gets me the best of both worlds and I can poke out any blockage from the opening in the aft.
Re: Jeffs FS14 LS
Posted: Mon Nov 09, 2020 12:13 pm
by VT_Jeff
These are the shoes for the console legs to slide in. Gluing them together with a crossbeam on the table saw, then will install by "hanging" them from the stringer cleats to ensure they are level/parallell/inline with each other. Not planning on the console being removable so the legs will get coated with expoy, slide in, and forever hold their peace(ideally).
Re: Jeffs FS14 LS
Posted: Mon Nov 09, 2020 8:42 pm
by Dan_Smullen
Great progress, Jeff! You’ve beaten on my glassing frames. I’m dying...
Enjoy the topside planning and work!
Re: Jeffs FS14 LS
Posted: Mon Nov 09, 2020 10:46 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Nov 09, 2020 8:42 pm
Only beating you because I picked a much smaller boat and I have no kids!
And dont worry, I'll be in the bilge for the firseeable. Deck work is in the distant, foggy future!
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 11:30 am
by VT_Jeff
Christmas came early!
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 11:43 am
by Jeff
Nice Jeff, how many gallons? Also, is that a Speedy made tank? Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 12:47 pm
by VT_Jeff
Jeff wrote: ↑Wed Nov 11, 2020 11:43 am
5 gallons, from Boyd welding. I saw this same tank in Seaslugs build. I would have liked something a little bigger but they are not doing custom orders right now and the next size up wasn't going to fit right.
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 12:56 pm
by Jeff
Thanks Jeff!! Looks good!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 12:58 pm
by VT_Jeff
Jeff wrote: ↑Wed Nov 11, 2020 12:56 pm
Thanks! I'm wondering if I need to paint it or if it's ok to leave as-is.
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 1:30 pm
by Jeff
Jeff, it is really up to you. We have customers here that get theirs powder coated or just leave them as is. If you are going to paint the aluminum tank, do a little research aa there is some prep-work you will be required to do!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 2:20 pm
by VT_Jeff
Jeff wrote: ↑Wed Nov 11, 2020 1:30 pm
Appreciate it, I'm going to leave it unless someone talks me out of it.
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 7:22 pm
by Dan_Smullen
Oohhh! How nice is it to see something not brown on your build?
I noticed your thread just had a birthday. That’s a milestone. Right?
Re: Jeffs FS14 LS
Posted: Wed Nov 11, 2020 8:33 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Nov 11, 2020 7:22 pm
Holly cow, you're right! 1 year in. I originally planned on 18 months, so 6 to go!
The tank is sweet, cant wait to fill it up!
Re: Jeffs FS14 LS
Posted: Thu Nov 12, 2020 1:42 pm
by VT_Jeff
Console sockets taped in and chase channel glued in place. Completing cleats is next, then floor.
Re: Jeffs FS14 LS
Posted: Thu Nov 12, 2020 1:47 pm
by VT_Jeff
Console sides are a parallel effort, got them glued up for required width at the top.
Re: Jeffs FS14 LS
Posted: Thu Nov 12, 2020 8:47 pm
by VT_Jeff
The vert grain fir stock I'm using for the console sides comes with soft edges, so I needed to joint part of the edge before attaching the "ears" that will add width at the top where the helm will be housed. Otherwise they'll be used as is.
Re: Jeffs FS14 LS
Posted: Fri Nov 13, 2020 9:17 am
by VT_Jeff
Got the final cleats attached this morning and gave all the cleats a first coating of epoxy on the undersides and vertical faces. I'll wait until the sole goes in before coating the top faces to avoid the need to sand them.
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 8:29 am
by VT_Jeff
Boats got sole!
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 8:57 pm
by VT_Jeff
Full size sketch of my helm/console on the workbench for easy patterning.
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 9:07 pm
by bamaguy0
VT_Jeff wrote: ↑Wed Nov 11, 2020 11:30 am
Hey Jeff, that's probably the tank I was going to get as well. Where are you going to mount it?
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 10:02 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Nov 14, 2020 9:07 pm
Just forward of frame B. I will need to open the hatch to fill. Seaslug ran his filler neck through the deck but I couldn't figure that out, I think it would require a custom neck and Boyd's not doing anything custom right now. Maybe there's a simple way to extend the neck, I'm open to suggestions.
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 10:10 pm
by bamaguy0
Hmmm. I was going to look into that. I assumed that the filler neck would take filler hose. Maybe not?
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 10:23 pm
by VT_Jeff
That will probably work if I can find hose and a deck fitting that match the diameter of the tank neck. I'll start shopping!
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 10:32 pm
by bamaguy0
They sell this kit.
https://fueltankparts.com/products/boyd ... eq=uniform
It you select yes, you get some adapter for that threaded neck. I can't find what it is, though. The neck threads are 2" NPS (Straight not Taper). A female thread to barb would be ideal, but not sure how available NPS fittings are. Also adds height that may or may not clear the deck.
Re: Jeffs FS14 LS
Posted: Sat Nov 14, 2020 10:38 pm
by bamaguy0
This might be the ticket.
https://www.mcmaster.com/5185K42
It isn't rated for Gasoline and I think that has to do with the Neoprene gasket. Might need to source a Buna-N/Nitrile replacement and all would be well.
Also, since you have the tank, could you measure the height of the neck from the top of the tank? I've modeled it for my boat in Fusion 360 and I wanted to check clearances.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 12:56 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Nov 14, 2020 10:38 pm
2 1/4 cap on, 1 3/8 cap off
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 1:20 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Nov 14, 2020 10:32 pm
They sell this kit.
I did look at that but am a little confused. It seems l like the kit comes with a new neck that you need to cut a hole for and bolt in. But the parts photo shows no neck and the tank photo shows a welded in neck. This is all outside my very narrow area of expertise and involves explosive liquids on a boat so I'm going to need it really dumbed down before I pull any triggers.
Btw, the outside diameter of the neck that comes is around 2 3/8. That neck is welded on.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 2:06 pm
by bamaguy0
Yeah it mentions an adapter if you already have a tank with a threaded neck but doesn't show it in any photos. They may be willing to sell that adapter separately with a phone call.
My money is its something nearly identical to the McMaster-Carr part I linked.
I wouldn't want that whole kit anyway. I'm going to be looking for a vented fill port. Saves from having to put another hole in the boat to vent the tank.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 2:22 pm
by VT_Jeff
bamaguy0 wrote: ↑Sun Nov 15, 2020 2:06 pm
Yeah, the vent is another can of worms I've been wrestling with. My plan atm is to drill the hole near the deckline and run the vent hose to a vent with a backflow preventer. Still concerned about water in the tank if I bury the bow, which is pretty likely in the LS.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 3:51 pm
by bamaguy0
Definitely going to want something like this:
https://www.westmarine.com/buy/attwood- ... --10017838
Supposedly these keep water from entering the tank.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 4:06 pm
by VT_Jeff
That's what I'm looking at, but it's the "normal conditions and washdows" disclaimer that has me wondering. Not sure if burying it in a wave is normal.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 4:13 pm
by bamaguy0
VT_Jeff wrote: ↑Sun Nov 15, 2020 4:06 pm
Probably not, but not sure there's much else you could do.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 4:41 pm
by VT_Jeff
bamaguy0 wrote: ↑Sun Nov 15, 2020 4:13 pm
I think a vented cap is out unless it's a deck fill, would you agree?
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 4:47 pm
by bamaguy0
My plan involved mounting the fill cap on the deck. That's what seaslug's fs14 had.
Next problem I've found is most boat filler ports take a 1.5" hose.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 5:06 pm
by VT_Jeff
bamaguy0 wrote: ↑Sun Nov 15, 2020 4:47 pm
Yup, it's a puzzle. Interested to see what you ultimately settle on, I'm going to delay any decisions for a bit.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 7:41 pm
by VT_Jeff
First step of sole glue up
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 8:16 pm
by Dan_Smullen
Great way to wrap up a Sunday!
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 8:25 pm
by bamaguy0
I updated my Boyd's 5gal tank model with the filler neck height (I was close at 1.5"). I added the McMaster-Carr fitting and it doesn't give much clearance to the deck. This is with the tank just forward of Frame B and set roughly as low as the hull would allow it considering some sort of creation of a flat surface for the flanges to mount to. This is a +5% scaled model also.
I'm beginning to think you're right that it will be best to just have a hatch to access the filler cap. I want to have a hatch that it will fit through anyway because I don't want to rip the deck out if I have to remove it.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 9:24 pm
by VT_Jeff
bamaguy0 wrote: ↑Sun Nov 15, 2020 8:25 pm
...considering some sort of creation of a flat surface for the flanges to mount to.
Right. Add to that height of the blocks that the flanges will actually sit on. The bolt heads will be inside those blocks, raising the tank up another 1/2" or over your flat surface. At least that's the way I figured it........there may be a simple way to get the flanges flush on the surface but I'm going the bolts through blocks method.
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 9:36 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Nov 15, 2020 8:16 pm
Trying to motivate to do some more tonight but the Patriots are actually in this game!
Re: Jeffs FS14 LS
Posted: Sun Nov 15, 2020 10:57 pm
by VT_Jeff
Got the tank bed pieces cut out. Used an old jig to taper the bottom of the platform.
A little scorching but servicable.
My front compartments will have a sole but the tank will be in a mini-bilge that will have a pump and worst case hold a few gallons of water.
The final clearance with the tank on a 9mm tapered platform and 3/4" blocks is 5 1/2" from the top of the neck to the underside of the deck . My boat is +10%
Re: Jeffs FS14 LS
Posted: Mon Nov 16, 2020 9:58 am
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Nov 16, 2020 6:09 pm
by VT_Jeff
Jeff wrote: ↑Mon Nov 16, 2020 9:58 amNice!!! Jeff
Thanks jeff!
Step 2 of the sole join: filling the gap...
Re: Jeffs FS14 LS
Posted: Mon Nov 16, 2020 6:56 pm
by VT_Jeff
Chiseled out the bolt head spaces on the tank feet. Some cleaner than others. I'm out of practice with the ww tools but looking forward to spending more time with em.
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 8:46 am
by pee wee
VT_Jeff wrote: ↑Mon Nov 16, 2020 6:56 pm
ww tools? Weed Whacker? Weight Watcher? Wheel Weight? Whole Wheat? World Wide? I give up.
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 8:55 am
by bamaguy0
Try woodworking.
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 8:56 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Nov 17, 2020 8:55 am
Try woodworking.
Ding!
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 8:57 am
by VT_Jeff
pee wee wrote: ↑Tue Nov 17, 2020 8:46 am
I appreciate the effort Pee Wee! That's a wide range of guesses there!
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 9:02 am
by pee wee
Thanks!
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 11:16 am
by VT_Jeff
Epoxy coat 1 of 2 on the underside of the sole and coat 2 on underside of tank platform.
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 11:34 am
by Fair WX Pilot
Those tank feet look good to me. They’re not loose, it’s expansion room for the epoxy
The boat looks great.
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 12:16 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Tue Nov 17, 2020 11:34 am
That's right! Gaps are good gaps are good!
Re: Jeffs FS14 LS
Posted: Tue Nov 17, 2020 7:48 pm
by VT_Jeff
Tank platform glued in, will run some biax tape on it also.
Re: Jeffs FS14 LS
Posted: Wed Nov 18, 2020 11:02 pm
by VT_Jeff
Got a second, sloppy coat on the sole bottom and got parts cut for the pole platform shoes. Not convinced I'll actually pull the trigger on the platform but the shoes will go in regardless just in case.
Re: Jeffs FS14 LS
Posted: Thu Nov 19, 2020 9:22 am
by VT_Jeff
First half of platform shoes glued up.
Re: Jeffs FS14 LS
Posted: Thu Nov 19, 2020 6:26 pm
by VT_Jeff
Put the load right on me!
Re: Jeffs FS14 LS
Posted: Thu Nov 19, 2020 6:37 pm
by VT_Jeff
Got the other sides attached to the platform shoes. I'll trim them neat and glass them to the inside faces of the stringers at the transom. The platform legs will slide in/slide out, and the platform load will be on the stringers and not the transom. At least in theory.
Re: Jeffs FS14 LS
Posted: Sun Nov 22, 2020 10:37 am
by VT_Jeff
Aft sole cleats taking shape. Scraping the bottom of the clamp barrrel.
Re: Jeffs FS14 LS
Posted: Sun Nov 22, 2020 11:07 am
by VT_Jeff
1/3 scuppers.
Re: Jeffs FS14 LS
Posted: Sun Nov 22, 2020 11:12 am
by VT_Jeff
Obligatory plug shot:
Re: Jeffs FS14 LS
Posted: Sun Nov 22, 2020 11:35 am
by VT_Jeff
Drainage
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 9:23 am
by VT_Jeff
Some scattered progress.
Got the tank feet made:
Got some more aft sole cleats in place:
Started from scratch on the platform shoes but got them made and glued in
Got the bow eye installed, slightly crooked. Trying to drill correctly on that surface proved more difficult than I planned for. This is the 3rd time I've installed a bow eye and probably the worst one yet. As long as it stays in place and gets the boat onto the trailer I'm happy with it. Theres not enough real estate to fill and redrill.
Next is getting the final 3 cleats in place on the transom and then install the aft sole.
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 9:27 am
by Jeff
Nice work Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 9:38 am
by bamaguy0
The bow eye is one of the things that scares me as well. Such small real estate on this boat!
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 10:03 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Nov 24, 2020 9:38 am
Yup. I couldn't(or wouldn't) come up with a simple/effective way to get a guide block securely attached with any real precision so in the end I just free-handed it. The pilot holes seemed perfect, but as I increased bit size, the bottom hole migrated to port. I could potentially keep making the hole bigger and then fill but I'm loathe to remove anymore material from that already extremely fragile region.
All I can hope for is to find someone who finds the boat interesting enough to actually notice. My drift boat is full of imperfections and for the life of me I can't get anyone to notice them.
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 10:14 am
by VT_Jeff
If I was going to do it again, I would square off the nose where the boweye is going. Actually tempted to do that now.
Re: Jeffs FS14 LS
Posted: Tue Nov 24, 2020 10:25 am
by bamaguy0
VT_Jeff wrote: ↑Tue Nov 24, 2020 10:14 am
Good idea! I actually put a couple extra plies up there to help wrap the corner during my layup. I guess it wouldnt hurt if they became sacrificial.
Re: Jeffs FS14 LS
Posted: Wed Nov 25, 2020 7:35 pm
by VT_Jeff
Got the aft sole properly fitted and put first coat on underside.
Got the platform sockets glassed in and the final transom cleats in.
Now just need to glass-in the battery support and then install the sole.
Wife says I'm not allowed to work on the boat all weekend, I need to do "family stuff". Luckily "family stuff" in our family means fishing with her and the dog!
Happy TG to all!
Re: Jeffs FS14 LS
Posted: Wed Nov 25, 2020 10:36 pm
by VT_Jeff
Aft sole is curing so moved back to the cockpit and drilled/routed the openings for the console sockets and the chase track. This is my first good look at how the console will mesh with the cockpit, outside of Fusion360. so far I'm happy with it.
Re: Jeffs FS14 LS
Posted: Thu Nov 26, 2020 9:29 am
by VT_Jeff
Made a quick & dirty under-deck support for the battery, which will be a jet ski battery. The aft sole is only 4mm so its kind of critical that its supported for all the bouncing it will endure on the trailer. It doubles as a spreader for the platform sockets.
Got a second coat on the aft sole underside
Glued in the tank feet. Once they cure I'll remove and stash the tank until install time.
Re: Jeffs FS14 LS
Posted: Thu Nov 26, 2020 1:05 pm
by Fair WX Pilot
Hi Jeff, the boat looks great. Can I ask a stupid question, bearing in mind that I may have missed the answer and preempted it with "Stupid Question". Will the platform etc. be bonded in to the sockets you have created and sealed? I only ask this as I cant work out how they drain if they are open to water ingress at the top. As I say I may have missed this, but like the design idea hence asking. Happy Thanksgiving.
Re: Jeffs FS14 LS
Posted: Thu Nov 26, 2020 2:51 pm
by VT_Jeff
Fair WX Pilot wrote: ↑Thu Nov 26, 2020 1:05 pm
Very astute, Alan! I'd expect no less from the guy landing large planes in crosswinds. They wont drain, is the dirty secret. When the platform is out, I'll cap the sockets. When it's in, there will be minute ingress.l no getting around it. Along with the gas tank bilge which will also collect water and the chase track. they are expected to collect and hold a small amount of water until it either evaps or I draw it out manually. Measured compromise. I poured raw epoxy into both sockets to help seal them. The console will be sealed into its sockets so no moisture expected there.
Re: Jeffs FS14 LS
Posted: Thu Nov 26, 2020 3:04 pm
by VT_Jeff
Giving some serious thanks for time to work on the build lately! Got the aft sole in place after we placed a few keepsakes from our recently departed pup and imminently departing cat. Hoping there is not a screwdriver or tape measure in there as well.
Re: Jeffs FS14 LS
Posted: Sat Nov 28, 2020 5:05 pm
by VT_Jeff
Got most of the fore sole cleats in as well as the frame for the tank bilge
Got the console sides trimmed down and drilled/located the helm support beam
Re: Jeffs FS14 LS
Posted: Sun Nov 29, 2020 10:48 am
by Dougster
Wow, that looks really nice. I look forward to seeing it progress. Seems clever and well thought out.
Dougster
Re: Jeffs FS14 LS
Posted: Sun Nov 29, 2020 10:52 am
by Jeff
Really nice detail Jeff!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Nov 29, 2020 5:48 pm
by VT_Jeff
Dougster wrote: ↑Sun Nov 29, 2020 10:48 am
Dougster
Appreciate that feedback, Dougster!
Re: Jeffs FS14 LS
Posted: Sun Nov 29, 2020 7:41 pm
by Dan_Smullen
It all looks great! Nice straight grain on the steering support.
Re: Jeffs FS14 LS
Posted: Sun Nov 29, 2020 8:46 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Nov 29, 2020 7:41 pm
Thanks Dan, I'd like to leave it bright but it may not be feesible, we'll see.
Re: Jeffs FS14 LS
Posted: Wed Dec 02, 2020 9:57 am
by VT_Jeff
Finally completed the cleats for the fore sole and got it glued down this morning. 1 sole left, the bow.
Re: Jeffs FS14 LS
Posted: Thu Dec 03, 2020 10:52 am
by VT_Jeff
I'm missing a block plane and am fairly sure its sealed under the fore sole. I just ordered a cheap scope to start looking for it. Trying to peer through small holes was not working. This is one of the dangers of doing most of my building immediately after waking up. The other danger is building after work, during cocktail hours. Will be interesting to see which end of the day ultimately produces more bonehead moves.
I started on the bow sole and got the aft end of my channel exposed in the aft sole.
Re: Jeffs FS14 LS
Posted: Thu Dec 03, 2020 11:27 am
by narfi
I think you can install a stud finder on your smartphone that uses the built in magnetic compass, perhaps you could use it to find your plane?
Re: Jeffs FS14 LS
Posted: Thu Dec 03, 2020 11:59 am
by VT_Jeff
narfi wrote: ↑Thu Dec 03, 2020 11:27 am
Great idea Narfi. The app didn't seem to work too well but it gave me another idea to try a large, blown, PA speaker magnet. Spent a minute with it just now without luck but will try again after work and see if it produces any results.
I figure the scope will be good have regardless to make it easier to find water eventually.
Re: Jeffs FS14 LS
Posted: Sat Dec 05, 2020 9:04 am
by VT_Jeff
I used the Texas Hold'em technique to get the right profile for the bow sole. I tried a ticking stick first but was struggling with accuracy. This worked pretty well though I could have spent a lot more time getting the surfaces to mate better instead of using liberal amounts of fudge.
Re: Jeffs FS14 LS
Posted: Wed Dec 16, 2020 11:21 am
by VT_Jeff
Took a side trip and made a decorative paddle for my mom for Christmas. Maple shaft(that stuff grows on trees around here) and doug fir blades. I think the highlights are mahogony, just stuff that was hanging around.
Re: Jeffs FS14 LS
Posted: Wed Dec 16, 2020 11:45 am
by Jeff
Very nice work!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Dec 16, 2020 6:03 pm
by gstanfield
Looking good!
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 12:27 am
by cracked_ribs
That's a good trick with the deck of cards...I'll have to remember that one. I could have done a better stem template that way, I bet.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 10:49 am
by VT_Jeff
cracked_ribs wrote: ↑Thu Dec 17, 2020 12:27 am
Thanks. I used the same technique to make the entire deck template for my driftboat and it worked perfectly, though I hadn't thought up the deck of cards yet: I was cutting up posterboard into small, playing-card-sized pieces.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 10:58 am
by VT_Jeff
gstanfield wrote: ↑Wed Dec 16, 2020 6:03 pm
Looking good!
Thank you!
I wet-out some of the 4oz this AM on my stern sole and it was not a good experience, I felt like a first-timer! The biggest issue was the fraying of the
edges.
I think I learned that I need to cut the pieces much more oversized and stay well clear of the edges while wetting out, then trim off the edges when it's green.
The other issues I had were with the new epoxy(MarinExpoy Fast: I have been using Silvertip Slow up till now) and the white pigment suspension I was adding. Added together, it made the epoxy feel pasty and the whole process feel a bit foreign to me and cause a little frustration and poor final results.
Good news is that I was doing this work in what will be an unseen area, under the stern deck, so it's a good place to make a mess, which I did, properly and completely. And now I know what the new epoxy feels like/works like and I'll be ready when I do the next piece.
Do you pre-glass your panels before installing?
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 11:39 am
by gstanfield
VT_Jeff wrote: ↑Thu Dec 17, 2020 10:58 am
Looking good!
Thank you!
edges.
The frames I pre-glass mostly, but some panels I glass after install. With the very light glass it can be a challenge as they are definitely different than working with the heavier biaxial glass or even heavier woven. The process that works for me is like this:
~ Cut cloth to size, allowing about an inch extra on all sides.
~ Roll one coat of epoxy on panel, allow to sit until it's not runny, but still pretty sticky. The time will vary depending on temp, epoxy, hardener, etc.
~ Gently lay 4oz cloth on epoxy, repositioning as needed. This is where having it sticky helps, it's like laying down decals where the sticky holds them in place, but you can still reposition as long as you don't press down hard.
~ Once positioned where you want it roll a light coat of epoxy on top. Avoid the temptation to put it on too thick.
~ Use plastic spreader and "squeegee" the cloth, pushing it into the first layer of epoxy and getting it nice and even without air bubbles.
As to the pigments, I've never used pigments in epoxy so I have nothing to offer in that regard.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 11:48 am
by VT_Jeff
gstanfield wrote: ↑Thu Dec 17, 2020 11:39 am
I'll go with this process next, much appreciated! I have a few more blind sections before I need to do my cockpit floor, so a few more chances to mess-up and learn.
I'm going to do a batch without the pigment just so I'll know what the MarinEpoxy feels like on it's own, and then adjust from there. It should not be difficult.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 12:00 pm
by Jaysen
one thing on the squeegee... keep the edge smooth and clean or your glass gets pulled or moved. And then you have a real mess. One that temps you to get gasoline and matches. But maybe that is just me.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 12:11 pm
by VT_Jeff
Jaysen wrote: ↑Thu Dec 17, 2020 12:00 pm
I feel your rage!
Appreciate the tip, that may have been part of the issue.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 1:39 pm
by gstanfield
Good point that I forgot to mention. After 30 years of doing body work I just took it for granted that it was understood to use a good spreader!
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 2:08 pm
by VT_Jeff
gstanfield wrote: ↑Thu Dec 17, 2020 1:39 pm
30 years of body work? That is an insanely unfair advantage! These boats are 99% body work!
Buddy of mine who grew up in VT went to some technical college in Laramie Wy (I think it was Laramie) to study the automotive trade, specialty in body work. Probably around 1987. Runs a ski-tuning shop now.
Re: Jeffs FS14 LS
Posted: Thu Dec 17, 2020 3:02 pm
by gstanfield
VT_Jeff wrote: ↑Thu Dec 17, 2020 2:08 pm
That would be WyoTech, the original before it was sold and went downhill. I also went there in the mid 90's, but grew up restoring cars with my dad in his shop. I've done body work as a primary job here and there, but have always done restoration work as a side even when not working in the industry full time.
Re: Jeffs FS14 LS
Posted: Sat Dec 19, 2020 11:52 am
by VT_Jeff
Got the Mrs. to assist on the sole wet-out this morning.
Re: Jeffs FS14 LS
Posted: Sat Dec 19, 2020 4:00 pm
by Dan_Smullen
Teamwork makes the dream work!
Re: Jeffs FS14 LS
Posted: Sun Dec 20, 2020 9:55 am
by VT_Jeff
The sole glass came off like packing tape this morning when I went to trim the excess. slightly disheartening.
I didnt pre soak the wood because I was afraid the 4oz cloth would be unmanageable trying to lay it out on sticky epoxy. So I prelaid the glass and wet it out over the top. I tried to warm.up the epoxy first but with the fast hardener it was challenging to get it warm and not have it kick too quickly. I ordered slow hardener, going to wait until that arrives and try again.
Re: Jeffs FS14 LS
Posted: Sun Dec 20, 2020 9:59 am
by VT_Jeff
VT_Jeff wrote: ↑Sun Dec 20, 2020 9:55 am
Maybe it would have been fine if I let it harden longer, going to leave the cockpit section for now and see if it behaves better in a week.or so.
Re: Jeffs FS14 LS
Posted: Sun Dec 20, 2020 10:18 am
by VT_Jeff
Re: Jeffs FS14 LS
Posted: Sun Dec 20, 2020 11:11 am
by cracked_ribs
I think at some point everybody gets epoxy kick jitters. I sealed up some parts for the cockpit of my big boat and did the work around September...it was hot and sunny for the first week of the project and then on about day ten it got rainy and cold and the last piece is primed up with epoxy didn't act like any of the others. I kept thinking I must have mixed stuff wrong and kept checking the piece every few hours, thinking it was still a bit tacky and it just didn't feel right etc etc etc and I was super annoyed. Finally I bought it into the basement and left it next to a halogen work lamp for a couple of days and it kicked hard as a rock. But the entire time I kept going into the basement, coming back up and announcing I was sure I'd have to scrap the piece.
At least with 4oz weave, you didn't waste a ton of materials. Imagine pulling up that much 1708...that'd be an expensive bag of garbage.
Re: Jeffs FS14 LS
Posted: Sun Dec 20, 2020 12:41 pm
by VT_Jeff
cracked_ribs wrote: ↑Sun Dec 20, 2020 11:11 am
Appreciate the thoughts and you're absolutely right, it's a minute setback time and money-wise. Cheap lesson.
Re: Jeffs FS14 LS
Posted: Mon Dec 21, 2020 1:09 am
by PapaDave
Sorry to see that Jeff. The weather has been cold for building here too and is both a blessing and curse. I get used to making big batches of epoxy over the winter that do not kick off right away and then learn my lesson in the Spring when I waste it due to higher temperatures. I know you will get it sorted out. Enjoy the build. Looking great!
Re: Jeffs FS14 LS
Posted: Mon Dec 21, 2020 8:15 am
by VT_Jeff
PapaDave wrote: ↑Mon Dec 21, 2020 1:09 am
Thanks Dave. All is good, I recovered from that snafu and moving on.
Progress on the console innards and made a tent with an oil-filled electric heater to help the epoxy harden.
Re: Jeffs FS14 LS
Posted: Mon Dec 21, 2020 8:18 am
by VT_Jeff
Dan_Smullen wrote: ↑Sat Dec 19, 2020 4:00 pm
You got it!
Been quiet out of Richmond lately, are you making mad, secret progress and planning a bombshell update?
Re: Jeffs FS14 LS
Posted: Mon Dec 21, 2020 8:27 am
by Jeff
Great to have good help in the family!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Dec 23, 2020 7:27 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Dec 21, 2020 8:18 am
You got it!
Haha! Unfortunately, no. Piddling here and there prepping for gas tanks. Some home projects happening too. But it’s all good. Still lurking and inspired by everyone else’s progress.
Merry Christmas to you and your Crew up north from VA!
Re: Jeffs FS14 LS
Posted: Wed Dec 23, 2020 8:04 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Dec 23, 2020 7:27 pm
You got it!
Also with you and yours, Dan thanks!
Re: Jeffs FS14 LS
Posted: Thu Dec 24, 2020 11:00 pm
by gstanfield
Sorry to hear of the SNAFU, but glad you’ve recovered and moving on. Merry Christmas and a happy new Year.
Re: Jeffs FS14 LS
Posted: Thu Dec 24, 2020 11:24 pm
by VT_Jeff
gstanfield wrote: ↑Thu Dec 24, 2020 11:00 pm
Nuthin but a thing! Very Merry to you also, have a great one!
Re: Jeffs FS14 LS
Posted: Mon Dec 28, 2020 7:29 pm
by VT_Jeff
I'm getting slowly framed. Still mostly dryfitting, killing time while epoxy cures to sandable, then will to paint the underdecks.
Re: Jeffs FS14 LS
Posted: Mon Dec 28, 2020 8:13 pm
by Jeff
Re: Jeffs FS14 LS
Posted: Mon Dec 28, 2020 8:55 pm
by Dan_Smullen
Looks like a fun part of the project!
Can you feel a considerable amount of added rigidity as you add framing? Looks like the does a lot to stiffen up the topside.
Re: Jeffs FS14 LS
Posted: Mon Dec 28, 2020 9:37 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Dec 28, 2020 8:55 pm
It is fun! Finally a few hours in a row without gloves on!
It's already super stiff due to the bow-to-stern sole and the rub rail, but I suspect the framing will add yet more stiffness once glued up.
Re: Jeffs FS14 LS
Posted: Tue Dec 29, 2020 8:28 am
by VT_Jeff
Having some light remodeling done on the guest house today.
Re: Jeffs FS14 LS
Posted: Tue Dec 29, 2020 8:35 am
by Jeff
Yes, that does appear to be some "light" remodeling!!! Jeff
Re: Jeffs FS14 LS
Posted: Tue Dec 29, 2020 11:36 am
by VT_Jeff
Jeff wrote: ↑Tue Dec 29, 2020 8:35 am
Yup. Just some paint and updated appliances, its finished now. Ready for guests. We encourage guests to make alternative reservations in the event that our accommodations are not exactly what they were looking for.
Re: Jeffs FS14 LS
Posted: Sun Jan 03, 2021 5:11 pm
by VT_Jeff
Got some decking loose fit. Painting the sole under the front decks was a bit of a disaster, going to postpone any further painting until spring.
Re: Jeffs FS14 LS
Posted: Sun Jan 03, 2021 6:36 pm
by VT_Jeff
I bought my wife(Elaine) a "make your own jewelry" kit for Christmas. She got right to it and quickly churned out 40 pieces of bling by following some videos. When she opened the kit she said "He went to Orvis!"
There are only two seasons in Vermont: Fly fishing season and Fly tying season.
Re: Jeffs FS14 LS
Posted: Sun Jan 03, 2021 7:18 pm
by Jeff
Nice Jeff!!!
Re: Jeffs FS14 LS
Posted: Thu Jan 07, 2021 9:02 am
by VT_Jeff
Worked on the rod tubes this morning. Took a few iterations before I got the process a little wired so the port side isn't as clean as the starboard, but they'll work and will never be seen except in these photos.
Re: Jeffs FS14 LS
Posted: Sat Jan 09, 2021 6:51 pm
by VT_Jeff
Got some wiring done while watching indy give the game away. Luckily I'm a Pat's fan. Go Buffalo!
Re: Jeffs FS14 LS
Posted: Sun Jan 17, 2021 4:46 pm
by VT_Jeff
Started the stern deck. I had a hard time determining how to locate the hatch openings and came up with this: I clamp 2 nails on the inside of each of the 4 hatch frame sides, with just about a steenth proud of the frame top. I then drop the deck panel down using pre-drilled alignment pins. I run a 25lb weight over the whole surface to ensure that each nail marks the panel, then I pull the panel off and quite literally connect the dots. It's simple, quick and accurate.
No idea how others are doing it but this is def working for me.
Re: Jeffs FS14 LS
Posted: Sun Jan 17, 2021 6:15 pm
by bamaguy0
Great idea!
Re: Jeffs FS14 LS
Posted: Mon Jan 18, 2021 8:49 am
by pee wee
VT_Jeff wrote: ↑Sun Jan 17, 2021 4:46 pm
I can follow what you are describing, but then I see what looks like a pencil clamped to a piece of wood- how does that come into play?
Re: Jeffs FS14 LS
Posted: Mon Jan 18, 2021 9:15 am
by VT_Jeff
pee wee wrote: ↑Mon Jan 18, 2021 8:49 am
That's a framing nail, 1 of 8 that will be used to mark the inside of each frame opening.
Re: Jeffs FS14 LS
Posted: Mon Jan 18, 2021 10:41 am
by joe2700
It's common in lofting to put a nail on its side so the head is on the line you want to transfer. You tap this down so the head sinks in then you place the wood you want to transfer to on top and apply weight(can walk on it when lofting). It leaves a number of indents you connect same as your method, but requires no clamps. You could have done this down the centerline of your frames, and you know the offset ofter marking the centerline. Just an alternative for places you can't easily clamp.
Re: Jeffs FS14 LS
Posted: Mon Jan 18, 2021 10:48 am
by VT_Jeff
joe2700 wrote: ↑Mon Jan 18, 2021 10:41 am
Good call! This would have been simpler and achieved the same results!
Re: Jeffs FS14 LS
Posted: Wed Jan 27, 2021 8:45 pm
by VT_Jeff
I have this nagging fear of my hatches warping. I want to lock them down without spending $66 /hatch on the fancy cam locks. Came up with this prototype. Will require a key(Phillip's head) but I can leave them unlocked when using the boat and lock them when its stored, is my thought.
Time will tell if its genius or ignoramus.
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 7:39 pm
by VT_Jeff
Been working steady but progress is hard to measure. 1001 tiny tasks, a handful of big ones.
I got the stern deck glued down, another milestone in my eyes. With it, I've regained the sense that I may actually splash this boat, a feeling that waxes and wanes with the start and completion of major steps.
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 7:52 pm
by Jeff
Good progress Jeff!!! How cold it’s it in your area and did you get a bunch of snow?? Jeff
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 7:59 pm
by VT_Jeff
Jeff wrote: ↑Tue Feb 02, 2021 7:52 pm
Thanks jeff!
Just exiting a cold snap, back in the high 20s, feels balmy. Hard to measure the snow due to wind but theres probably 3 feet or more on the ground. We've been xcountry skiing along the river and hiking up/snowboarding down an old, closed ski area here in town, it's been great, the new pup is a snow machine! Thanks for asking, hope all is good in sunny Fla!
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 8:03 pm
by cracked_ribs
VT_Jeff wrote: ↑Wed Jan 27, 2021 8:45 pm
You can lock the hatches, but I'm probably going to steal this idea.
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 8:17 pm
by Jeff
Too cold Jeff but it will be in the high 30’s tonight here in Florida!!!! Way too cold for us!!!! Stay warm, Jeff
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 8:21 pm
by bamaguy0
Jeff wrote: ↑Tue Feb 02, 2021 8:17 pm
Watch out for falling iguanas! Are they around your parts or still too far north?
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 8:51 pm
by Jeff
You are correct, we have some but not like Miami!!! Jeff
Re: Jeffs FS14 LS
Posted: Tue Feb 02, 2021 10:44 pm
by PapaDave
Looking good Jeff. All of those little jobs end up becoming a finished boat. Keep at it. I am always amazed how the build “to do” list gets longer as you mark off items completed. And then, it is in the water. Stay warm!
Re: Jeffs FS14 LS
Posted: Wed Feb 03, 2021 7:47 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Feb 02, 2021 8:21 pm
Do they freeze and fall out of trees?
Re: Jeffs FS14 LS
Posted: Wed Feb 03, 2021 7:54 am
by VT_Jeff
PapaDave wrote: ↑Tue Feb 02, 2021 10:44 pm
Thanks dave. Shooting for june splash but no pressure, we've got other watercraft that also need use.
Re: Jeffs FS14 LS
Posted: Wed Feb 03, 2021 8:03 am
by bamaguy0
VT_Jeff wrote: ↑Wed Feb 03, 2021 7:47 am
Yeah they're cold blooded, and they can't handle it when South Florida gets their annual cold snap. They basically become paralyzed. Some are pretty significant in size.
Re: Jeffs FS14 LS
Posted: Wed Feb 03, 2021 12:36 pm
by VT_Jeff
I'd be interested to know what you're lofting there, btw, looks like maybe some frames/stations/molds for a strip-built?
Re: Jeffs FS14 LS
Posted: Wed Feb 03, 2021 3:23 pm
by joe2700
VT_Jeff wrote: ↑Wed Feb 03, 2021 12:36 pm
Just the first clear image I found online of what I was talking about. I do have pics of me doing it for my plywood panels somewhere, but it was quicker to search online than dig through all my build pics
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 9:07 am
by VT_Jeff
Bit of a staged photo here for fun. Amazing how all the internals I've been slaving away at for months become instantly invisible when the decks go on!
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 9:15 am
by VT_Jeff
One more
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 9:40 am
by Jeff
Nice work Jeff!!!! Jeff
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 7:27 pm
by bamaguy0
Awesome!
It's funny, I was just thinking the other day after working on my console how I could raise my seating position a bit. Cooler sounded like a good idea to me also!
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 8:30 pm
by VT_Jeff
bamaguy0 wrote: ↑Thu Feb 04, 2021 7:27 pm
Awesome!
Thanks Cameron.
I think coach wrote the book on cooler integration, I'll find his thread and link.
Re: Jeffs FS14 LS
Posted: Thu Feb 04, 2021 11:22 pm
by cracked_ribs
VT_Jeff wrote: ↑Thu Feb 04, 2021 9:15 amOne more
I really like your ultra minimalist console. So often I see giant consoles on little boats and to me it's just space eaten up.
My seating plan is also coolers, basically coolers with pads that I can move around as necessary and haul out to clean. People build so much into these things which is tempting, since it's all custom anyway, but I'm a bit of a believer in keeping it simple. That's a great setup you're putting together there, I think.
Re: Jeffs FS14 LS
Posted: Fri Feb 05, 2021 9:25 am
by VT_Jeff
cracked_ribs wrote: ↑Thu Feb 04, 2021 11:22 pm
Thanks CR, it's basically exactly big enough to house the helm, a couple of cup holders and 4 on/off switches. I have it too far forward: makes it great for the driver but not any leg room for the passenger seat I hope to mount on the legs.
Simple, flexible seating is smart, it's hard to predict all the ways a boat's gonna get used, at least for me. On my driftboat, I left it wide open with a flat, self-bailing deck with a few tie down points for the guest seat(cooler) and guide seat, which was originally supposed to be another cooler but it turned out that was too tall, so I made a battery box with a soft top. The guest seat tends to stay where it is but I move the guide seat around a lot depending on if we're actually drifting, or rowing on flatwater, or motoring. The other idea is that we can camp with it, take the seats out at a campsite and use the boat as a sleeping platform. That boat has been a ton of fun to mess around in.
Re: Jeffs FS14 LS
Posted: Fri Feb 05, 2021 9:31 am
by VT_Jeff
Awesome!
As I said, Coach set the bar on cooler integration IMO. His build may have orignally given me the idea to move my cooler to the stern deck, albeit a lot more quick/dirty than his profressional job.
viewtopic.php?f=12&t=63888&hilit=coach&start=310
Re: Jeffs FS14 LS
Posted: Fri Feb 05, 2021 9:56 am
by bamaguy0
Thanks! I think I recall seeing that in the past. Definitely a gold standard. I think I'll be doing a cooler or try to rig a fold up leaning bar that can be flushed to the deck when not in use. We'll see what I'm able to come up with.
Re: Jeffs FS14 LS
Posted: Sun Feb 07, 2021 9:57 pm
by Dan_Smullen
I think I just watched my chances of catching you slip away for good.
The console looks great.
Good point about covering up all the good work below deck, but there really is no alternative. In my experience, “rushing” only leads to delays modifying the plan to member with erratic work. No question, it’s worth taking the time to do good work, even when no one will see it.
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 8:50 am
by VT_Jeff
Dan_Smullen wrote: ↑Sun Feb 07, 2021 9:57 pm
Don't despair. My window of opportunity is closing: We are (hopefully) going to take an RV trip to Columbus, Ga in March to do some WW kayaking/Supping/fishing/thawing. It hinges a little on the health of a pet. But if we do go, that means I have basically the rest of Feb to focus and then I'll just be grabbing hours where I can once we get back. So I'm definitely cramming, and unlike you, getting NOTHING done around the house.
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 11:06 am
by Dan_Smullen
You’ll squeeze it all in.
If you do get to head south, and need some hydration at the half way point in Richmond, be sure to give me a shout. Very strong New England style IPA game here in town!
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 11:46 am
by VT_Jeff
Dan_Smullen wrote: ↑Mon Feb 08, 2021 11:06 am
Mapping route as we speak!
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 12:33 pm
by bamaguy0
VT_Jeff wrote: ↑Mon Feb 08, 2021 8:50 am
...getting NOTHING done around the house.
Wait. We're supposed to keep up with housework too?
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 1:11 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon Feb 08, 2021 12:33 pm
According to Dan, not me!
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 8:47 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Feb 08, 2021 11:46 am
White water too!
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 8:52 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Feb 08, 2021 1:11 pm
It's not too bad. Every time I bring something home from the shop for the house, I use it to disguise more material for the boat.
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 10:06 pm
by Fuzz
You guys need to refine your methods. When I get something I do not want to have to explain I put it in the shop and let it set for at least one week. Then if I am asked about it I can truthfully say " Oh I have had that in the shop for a long time"
Re: Jeffs FS14 LS
Posted: Mon Feb 08, 2021 10:13 pm
by VT_Jeff
Fuzz wrote: ↑Mon Feb 08, 2021 10:06 pm
Crimony! My wife uses that one all the time!
"Where'd this come from?"
"Oh, I've had that"
"Yeah, had it ever since ups was here this morning!"
<shrug>
Re: Jeffs FS14 LS
Posted: Tue Feb 09, 2021 7:29 am
by Dan_Smullen
That’s my go to response for fishing equipment.
Ok Jeff. Enough goofing off. Back to building!
Re: Jeffs FS14 LS
Posted: Tue Feb 09, 2021 1:24 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Feb 08, 2021 8:47 pm
White water too!
Very, very interesting! How's the fishing in the area in march?
Re: Jeffs FS14 LS
Posted: Tue Feb 09, 2021 1:30 pm
by VT_Jeff
White water too!
"Being an urban run, many natural and manmade hazards exist such as low head dams, keeper holes, rebar, hidden debris, and strainers. "
The Lower James, AW
We have some paddling friends in the area and are actually going to consider if it may be a good alternative to Columbus, def a shorter drive for us. Elaine feels like there is not the same quality play-boating that Columbus has but that could get out-weighed by other factors, so appreciate you bringing it up!
Re: Jeffs FS14 LS
Posted: Tue Feb 09, 2021 8:41 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Feb 09, 2021 1:24 pm
White water too!
Definitely can be good! As you know, the weather effects it all. River fishing here in town depends a lot on water levels. We had a great day wading last spring, but I'll do my best to get you on a few in March.
1-1/2 hours east and it's all about stripers and trout in the salt.
Lemme know...
Re: Jeffs FS14 LS
Posted: Tue Feb 09, 2021 9:24 pm
by Jeff
Good stuff Dan!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sat Feb 13, 2021 6:44 pm
by VT_Jeff
The fence moved, plank wasted. Take II coming up.
Re: Jeffs FS14 LS
Posted: Sun Feb 14, 2021 12:42 pm
by Dan_Smullen
What happened Jeff? Catastrophic failure?
Re: Jeffs FS14 LS
Posted: Sun Feb 14, 2021 8:44 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Feb 14, 2021 12:42 pm
I spent some considerable time ensuring the plank would stay tight to the fence, tight to the deck, level on indeed and outfeed side. Halfway through the cut, I realized the fence was not gripping, so instead of a parallel cut, I got a wavy taper. Pricey lesson but not the end of the world.
Re: Jeffs FS14 LS
Posted: Sun Feb 14, 2021 8:50 pm
by bamaguy0
That's a pretty extravagant setup. Whatcha making?
Re: Jeffs FS14 LS
Posted: Sun Feb 14, 2021 9:00 pm
by VT_Jeff
bamaguy0 wrote: ↑Sun Feb 14, 2021 8:50 pm
Rubrail brightwork. The idea is to rip that plank in half, then resaw the halves with the tablesaw, then scarf the quaters for length, then glue them on. If the photos of my completed boat feature a plastic rubrail, you'll know that things didnt improve.
Re: Jeffs FS14 LS
Posted: Sun Feb 14, 2021 9:12 pm
by bamaguy0
Ahhh. I see.
Yeah. Not even gonna try for pretty on that. Already planning for a Taco Marine rubrail on the outside of mine.
Re: Jeffs FS14 LS
Posted: Mon Feb 15, 2021 12:19 am
by cracked_ribs
Brightwork is the meth of boatbuilding...you experiment with it once, and suddenly you can't stop and it wrecks your life. You burn money and relationships in the pursuit of artful grains, rich wood tones and matched halves.
I'm pretty sure I've never built a boat that didn't end up with a bunch of brightwork that I later kicked myself for doing but I can never stop myself, either. It's too pretty.
Good luck on the next cut!
Re: Jeffs FS14 LS
Posted: Mon Feb 15, 2021 10:14 am
by VT_Jeff
cracked_ribs wrote: ↑Mon Feb 15, 2021 12:19 am
I'll assume you know what you're talking about but personally, to-date,
to-my-knowledge, I have never, actually experimented with...brightwork.
You nailed it on all points, CR, that was hilarious.
My driftboat(oh, did I mention that I previously built a driftboat? no? really? I'm sure I must have mentioned it....) has bright 'wales and most of the interior is bright save for the sole and a 2" rand up the sides. Makes a HUGE difference in the asthetics, IMO. A lot of guys leave their driftboats completely bright but as I've debated on other threads, contiguous square yards of bright plywood is not my cup of tea.
My last sailboat(Leisure 22, very aptly named for it's pace of sail) had bright rubrails which always made me scratch my head a bit. "Why the !@#$ would they put brightwork in the one place where it is GUARANTEED to get beat up?". I'm going to pay that little mystery forward on my own boat, and let the nephew/niece who wrestles the FS14LS from my cold, dead hands ponder the same question.
Anyway, blame Seaslug, he started it with the walnut. And then Coach piled on with his Ash. Bad influences!
Re: Jeffs FS14 LS
Posted: Mon Feb 15, 2021 10:47 am
by Jaysen
HA!
I'm in need of new "bright" components. I started looking up teak and mahogany and mentioned it to the boss lady. When I woke up a bit later she calmly pointed at the various places the she has requested be painted around the house. I got the message. Now I need some aspirin.
Re: Jeffs FS14 LS
Posted: Mon Feb 15, 2021 10:50 am
by VT_Jeff
Jaysen wrote: ↑Mon Feb 15, 2021 10:47 am
HA!
Right there with you! Last night my wife got a splinter from the
living room floor. Once we got it mostly out, I was like "Ok, I really need to do some sanding/smoothing..........on my BOAT, SEE YA!"
Re: Jeffs FS14 LS
Posted: Mon Feb 15, 2021 8:04 pm
by VT_Jeff
Waiting on supplies and doing some cleanup. Getting the deck panel joints smooth. I routed a good sized bevel at the joints and then filled it with a wood flour mix in hopes that the seam wont become visible after time.
I had glued the side panels in place too hastily and then realized they were not flat due to a poor plane job on the sheer. So I reopened the sheer joint, used wedges to get them flat, and filled the gap with gel magic. I wanted 0 drip/run for this and gel magic delivered.
My rear deck side cut was not great so I attached a fence with packing tape and filled it out with more gel magic.
Spent some time smoothing the hatch lips etc, more to do. This kind of work is a little mindless and enjoyable after weeks of non stop problem solving.
Re: Jeffs FS14 LS
Posted: Tue Feb 16, 2021 11:54 am
by Dan_Smullen
I like what you did at the shear line. A little wonkiness there would have haunted you forever. Good to be able to make the corrections.
Build on!
Re: Jeffs FS14 LS
Posted: Tue Feb 16, 2021 12:18 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Feb 16, 2021 11:54 am
Absolutely! Would have made it a major chore to get the solid rubrail on at least, and then probably would have caused puddling and astethic issues. It took a little while to convince myself to rip it back open with a circular saw but like a lot of things, the actual fix was not nearly as bad/difficult as I had imagined it would be, super glad I did it.
Knowing what I know now, I would have spent a LOT more time getting the boat stitched correctly, getting the ply-rails fabricated precisely, and getting the sheer planed correctly. I got lulled into the "gaps are good" mantra and just kept carrying errors forward until they literally ended up on top. In the end, I think it will all work out.
Re: Jeffs FS14 LS
Posted: Tue Feb 16, 2021 12:52 pm
by cracked_ribs
Definitely good call on fixing that...it sucks to go back to that stuff but there's a few spots where mistakes remain visible and haunt you forever. Sheerline is a huge one.
You always hear that whole "gaps are good" thing but I have mixed feelings about it. Epoxy and wood flour doesn't flex, so it's not like you're getting an expansion joint out of the deal; I would guess that gaps any greater than 50 thou or so are unnecessary, and they make some stuff hard to be precise around.
I was a little more tolerant of gaps on my current boat - I think in a couple of spots I went up to about 1/8" - but my last one was small so I fitted it carefully just because, and I kept the gaps in the hull structure down around 20 thou and never regretted it at all. As long as I could get thickened epoxy uniformly through the joint, I didn't see the point in being sloppy about things. And it made for a very clean assembly process. I did it in my living room, and found it kept my epoxy usage low, and at the end of the build I didn't have a single drop on the living room floor. I think that was largely because I took a "careful fit" approach to everything.
Anyway on the plus side, epoxy is so forgiving, you can fix all that stuff, which you did, so...onwards!
Re: Jeffs FS14 LS
Posted: Tue Feb 16, 2021 1:05 pm
by VT_Jeff
cracked_ribs wrote: ↑Tue Feb 16, 2021 12:52 pm
There's a fair amount of epoxy on my living room floor. And I'm building the boat in the basement. So you're a sight neater than I am!
Pretty sure my next boat will be an Oughtred Tammie Norrie, glued lapstrake, which should theoretically mean a lot more planing/chiseling/cutting and a lot less mixing/spreading/sanding, though there will be some of that. But I will definitely need to re-calibrate my gap standards. I made some shaker nightstands for a while maybe 20 years back after taking a fine woodworking class in Boston(amazing 2 week, full-time class, I'd recommend it to anyone!). Dovetailed drawers cut by hand, mortise and tenon apron/leg joints, etc. It was a lot of fun and I miss the joinery aspects. Back then I had not yet figured out the "do indoor things in winter darkness and outdoor things otherwise" thing so I gave it up. Looking forward to getting that started in the Fall if all goes to plan.
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 1:29 pm
by VT_Jeff
Trailer. Check. Brand new but already filthy and covered with road salt.
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 3:38 pm
by Dan_Smullen
Sweet! Major milestone achieved!
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 4:23 pm
by bamaguy0
Big difference between you and I! I picked mine up in shorts!
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 5:07 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sat Feb 20, 2021 3:38 pm
Yep, starting to feel real!
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 5:08 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Feb 20, 2021 4:23 pm
Now that just ain't fair!
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 5:11 pm
by bamaguy0
VT_Jeff wrote: ↑Sat Feb 20, 2021 5:08 pm
It was a chilly 50 degrees today so I had my Florida Winter coat on...a light pullover.
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 5:14 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Feb 20, 2021 5:11 pm
I just don't know how you guys get any boats built with nice weather in February!
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 10:01 pm
by VT_Jeff
Got 3/4 hatches hinge-mortised. Spent a few nights after work this week practicing the procedure on scrap and it paid big dividends. By the third hatch, I knew about how many chisel strokes were needed to clean the corners.
For the 30mm wide hinges I bought, I used a 30mm forstner bit to create a template out of 3/4 mdf
which I screwed to the deck/lid. The template had brad holes along the x axis to make alignment easier. Once the template was screwed down I removed the brads.
I made a second template to cut the deep section at the edges, screwed to the deck/lid through the same holes to ensure alignment.
To set the right depth for the 2 router passes, I first used the hinge body
and then a scrap of 9mm ply
I spun the dial up a half turn on the hinge and a full turn on the ply to get a little extra depth
A centering drill bit made the screw holes a snap.
I eased the edges with some 60grit and they're about done.
The complete cast of tools is shown below.
The 3 separate drills made things go smoothly without the need to constantly move bits around. I used some brad's through scrap to set the lid spacing on all sides before marking/attaching the template.
Re: Jeffs FS14 LS
Posted: Sat Feb 20, 2021 10:54 pm
by cracked_ribs
That's a lot of fiddly work but sure satisfying to do it right, I think.
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 7:34 am
by bamaguy0
Great overview! I'm not skilled woodworker by any stretch of the imagination so I would be racking my brain on how to do that with any degree of repeatability. I'll be saving that post for sure.
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 7:38 am
by bamaguy0
Are those friction hinges or are you to have to put stays in as well?
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 7:42 am
by Jeff
Nice!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 9:02 am
by VT_Jeff
bamaguy0 wrote: ↑Sun Feb 21, 2021 7:38 am
They are not. Friction hinges cost more than I could bring myself to spend. These can open 180 degrees and lie flat on themselves so stays not really needed and no plans now to add any.
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 9:06 am
by VT_Jeff
cracked_ribs wrote: ↑Sat Feb 20, 2021 10:54 pm
Agreed. I didnt really have any choice. I tried freehanding the router shy of the traced line and finishing with a chisel but was totally unable to get the radius clean. With 16 radius's, the fiddling was the far lesser evil.
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 10:56 am
by Browndog
Looks Great! I used a similar process to recess the hinges on the FS 19 I built. Really makes a difference on the finished boat. Remember to account for the thickness of the epoxy, primer and paint coats, other wise the hinges will end up being a bit proud of the surface.
Re: Jeffs FS14 LS
Posted: Sun Feb 21, 2021 11:59 am
by VT_Jeff
Browndog wrote: ↑Sun Feb 21, 2021 10:56 am
Thanks. I gave the depth pin 1/2 a dial up after setting it to the hinge depth for the epoxy etc, it's a gamble but they should end up pretty flush.
Re: Jeffs FS14 LS
Posted: Tue Feb 23, 2021 6:14 am
by Dan_Smullen
Nice job Jeff. The consistency is worth every moment of fiddling. I like the OG Makita too!
The next step is to save the jig “for next time” and put it on a shelf for 10 years. ( what happens in my garage)
Re: Jeffs FS14 LS
Posted: Tue Feb 23, 2021 8:46 am
by fallguy1000
Nice work. People can use this thread as a hinge mortising tutorial almost.
Re: Jeffs FS14 LS
Posted: Tue Feb 23, 2021 9:20 am
by VT_Jeff
Dan_Smullen wrote: ↑Tue Feb 23, 2021 6:14 am
The OG Makita is on modified duty, it's close to being a pensioner! Got it in '91 to install audio/video systems in SoCal tract homes in a very former life.
Re: Jeffs FS14 LS
Posted: Tue Feb 23, 2021 9:23 am
by VT_Jeff
fallguy1000 wrote: ↑Tue Feb 23, 2021 8:46 am
Appreciate that Dan! I did finally go back and fix the photo order.
This morning I over-drilled all the screw holes and started filling, I didn't dam some up well enough so there will need to be a Part II on that.
Re: Jeffs FS14 LS
Posted: Tue Mar 09, 2021 9:24 am
by VT_Jeff
Starting to think about the cockpit trim inside radius puzzle. I played with a few different ideas with little success. My chief technical advisor, Dan S, wisely recommended trying laid up veneers instead of cutting or bending the 3 inch radius. To that end I ordered the veneers that Dan found for me and started making the Male and female molds for the layup. I used a super simple radius jig on the bandsaw to make the molds out of pt plywood stacked up with hot glue.
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 10:04 am
by VT_Jeff
This is the simple radius jig used to make the Male and female forms.
The two holes are the pivot points for the single piece being cut into the two mold halves.
The distance between the edges(not centers) of the holes = the thickness of the final layup, in this case 1/4".
The distance from the outside of the blade to the center of the outside hole = outside radius of the trim piece I need, in this case 3"
I did not really account for the blade thickness properly but I suspect my margin of error is at least as large so not going to sweat it.
My piece was scrounged scrap and none too pretty but it should work just fine, or at least it should not account for total failure, that will be due to something else.
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 3:50 pm
by Dan_Smullen
Jeff! This is beautiful! I can’t wait to see the veneer sandwich!
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 3:54 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Mar 10, 2021 3:50 pm
Thanks. The veneer showed up today and looks great. Expensive shipping but very fast. It may be at least a few days or more before I get back to playing with that stuff, though I'm chomping at the bit to. Thanks again for the direction on this! Fingers crossed it all comes together but it's just gravy so no stress.
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 4:01 pm
by Dan_Smullen
Shoot, Man. Glad to have something constructive to share.
How thick is the mold?
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 4:12 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Mar 10, 2021 4:01 pm
It's 6/4 made from 2 pieces of 3/4 PT ply stacked up. That height will dictate the h dimension of my cockpit trim, which I had planned around that size anyway and should probably look about right. The outside trim/rubrail will probably come in around 2.25 or so.
One small regret: the inside faces of my side decks are straight, giving the interior of the cockpit a super square look. Seaslug and others made the inside face mirror the curve of the deck, much more attractive. I think that a curved inside face along with the radius'd, trimmed inside corners would have been really sharp. That particular ship has sailed though.
Re: Jeffs FS14 LS
Posted: Wed Mar 10, 2021 4:20 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Mar 10, 2021 4:12 pm
Get it on the next build...
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 12:58 am
by VT_Jeff
Deck is glassed. 3.5 months of final prep to go.
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 1:08 am
by VT_Jeff
This is what my final wiring ended up like. Took a few iterations to get to this but worth the hassle.
Still to do is installing and wiring 4 switches in the console, one of my many "while paint dries" projects coming up.
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 7:50 am
by Jeff
Nice work VT_Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 10:06 pm
by Dan_Smullen
Nice progress as always, Jeff.
Is that a removable cover? On in the first pic, but off in the 2nd?
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 10:23 pm
by VT_Jeff
First trial run at inside radius trim lamination came out decent and lifted some of the fog for me. The jig needs to bend a little bit more and the pieces need to be longer.
I spent some time fiddling with ways to clamp for the glue up, hoping to avoid the need for fasteners.
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 10:25 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Mar 16, 2021 10:06 pm
Exactly Dan. It's mainly to prevent dripping onto the blocks, which are somewhat exposed in the cooler hole.
Re: Jeffs FS14 LS
Posted: Tue Mar 16, 2021 10:38 pm
by Dan_Smullen
You’ll figure out the clamping. Part looks great! Grain look good against the solid stock?
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 7:37 am
by VT_Jeff
Dan_Smullen wrote: ↑Tue Mar 16, 2021 10:38 pm
Grain does not really match. Not sure if I'm bothered enough to do anything about it, we'll see.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 2:18 pm
by TomW1
VT_Jeff wrote: ↑Wed Mar 17, 2021 7:37 am
Jeff it is hard to match grain even from the same tree unless you request matching veneer, then it gets expensive. Unless they are going to be side by side I don't think I would worry about it.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 2:42 pm
by VT_Jeff
TomW1 wrote: ↑Wed Mar 17, 2021 2:18 pm
They will actually be in series: the inside of my cockpit rim will have trim running all the way around it. For the corners, which are radius 3", I'm making the bent lam inside radius parts from doug fir veneers I ordered, 8-9 layers stacked up and then bent as you can see above. The straight runs will use solid vert-grain doug fir stock that i already have. So the solid stock will be running directly into the veneers on each side of each corner, joined by a simple 45 degree scarf.
So the difference in grain will make it quite obvious that it is not a continuous piece running the straights and the curves, which isn't the end of the world, but this is all purely aesthetic to begin with, so getting it aesthetically right is definitely worth some consideration, time will tell exactly how much.
As I mentioned, I could "cheat" and veneer the faces of the straight runs, though something about this doesn't sit quite right, unsure exactly what.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 3:57 pm
by Dan_Smullen
I wouldn't let it bother you. You'll be the only one who ever thought about it.
Longer form and longer parts might make it easier to blend things together.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 4:05 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Mar 17, 2021 3:57 pm
You are absolutely most likely correct. Absolutely no one but me notices any of the details I slaved over on the drift boat
. Luckily this works the other way and no one notices the errors either.
I'd like to darken the fir but know that epoxy doesn't bond well over oil stains, any experience in this department/recommendations?
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 4:15 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Mar 17, 2021 4:05 pm
Sorry sir. None whatsoever.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 4:35 pm
by Jaysen
Bend... steam is your friend. Make a small steam chamber and make it happen.
Color... alcohol stain. Look into shellac based finishes. The stains can be applied separately. To get penetration you increase the alcohol content.
My old school woodworking comes in handy.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 6:59 pm
by VT_Jeff
Jaysen wrote: ↑Wed Mar 17, 2021 4:35 pm
I considered steam but bending 1/4" stock to R3 with basically 0 run rate with steam bending isn't filling me with confidence. Not ruling it out but going to run the glue-lam route for now.
I'll checkout the alcohol stain idea, that's new to me.
Here's take 2 on the bent lam glue-up with longer pieces and a tighter jig.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 7:06 pm
by Jaysen
VTJ, the steam route will make all bends easier. With the glue up route it reduces the strain on the parts being laminated. If you steam long enough you can bend some pretty thick pieces.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 7:23 pm
by VT_Jeff
Jaysen wrote: ↑Wed Mar 17, 2021 7:06 pm
The laminated veneers bend effortlessly without steam, the challenges come later in making use of the part, but I think a few iterations will get the kinks worked out.
I did find this related to S3 epoxy over stain, which is easing my mind a bit about darkening the fir.
I also read that West Systems tested a bunch of stains for adhesion. Minwax oil failed but just about everything else passed with 4 day cure of the stain. Of course I have quarts of minwax oil on my shelf, though probably 20 years old. Amazing how you buy stain, put it on the shelf, and the next time you reach for it its 20 years old. Scary.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 7:43 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Mar 17, 2021 7:23 pm
My dad probably used 10 gallons of Minwax "Ipswich Pine" when I was growing up.
Several cans still on a shelf somewhere I'm sure. Pretty sure I've bought more than I've used too.
Carry on, Jeff. You'll be in good shape with the longer ends. Looks good!
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 7:52 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Mar 17, 2021 7:43 pm
Too funny!
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 9:40 pm
by Dan_Smullen
HA! I love it!
A classic, woody tone that represents tradition.
Re: Jeffs FS14 LS
Posted: Wed Mar 17, 2021 10:57 pm
by TomW1
I to love Ipswich Pine could probably go out to the shop and find a couple of qts.
Not doing it at this time of night with a major storm over us.
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 5:55 pm
by VT_Jeff
Latest bent-lam inside radius trim effort looking better. Some process refinements still to be made but my confidence is growing. Fun learning new stuff like this.
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 5:57 pm
by VT_Jeff
TomW1 wrote: ↑Wed Mar 17, 2021 10:57 pm
I'm guessing by your posts today tgat you survived, very glad to hear it!
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 6:03 pm
by Jaysen
That’s purty!!
How many layers?
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 6:30 pm
by VT_Jeff
This is with a very dry fit of an adjoining piece for grain match judging.
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 6:31 pm
by VT_Jeff
Jaysen wrote: ↑Thu Mar 18, 2021 6:03 pm
That’s purty!!
How many layers?
Thanks. 9 layers of veneer laid up with gorilla glue.
I'm thinking that if I darken it a bit, against the oyster white deck, it will really "pop" and give it a pretty shippy look, which is what us puritans from New England are always after.
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 7:19 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu Mar 18, 2021 6:30 pm
That looks great, Jeff. A little wood flour and the seams will disappear. Shippy and nautical indeed!
Re: Jeffs FS14 LS
Posted: Thu Mar 18, 2021 7:24 pm
by Jaysen
Dan_Smullen wrote: ↑Thu Mar 18, 2021 7:19 pm
I was going to suggest a 10deg camfer on the mating surfaces. A light sand should make the joint all but invisible.
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 8:30 am
by Jeff
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 10:18 am
by VT_Jeff
Jeff wrote: ↑Fri Mar 19, 2021 8:30 am
Appreciate it!
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 5:23 pm
by VT_Jeff
New toy arrived today. Some assembly required, apparently.
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 5:45 pm
by Jaysen
Primary or secondary locomotive force?
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 6:46 pm
by VT_Jeff
Jaysen wrote: ↑Fri Mar 19, 2021 5:45 pm
Ideally, secondary. This 20hp is primary, though with the way I've overbuilt this, may need to move up to a 90 like jondavis did on his fs14ls.
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 6:53 pm
by Jaysen
Why not shoot for the 115?
Re: Jeffs FS14 LS
Posted: Fri Mar 19, 2021 7:42 pm
by VT_Jeff
Jaysen wrote: ↑Fri Mar 19, 2021 6:53 pm
Probably smart, just get right to it. You too. Maybe we can get a deal if we buy 2.
Re: Jeffs FS14 LS
Posted: Thu Mar 25, 2021 6:20 pm
by VT_Jeff
Playing around with the console dash to avoid the real work of deck fairing. The steering column will be coming through the center of this somewhere.
I could not find a switchbar suitably small enough and so went with 4 switches for nav lights, deck lights, bilge pump, and troll battery charger.
Re: Jeffs FS14 LS
Posted: Sun Mar 28, 2021 2:03 pm
by VT_Jeff
More fiddly bits.
I relocated the switches and USB port on the dash and then made a new front and rear dash sans the extra holes and got a coat of e on them. I added the radius because I didnt want them to feel left out.
I have been going around the sheer and filling the edge out to a temp rubrail. I want the deck finished and painted before I add the actual, bright rubrail because a want a clean line between them, not just a taped off line. So I need to get the sheer as close to perfect as possible so there will be no gaps to fill and mess up my clean line. Hard to tell in the photo but that's a temp, proud rub rail with packing tape and gel magic filling the gap.
I decided I wanted a little more overhang on the top and sides of the dash so I'm scabbing some pieces to the console.
I received the steering arm for the outboard and got it attached. The controls on this boat will be a bit bizarre. Wheel steering but all else on the motor. Over time I may migrate more controls forward if this setup proves too weird for even my rube-goldbergish tastes: I never met a problem I couldn't over complicate.
I got a coat of quick fair over the whole deck, eventually. Fishgitr built a hull faster than I got a single coat of fairing compound on my deck, but I'm guessing he doesn't have nearly as much tv to watch as I do, so I'm not going to feel too badly.
Next up: more fiddly bits.
Re: Jeffs FS14 LS
Posted: Sun Mar 28, 2021 8:45 pm
by Dan_Smullen
VT_Jeff wrote: ↑Sun Mar 28, 2021 2:03 pm
The entire enterprise is fiddly bits.
What type of steering, Jeff? Hydraulic or cable?
Re: Jeffs FS14 LS
Posted: Sun Mar 28, 2021 9:37 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Mar 28, 2021 8:45 pm
Cable. Seastar/dometic. Original plan was stick steering but I wasn't stoked on the available systems.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 1:18 am
by cracked_ribs
So how will that work, the steering on the console and the throttle/shifter on the motor - is it a locking throttle on the tiller kind of thing? You set it to whatever throttle position, then cam a locking lever down or something and steer on cruise? I'm trying to picture this.
It did strike me on my own boat that I could put forward steering on, and use a tiller extension with a U-joint to control the throttle, but then I came up with a whole other plan that's not important here.
I looked at stick steering a bit but for what it is, I thought it seemed kind of pricey. But then maybe I haven't looked in enough detail at wheel steering systems and I'm underestimating their cost.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 7:41 am
by VT_Jeff
cracked_ribs wrote: ↑Mon Mar 29, 2021 1:18 am
Yes, the throttle has a locking ring with variable tension.
I also have a troll control servo thingy but not sure that will get in the game. I have not yet been able to find a way to integrate the servo with the honda, something I may play with during the summer with the help of the marina mechanic who gave it to me.
The stick steering seemed expensive to me as well and hard to find info on.
The real issue with my system is the no feedback helm, which seemed like a good idea but presents problems. It means I cant steer with the tiller. So I'll have it setup with a quick disconnect out of the gate to make sure docking is easy enough with the wheel but have the option to go tiller.
My antique ski boat had pretty weird controls, vernier throttle on the dash, shifter on the tree, and I had that wired after 5 years or so. So I'm not too worried.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 9:40 pm
by VT_Jeff
Not sure if all 4 will be usable but I have definitely improved the process for making these inside trim pieces and have a few sheets of fir veneers left. Short term, I need to assign one to each corner, tape, clamp in place and cut/fill the deck to a smooth fit. Like the rubrails, this trim will go on after the deck around the cockpit is finished to ensure a clean line between the deck and trim.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 9:48 pm
by Dan_Smullen
What don’t you like about them Jeff? They look good.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 9:54 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Mar 29, 2021 9:48 pm
Some may have defects on the edges that will require removing too much width. Since they will be bright, I can't really fill gaps. I'm going to work them all down to at least one very good edge, and then use whichever ones meet the width criteria, remake new ones where needed.
On the first couple I was not getting consistent width from the strips, took some practice to get smooth cuts, esp where the grain waved.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 10:12 pm
by VT_Jeff
And more gap-filling around the deck. I may have been a little deep in the boxed wine when I lofted this panel.
Re: Jeffs FS14 LS
Posted: Mon Mar 29, 2021 10:19 pm
by VT_Jeff
Round one of fairing on the console dash extension pieces:
And got my console wiring terminals squeezed on. Super simple wiring on this boat.
Re: Jeffs FS14 LS
Posted: Sun Apr 04, 2021 6:26 pm
by VT_Jeff
Finally got around to making and using a pup-deck for the cat-raft.
It was a fast/cheap build but worked great and Bow loved his first trip on the river. No fish were harmed during the testing of this deck, unfortunately.
Just got this action shot from a paddling buddy.
Re: Jeffs FS14 LS
Posted: Sun Apr 04, 2021 8:35 pm
by Dan_Smullen
Good way to get the whole family out at once.
Nice rig! A smallmouth guru I know in MD fishes out of one just like it, minus the pup deck.
Re: Jeffs FS14 LS
Posted: Mon Apr 05, 2021 10:35 am
by VT_Jeff
This weekend I finally got around to forming the cockpit radiuss with the curved trim. Looks like all 4 trim pieces will work. This was one of the final steps before I can start painting the deck.
- 20210405_102149.jpg (48.16 KiB) Viewed 128876 times
I also started painting the under deck areas. This is totally backwards, should have been done before the deck went on, but it was just too cold for paint at that point and I'm too cheap to run the heat as long/high as was necessary. Definitely not going to earn myself a Seaslug with the appearance of these compartments, but...........oh well. Will give the most visible areas one more coat and call it done.
Re: Jeffs FS14 LS
Posted: Mon Apr 05, 2021 11:13 am
by lucastefanel
VT_Jeff wrote: ↑Mon Apr 05, 2021 10:35 am
Really amazing job Jeff, working wood as you are doing is just art!
Re: Jeffs FS14 LS
Posted: Mon Apr 05, 2021 11:20 am
by VT_Jeff
Dan_Smullen wrote: ↑Sun Apr 04, 2021 8:35 pm
Thanks Dan. Our goal is to do some serious whitewater/fly-fishing trips out west with this rig someday, hopefully soon. I've been whitewater kayaking/canoeing for many years (as you know) but the whole oar thing is a bit new still, lots to learn. Really fun though.
Re: Jeffs FS14 LS
Posted: Mon Apr 05, 2021 11:55 am
by VT_Jeff
lucastefanel wrote: ↑Mon Apr 05, 2021 11:13 am
Appreciate it Luca, thanks for tuning in. I'm watching your aluminum CSX25 project with great interest also, incredible commitment required for something like that! Will be an amazing boat when finished.
Re: Jeffs FS14 LS
Posted: Tue Apr 06, 2021 8:02 pm
by VT_Jeff
As recently discussed with some fellow fs14ls builders, I added a quick and dirty glass cap to the transom.
Crude but should be effective.
Re: Jeffs FS14 LS
Posted: Mon Apr 12, 2021 11:28 am
by VT_Jeff
Couple quick updates.
The fs14ls has a transom corner peculiarity: the deck corner ends up proud of the transom corner. Maybe not an issue if you're not going out of your way to overcomplicate the rubrails, but definitely an issue if you are. I made a quick
n dirty form to fill in the gap.
And the result, with a little quickfair:
I promised the wife I would make her some outdoor furniture, this is the design mockup:
After playing around with it I decided to make it with a foam/vinyl cushion instead of slatted. It will pivot up into the "console" when not in use.
Re: Jeffs FS14 LS
Posted: Mon Apr 12, 2021 11:53 am
by cracked_ribs
I like it!
Re: Jeffs FS14 LS
Posted: Mon Apr 12, 2021 11:58 am
by Jeff
Nice work!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Apr 12, 2021 12:45 pm
by TomW1
+3
Re: Jeffs FS14 LS
Posted: Tue Apr 13, 2021 11:22 am
by VT_Jeff
Fiddling with my foldup seat. Below is my current plan for supporting it when deployed. I'm not convinced it's the best option. Seems like a lot of leverage on some small areas. I'm thinking of maybe some side straps or front legs that stow/deploy by gravity. Open to ideas.
Re: Jeffs FS14 LS
Posted: Tue Apr 13, 2021 12:05 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Apr 13, 2021 11:22 am
I love what you're doing with the seats. It's a classic outdoor furniture look! Teak would be nice, and less splintery than fir.
It's a tough ask to support a seat like that on dry land, nevermind skipping across the water. I wonder if something like this would work, with the horizontal stretcher continuous between the uprights. Stainless pin from McMaster for the pivot.
Fusion will be helpful sorting out the geometry.
Re: Jeffs FS14 LS
Posted: Tue Apr 13, 2021 2:51 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Apr 13, 2021 12:05 pm
Interesting thought Dan, I had not considered a stretcher.
But, it's still going to concentrate the weight into a few square inches. I think I really need some better geometry/angles. I think that some swing down legs are going to be the ultimate solution so I'm going to go straight there, contrary to my usual "what's the absolute longest path between the problem and solution" approach. That way I'll be less worried about the Mrs. falling on her a$$ when we hit a wake. Not that it wouldn't be hilarious, it would, cause I could say "Told you not to eat all those Newmans Cheese Squares" and then I wouldn't really remember anything after that.
Re: Jeffs FS14 LS
Posted: Tue Apr 13, 2021 3:32 pm
by Marshall Moser
Make the "hinge" ride in a slot, and use a stretcher from the front edge of the seat to a point on the upright. So when folded, the hinge point moves downward and the front of the seat moves in. That way, your stretchers can be the same length.
Edited to add:
https://www.greatlakesskipper.com/parke ... h-aluminum
Here's the mechanism I think might work best.
Re: Jeffs FS14 LS
Posted: Wed Apr 14, 2021 9:19 am
by Dan_Smullen
VT_Jeff wrote: ↑Tue Apr 13, 2021 2:51 pm
Worse than being killed by your wife will watching your beautiful work break. Precautions best taken.
Don't be tempted by the simple path. Anyone can take that.
Re: Jeffs FS14 LS
Posted: Thu Apr 15, 2021 1:47 pm
by VT_Jeff
Marshall Moser wrote: ↑Tue Apr 13, 2021 3:32 pm
Edited to add:
That's pretty slick Marshall. I like how the supports double as arms. appreciate the input!
Immediate plan is to use swing down legs that will nest in the seat when stowed and deploy via gravity. Gives me the most support bang for the buck/best geometry. I'm re-making the frame out of Doug Fir, the seat will have a foam/vinyl cushion and will inset in the frame.
The "slatted" seat idea was not working: that design really needs the slats to overhang the frame by a decent margin and I just don't have room for that.
If all goes to plan*******, the seat frame and legs will be bright-finished, matching the rub rails and cockpit trim. Everything else(meaning the console itself) will be painted oyster white like the hull/deck. I'm going to add a back rest, also vinyl over foam, and possibly a leg cushion that will wrap the deck edge in front of the seat, which I hope will give the whole thing a bit of a "lounge" chair look, we'll see.
Clearly this passenger seat will take longer and cost more than the rest of the boat combined, and will likely never get used, but it's an itch I need to scratch for whatever reason.
Re: Jeffs FS14 LS
Posted: Thu Apr 15, 2021 6:19 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu Apr 15, 2021 1:47 pm
None of us would be here if we wanted to take the easy route. Build on, Jeff.
If we only get to do this once, it will be a shame to not put all of our vision into it.
Re: Jeffs FS14 LS
Posted: Thu Apr 15, 2021 8:52 pm
by Mojosmantra
Some creative stuff going on around here. Very nice.
For some reason, I’m no longer getting automatic update messages - gotta check into that.
Re: Jeffs FS14 LS
Posted: Sat Apr 17, 2021 10:48 am
by VT_Jeff
Take 3 on the guest seat frame. I thought it would be fun to add some dovetails to the mix since the frame will be bright. Been a while since I did any of that but the magic of epoxy and wood flour will help hide any rust.
Still lots to do but the hard parts are in the can.
Re: Jeffs FS14 LS
Posted: Sat Apr 17, 2021 11:53 am
by cracked_ribs
Edited to add:
Really like the way it's shaping up! But holy cow is that bolded sentence ever relatable.
"I'm basically done, I just had this simple idea to bright finish this one little spot and have a flip-up lid for a radio..."
NINE MONTHS AND $27000 LATER "finally satisfied with the finish, but don't really like having the radio under a lid so may scrap it."
That's such a perfect encapsulation of the boatbuilding experience, it's basically a conceptual haiku.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 9:05 am
by VT_Jeff
cracked_ribs wrote: ↑Sat Apr 17, 2021 11:53 am
Glad you support the impractical aspects of boat building as much as I do! It ain't "messing about in boats" without some measure of messing.
These may not pass the muster in Shaker country, but I'm putting them in the W column.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 9:17 am
by VT_Jeff
Far less fun and exciting than hand cutting dovetails is repairing transom paint where I was careless with dripping epoxy.
The entire deck and cockpit still need to be painted so these repairs are very literally a drop in the bucket. I also needed to extend the paint over the corner caps I made so some transom painting was inevitable even without the mess ups.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 3:10 pm
by Dan_Smullen
Nice touch as always, Jeff. The dovetail would not have remained relevant if it were not the best joint for some applications. I think the wood flour in the seam will too be a nice detail.
Aren't you shooting at a June completion guestimate?
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:20 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Apr 18, 2021 3:10 pm
July 4th is my drop- dead date, gives me may and june to paint the deck. I know some guys would have it done in a weekend. I ain't them.
Elaine snagged this hawg of a 'bow on our local, stocked tailwater. On a bugger she tied this winter. Best. Wife. Ever.
Bow, our pup, seems to love 'bows as much as we do! Normally he's a lean-jetted 2 stroke with a high idle but for reasons unknown, he really settles down on a float trip, which is flipping outstanding! Great day!
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:28 pm
by VT_Jeff
Thanks, as always! There was a period when I was pumping these nightstands out and was considering turning it into a part-time money-losing venture. Very fun but after number 11 or 12 the itch was thoroughly scratched.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:32 pm
by Jaysen
VT_Jeff wrote: ↑Sun Apr 18, 2021 6:20 pm
I’ve got one of those too! Still trying to get mine properly adjusted to boat life. Any tips.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:41 pm
by VT_Jeff
Jaysen wrote: ↑Sun Apr 18, 2021 6:32 pm
I wish I could take some credit/offer advice but it's just how he is, incredibly! We bring a ton of treats and kongs and bully sticks but he mostly likes to just look around.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:49 pm
by Jaysen
VT_Jeff wrote: ↑Sun Apr 18, 2021 6:41 pm
The time Mary has been on a moving boat she pulls the
Spirit of Ecstasy routine underway. I’m hoping she’s just irritated that we haven’t untied from the dock.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 6:55 pm
by VT_Jeff
Jaysen wrote: ↑Sun Apr 18, 2021 6:49 pm
She looks stoked!
Our pup has only been on small boats so far, sailboat will be another experience, hopefully in May, I'll let you know how it goes.
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 7:34 pm
by Jeff
Good lucking pup!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Apr 18, 2021 9:29 pm
by Fuzz
That is a great picture of the wife, pup and Bow! I enjoy catching them around here but always let them go. I am not a big fan of how the are to eat.
Re: Jeffs FS14 LS
Posted: Mon Apr 19, 2021 9:06 am
by VT_Jeff
Fuzz wrote: ↑Sun Apr 18, 2021 9:29 pm
Thanks Fuzz. A lot of these are in catch/release areas so we don't eat many ourselves.
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 12:48 pm
by VT_Jeff
I had my regular customer test fit the guest seat. It got a "yeah, I guess this will work. Where does the pup go?" I'll take it.
Pretty slow progress otherwise. Actually had some friends over this weekend, kinda weird in the brave new world. I got skunked but my buddy got this sweet brown on our local "wild" stretch. Maybe wild, maybe a holdover, maybe swam over the dam.
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 1:05 pm
by VT_Jeff
Just realized I missed drip loops going from my fuse box to dist block. There is not a whole lot of room to work with under the deck of this boat and I struggled to get the wiring done with the space I had. I think one solution would have been to put the fuse box and dist block on the underside of the rear deck. Not great for access but it would keep them dry and eliminate the drip issue. Next boat.
- Capture.PNG (182.71 KiB) Viewed 139711 times
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 1:40 pm
by Mojosmantra
That console/seat rocks!
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 2:14 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Apr 27, 2021 1:05 pm
80/20 rule. Right? No drip loops probably isn't the end of the world, not result in catastrophic failure. Probably...
Recognizing an area that COULD be improved is important, but no reason to lament.
The boss happy on her seat is more important than a drip loop. Build on!
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 2:35 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Apr 27, 2021 2:14 pm
Yeah, I'm not sweating it, just noting it for future builders to take note of.
The boss happy on her seat is def a big win!
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 2:55 pm
by VT_Jeff
Mojosmantra wrote: ↑Tue Apr 27, 2021 1:40 pm
Thanks Trent, would love to give you a close up look at it on Big Pine Key sometime!
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 9:41 pm
by bamaguy0
Hey Jeff on the transom edge fiberglass did you wrap it around or just directly on top?
Re: Jeffs FS14 LS
Posted: Tue Apr 27, 2021 9:57 pm
by VT_Jeff
bamaguy0 wrote: ↑Tue Apr 27, 2021 9:41 pm
I just laid it on top. I didnt want to create a new fairing adventure. I left all the edges wide and once the epoxy cured I trimmed it, sanded the edges smooth and then applied some epoxy to the edges with a gloved finger to seal them.
Re: Jeffs FS14 LS
Posted: Wed Apr 28, 2021 9:06 am
by VT_Jeff
Something I would differently in hindsight: if adding any type of console/seat, I would move Frame B forward by about 12" to open up a little leg room. This may mean a floor frame where B is now and a new "false" frame at the front of the cockpit, or whatever the design details turn out to be. But we have, in our case, acres of front deck while legroom in the cockpit is super tight. This is a +10% already so I guess I'm really starting to bend the intended design, admittedly. "Plans were meant to be changed" as they say.
Re: Jeffs FS14 LS
Posted: Wed Apr 28, 2021 9:18 am
by bamaguy0
I shifted my Frame B by about 8" if I recall because of my console.
I followed the guidelines of max spacing between frames and didn't violate that.
Re: Jeffs FS14 LS
Posted: Wed Apr 28, 2021 9:19 am
by bamaguy0
VT_Jeff wrote: ↑Tue Apr 27, 2021 9:57 pm
Gotcha, thanks. I had a moment of panic last night thinking I needed to do that before the flip, but then I remembered I was gonna paint the transom short so I can fair that in later once I put in the deck and motorwell.
Re: Jeffs FS14 LS
Posted: Wed Apr 28, 2021 10:15 am
by VT_Jeff
bamaguy0 wrote: ↑Wed Apr 28, 2021 9:18 am
Great planning. 8" would be plenty if that's the max allowable change.
Re: Jeffs FS14 LS
Posted: Wed Apr 28, 2021 3:34 pm
by TomW1
Vt_Jeff don't sweat the drip loops. Instead tie some string at where the loop would have been and the moisture will follow the string down. Old sailors trick.
Boat is looking great!!!
Re: Jeffs FS14 LS
Posted: Thu Apr 29, 2021 10:22 pm
by Mojosmantra
I was going to ask, what the heck is a "drip loop", but this response made it crystal clear. Never heard of such a thing and now I have learned something new.
Re: Jeffs FS14 LS
Posted: Thu Apr 29, 2021 10:26 pm
by bamaguy0
Mojosmantra wrote: ↑Thu Apr 29, 2021 10:22 pm
Good practice for power cords coming off an aquarium also. Basically anywhere electricity and water mix you want the water to go to a low spot that isn't a connection.
Re: Jeffs FS14 LS
Posted: Thu Apr 29, 2021 10:33 pm
by Mojosmantra
Yeah, I'm skipping it altogether and reducing the cockpit size back to the grab rail location. My version is standard % and I couldn't see any legroom at all or any real usefulness of that space - the way I fish anyway. On the few occasions where I have a passenger, they'll be sitting on a cooler on the deck - and yelling at me to slow down
. I imagine it'll be like riding on a giant surfboard at 25 knots
Re: Jeffs FS14 LS
Posted: Fri Apr 30, 2021 9:34 am
by VT_Jeff
TomW1 wrote: ↑Wed Apr 28, 2021 3:34 pm
Good idea Tom, thanks!
Re: Jeffs FS14 LS
Posted: Fri Apr 30, 2021 9:36 am
by VT_Jeff
Mojosmantra wrote: ↑Thu Apr 29, 2021 10:33 pm
Man, I just hope my boat will go anywhere near 25knots, screaming passenger be damned!
Re: Jeffs FS14 LS
Posted: Fri Apr 30, 2021 10:41 am
by bamaguy0
I'd take 25 knots. Not much more than that, though.
I do plan on retuning my 25hp to 30!
Re: Jeffs FS14 LS
Posted: Fri Apr 30, 2021 11:15 am
by VT_Jeff
As I consider this further, I have very minimal run going into the fuse box, to the point were condensation on the fuse box itself will probably generate as much moisture as anything coming down those wires, so I am going to do some serious not-worrying about it.
I've been knocking out micro-tasks while waiting for the weather to warm up enough to where I dare start painting the deck.
I got the steering arm hardware sorted out finally,
got a coat of epoxy on my guest seat frame,
got some fairing compound on my dashboard and one side of my console,
got my guest seat-back backer-board cut to the right shape(it will be upholstered)
put another coat of paint under the decks(not as worried about painting these areas in the cold)
got some ring terminals on the battery line
figured out how to retain the steering-worm sleeve on the "wrong" side of the helm(zip ties to the rescue)
Also, in a fit of insanity, I just ordered/paid for the plywood for my next build, picking it up Saturday in Boston. Will be building a glued-lapstrake row/sail boat somethig like what's shown below. I've had the book "How to build Glued Lapstrake Wooden Boats" on my nightstand for probably 6 years, maybe more, but it's only within the past year or so that it's started to actually feel feasible. My two SnG boats have done marvels for my confidence with the various processes involved to where I actually, finally feel like I can get it to completion. Plan is to start on that project in Sept or October but with the price/availability of plywood, figured I'd get it now and sit on it and not run the risk of a winter without a boat to build, a very very frightening thought.
- Capture.PNG (544.09 KiB) Viewed 131433 times
Re: Jeffs FS14 LS
Posted: Sat May 01, 2021 8:22 am
by Dan_Smullen
This is the boat building equivalent of Babe Ruth calling his hit to left field.
If all the water is hard for a few months, I can see the importance of having a project or 10 in the works. No doubt she’ll be clean and refined when she comes together.
Re: Jeffs FS14 LS
Posted: Sat May 01, 2021 11:48 am
by cracked_ribs
Buying the supplies for the next boat before the current one is done... you've got it bad bro!
Re: Jeffs FS14 LS
Posted: Sat May 01, 2021 12:47 pm
by VT_Jeff
cracked_ribs wrote: ↑Sat May 01, 2021 11:48 am
SCORE!
Re: Jeffs FS14 LS
Posted: Sat May 01, 2021 12:54 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sat May 01, 2021 8:22 am
Hilarious! Maybe I'll name the boat "Landsdowne Street"
and yes: long winters with unusable water and 4pm darkness requires careful coping plans!
My goal is very similar to the boat pictured: off white hull, bright stem/keel/transom, bright sheerstrake and bright interior. Hopefully oiled brightwork, time will tell.
Plywood is in hand, need to get some cherry closer to home for the backbone, some mdf for molds and away we go(in 6 months or so).
Re: Jeffs FS14 LS
Posted: Sat May 01, 2021 4:53 pm
by VT_Jeff
No argument. I've had less healthy addictions, never a more expensive one though.....
Re: Jeffs FS14 LS
Posted: Wed May 05, 2021 5:58 pm
by bamaguy0
Btw, I'm trying to reply to your PM's but they keep getting stuck in my outbox.
Re: Jeffs FS14 LS
Posted: Wed May 05, 2021 6:00 pm
by Jaysen
Things move out of your PM outbox when the recipient reads the message. It’s like a read receipt but less intuitive. I would change the behavior if I could but... I can’t. Sorry.
Re: Jeffs FS14 LS
Posted: Wed May 05, 2021 6:01 pm
by bamaguy0
Jaysen wrote: ↑Wed May 05, 2021 6:00 pm
Ohhhh i had no clue it worked like that! Good to know. Thanks Jaysen!
Ok so Jeff, I just look like a babbling idiot then!
Re: Jeffs FS14 LS
Posted: Wed May 05, 2021 6:46 pm
by VT_Jeff
bamaguy0 wrote: ↑Wed May 05, 2021 6:01 pm
I suspect everyone on here has been through the exact same exercise. I know I have!
Re: Jeffs FS14 LS
Posted: Sat May 08, 2021 11:50 am
by VT_Jeff
Simple scarfing jig, stolen from "the art of boatbuilding" on youtube. Works fine.
Re: Jeffs FS14 LS
Posted: Sat May 08, 2021 12:40 pm
by VT_Jeff
Re: Jeffs FS14 LS
Posted: Sat May 08, 2021 2:16 pm
by VT_Jeff
Finally got the "next boat" materials unloaded and stored. 6 sheets of 6mm marine okume, 3 sheets of 1/2 birch for molds, 1 sheet of 3/16 luan for mold templates.
I altered my bench to make it easier to get sheets in and out of storage.
Re: Jeffs FS14 LS
Posted: Sat May 08, 2021 2:35 pm
by Dan_Smullen
VT_Jeff wrote: ↑Sat May 08, 2021 12:40 pm
Dust collection: check.
This is only acceptable if that cup has already been used to mix epoxy half a dozen times, and so caked with hardened silica that is no longer usable. Otherwise, kind of a waste of a valuable mixing cup.
I have my girls are on a strict diet of 4 cups of vanilla yogurt a day, to be sure I always have an clean cup standing by.
Re: Jeffs FS14 LS
Posted: Tue May 11, 2021 10:45 pm
by VT_Jeff
For about the 3rd time, I got the deck surfaces vacuumed, free of dust and grease, ready for primer. Bring on some heat, please! Had to build a fire this morning so my mouse would stop shaking!
I decided against my finger hole idea for hatch openers and picked up some of these pop-a-ma-jigs.
I over-drilled and neat-filled some ugly holes for them in the hatch lids. Not sure why it looks oval.......
- 20210511_224036.jpg (361.94 KiB) Viewed 130555 times
Will start priming when the mercury stops hiding. Till then, hopefully more of these:
I stole that fish from the Mrs. She had been working a spot for 30 minutes, I asked for a turn with her rod, first cast SLAM!
Re: Jeffs FS14 LS
Posted: Wed May 12, 2021 1:17 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sat May 08, 2021 2:35 pm
Thats very smart! Funny you should mention that cause I looked at the photo and saw it was lowfat plain and thought YUCK! Who ate a whole quart of that?
I am not above doing some dump-picking from the transfer station recycling roll-off to augment my mixing cup supply, I'm guessing that's where it came from.
Re: Jeffs FS14 LS
Posted: Wed May 12, 2021 5:24 pm
by Dan_Smullen
How wide of a strip can you scarf with the jig?
Have you ever built one of the router versions? I've never tackled one but can see the benefits.
Pretty fish too! Sniping one in front of a fishing partner is always sweet.
Re: Jeffs FS14 LS
Posted: Wed May 12, 2021 6:04 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed May 12, 2021 5:24 pm
Just 4 inches probably, trim only. I may make the router version for the next boats planks.
Re: Jeffs FS14 LS
Posted: Wed May 12, 2021 9:30 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed May 12, 2021 6:04 pm
Gotcha. Thought you might be prepping for the next build.
Re: Jeffs FS14 LS
Posted: Thu May 13, 2021 12:54 am
by Fuzz
Sounds like to me we both are still having the same weather problem
The good news is no worry from heat stroke
Re: Jeffs FS14 LS
Posted: Sun May 16, 2021 7:14 pm
by VT_Jeff
Elaine hooked into 5 fish over the weekend but only boated this one. I'm trying to convince her to stop crushing her barbs but shes a trout hugger.
Trying to land a fish while anchored in current is proving to be tricky. You're not only fighting the fish, you're fighting the current. This fish, like the others she hooked, was turning her 4 weight rod into a noodle. Her 6 weight is under repair, my 5 weight was in use:
The other thing that's a bit tricky is releasing a fish while anchored in current: ideally you give the fish an opportunity to recover while you hold it in the water but doing this in current is definitely not straightforward.
Nice problems to have
Re: Jeffs FS14 LS
Posted: Sun May 16, 2021 7:35 pm
by Jaysen
I can offer a bit of help on the last one… fish glove. I hate them but it is much easier to hold the fish without damaging it.
I also learned to release them from the transom. The little eddies create enough backflow to assist in the slow release.
I love to eat trout but I’m a barbless freshwater trout guy. They are easily damaged and it’s worth losing a few to know you are preserving a fishery to harvest later. Saltwater trout… they get barbs from me. Mostly because I fish big enough bait to avoid under limit fish.
Re: Jeffs FS14 LS
Posted: Sun May 16, 2021 7:56 pm
by bamaguy0
Awesome 'bow!
I'll 2nd the barbless for freshwater trout! I'm a softie when it comes to those beauties!
Re: Jeffs FS14 LS
Posted: Sun May 16, 2021 8:31 pm
by Dan_Smullen
Nice fish! The dog appears to agree.
4 wt on that class of fish in current has to be tough, but like you said, "good problems to have.".
Re: Jeffs FS14 LS
Posted: Thu May 20, 2021 8:49 pm
by VT_Jeff
You cant paint without "pain".
Got a second coat on much of the deck, then ran out.
On staycation this week and have been on the river every day, feels great. Got a little boat building/painting done and waged war on some knot weed on the property.
Crappy photo but this little guy was hanging out at our lunch-fishing spot down the street.
Re: Jeffs FS14 LS
Posted: Thu May 20, 2021 8:56 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun May 16, 2021 8:31 pm
Yep. Elaine just ordered a new 6 weight, when the broken one finally comes back well sell it to a friend.
We lost a few more and boated a few more yesterday. today elaine hooked one but it shook off right away. Tomorrow is our last chance, at least for this week.
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 12:03 am
by Fuzz
Question, the bow looks like the tail has been clipped. Does that mean they are hatchery fish?
Alaska does not have a lot of different wildlife but what we have we have a lot of. There are more eagles around here than seagulls I think.
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 6:46 am
by VT_Jeff
Fuzz wrote: ↑Fri May 21, 2021 12:03 am
The rainbows are stocked, yes. I think they clip some adipose fins for some tracking data, the tail fin may just be a mutation, these fish are total science experiments by now.
We have a pretty healthy bald eagle population but nowhere near any other bird, there may be 10-20 along the 20 mile stretch of river that we use regularly, if I were to guess based on my observations. You see them most times out, but normally only one, maybe two.
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 9:23 am
by PapaDave
That boat is looking sensational. Really nice work.
Dave
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 9:37 am
by Jeff
Really nice work VT_Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 9:57 am
by narfi
Looking good!
I am the worst at estimating how much paint and epoxy I will need for any given project
so feeling your pain
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 10:55 am
by Mojosmantra
Looking really nice Jeff!
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 5:20 pm
by VT_Jeff
Thanks all!
Jamestown Distibutors got me another quart of paint here nearly as quickly as Jeff Morrow, so props to them, was not expecting it until tuesday! So that means I can continue the process through the weekend.
Skunked today on the river but another amazing day out there, great weather, small crowds. The new pup is really taking to boating life, which is a huge relief.
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 7:57 pm
by VT_Jeff
Painting progresses.
I'm going to use the non-skid grit on the majority of the deck, so I think my next coat will just cover the borders, then let that dry, mask, and start the non-skid coats.
Re: Jeffs FS14 LS
Posted: Fri May 21, 2021 8:02 pm
by TomW1
Looking good.
Sounds like a plan to me.
Re: Jeffs FS14 LS
Posted: Sat May 22, 2021 8:46 pm
by VT_Jeff
TomW1 wrote: ↑Fri May 21, 2021 8:02 pm
Looking good.
Re: Jeffs FS14 LS
Posted: Sat May 22, 2021 10:09 pm
by VT_Jeff
Staged photo belying the actual state of the build.
The unpainted strip around the cockpit is the glue surface for the trim. Any other unpainted areas are holidays.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 9:11 am
by Mojosmantra
Need to see one with the chair
Also, curious about the term “holiday” - suspect it’s builders jargon that I’m unaware of.
Looks great Jeff.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 9:20 am
by VT_Jeff
Mojosmantra wrote: ↑Sun May 23, 2021 9:11 am
Looks great Jeff.
The seat is in the upholstery shop(my bedroom) and wont be available for photos for a bit, but I'm at least as curious as you how it will look alttogether.
I thought that "Holiday" was a ubiquitous term meaning a spot you missed while painting, but you are the second person in as many days to claim unfamiliarity, the first being the Admiral(wife). May be time for a poll.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 11:37 am
by cape man
Having taken holidays myself while painting, I knew what it was.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 12:32 pm
by narfi
VT_Jeff wrote: ↑Sun May 23, 2021 9:20 am
Until a year or so ago I knew for a fact that fl.oz. represented a floral ounce. I used it for some reason at work and we spent at least one entire coffee break time discussing it. I was the only one who had heard it including one co-worker who had gone through chef school.
After some googling by both sides of the argument I was only able to come up with a couple of very obscure and old references to support what I "knew".
I was an avid reader in my youth often consuming a novel per day including lots of older books including many classics as well as just whatever books I could get my hands on. (This being the days of paper books and no digital access) My best guess is that the term was used in one of those books and being the first to enter my brain is what stuck as fact. I don't know....
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 1:35 pm
by VT_Jeff
narfi wrote: ↑Sun May 23, 2021 12:32 pm
A floral ounce? That is making me laugh, out loud. For some reason!
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 3:14 pm
by VT_Jeff
I used my chopsaw scarfing jig to join 2 8' lengths of doug fir. I had to resaw the fir first. Went pretty smoothly, used the tablesaw.
Started touching up the transom where I had some paint issues, few more coats needed still.
The end is in sight, though not particularly near.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 9:23 pm
by TomW1
VT_Jeff wrote: ↑Sun May 23, 2021 3:14 pm
Jeff that is going to be a beautiful boat. Please be careful resawing on a table saw. That can be one dangerous step.
Re: Jeffs FS14 LS
Posted: Sun May 23, 2021 10:00 pm
by VT_Jeff
TomW1 wrote: ↑Sun May 23, 2021 9:23 pm
Thanks Tom!
The key to a safe resaw is to have the blade height at just less than 50% of the piece height, send it through, flip the piece on the vertical plane end for end( I had to take it outside) and send it through again. The blade is never exposed and the two halves remain joined by a hair. You then split them with a handsaw or band saw and plane the small ridge. Someday I'll get my bandsaw setup to resaw but in the meantime this works. Thin kerf blade helps too.
Re: Jeffs FS14 LS
Posted: Mon May 24, 2021 7:22 am
by bamaguy0
I had never heard of the term holiday(used in this context) until I started reading about boat painting.
Re: Jeffs FS14 LS
Posted: Mon May 24, 2021 8:43 am
by Mojosmantra
Google says "Within the coating industry, these defects are referred to as holidays, which are areas of the substrate that have not been properly coated, subsequently creating flaws in the coating film. Holidays include misses, inadequate coating thicknesses, and inclusions and pinholes, all of which register as anomalies."
Re: Jeffs FS14 LS
Posted: Mon May 24, 2021 9:07 am
by VT_Jeff
Mojosmantra wrote: ↑Mon May 24, 2021 8:43 am
VICTORY! SWEET, SWEET VICTORY!
Re: Jeffs FS14 LS
Posted: Mon May 24, 2021 9:49 pm
by VT_Jeff
I hung a rub rail on for visualization. It doesnt pop a whole lot because it's so light, but it will darken up like honey after a little time in the sun if my driftboat is any guide.
Anyway, I think it's too tall. Distractingly tall. I'm thinking that if I remove 1/2" it will blend better.
Or maybe leave it.
Re: Jeffs FS14 LS
Posted: Mon May 24, 2021 9:59 pm
by VT_Jeff
My bride: the perfect, deadly blend of shop-o-holic and fish-o-holic!
Re: Jeffs FS14 LS
Posted: Tue May 25, 2021 1:58 am
by Fuzz
Your wife and mine would get along good together. I think she likes to fish more than I do. Only problem is if she has her line out for more than 5 minutes and no fish it is my fault for taking her to a bad spot
Re: Jeffs FS14 LS
Posted: Tue May 25, 2021 2:17 am
by TomW1
Dang Jeff you said your wife was going up to 6 wt fly line. Didn't say she was going to get a new Battenkill reel and fly rod.
She buy you one also.
Re: Jeffs FS14 LS
Posted: Tue May 25, 2021 7:52 am
by VT_Jeff
Fuzz wrote: ↑Tue May 25, 2021 1:58 am
YES!
and....
"Rising fish over there on the right! HURRY UP!"
(I row over as quickly/quietly as humanly possible)
"You scared him! He's gone!"
(Good Grief!)
The fact that I have a wife who has a burning desire to be on the boats that I build is about as great as it gets, even if I'm getting reprimanded for shitty guiding skills occasionally. I'll take it.
Re: Jeffs FS14 LS
Posted: Tue May 25, 2021 7:55 am
by VT_Jeff
TomW1 wrote: ↑Tue May 25, 2021 2:17 am
Yeah, not sure why she also needed a new reel and a new line, I thought it was just the rod that broke.
I have a 3, she has a 4, I have a 5, she has 2 6's, and we have a 7 and a 9 that we're not sure who's is who's. Just need a putter and a wedge.
Re: Jeffs FS14 LS
Posted: Wed May 26, 2021 8:41 pm
by bamaguy0
Very nice. I wish I could get my wife more excited about fishing, but it's not a big deal. She's more than happy just chilling on the boat and reading a book while I fish.
It's too bad she's scared to death of the thought of getting up on the poling platform and trying to spot fish for me.
Re: Jeffs FS14 LS
Posted: Thu May 27, 2021 11:53 am
by cape man
I can attest to this! My wife and I still mimic Fuzz's wife "David I am not happy! Why are we fishing here? There are no fish!" But she out fished me BIG time, and thoroughly enjoyed letting me know!
Mine will fish if the fish are biting, but loves just chilling on the boat otherwise.
Re: Jeffs FS14 LS
Posted: Thu May 27, 2021 12:58 pm
by Mojosmantra
This is my situation - no interest until I find the fish and figure out the bite. Then she’s all in.
Re: Jeffs FS14 LS
Posted: Thu May 27, 2021 1:32 pm
by VT_Jeff
Mojosmantra wrote: ↑Thu May 27, 2021 12:58 pm
mmm, that's pressure!
Re: Jeffs FS14 LS
Posted: Fri May 28, 2021 6:47 pm
by VT_Jeff
Super-seamster. Not.
This one is for practice and I did learn quite a bit. Getting the corners boxed correctly on the thread welder is one challenge, getting the corners stapled correctly is another.
Re: Jeffs FS14 LS
Posted: Fri May 28, 2021 7:24 pm
by bamaguy0
Woah! Wasn't even planning to attempt that myself. Might change my mind after I call around for quotes.
Few years back I was trying to fix up a '77 280Z and was going to reupholster the seats myself, but I at least had something to go by. That project was abandoned at a major loss when I moved from Alabama to Florida.
Re: Jeffs FS14 LS
Posted: Sat May 29, 2021 3:16 pm
by VT_Jeff
bamaguy0 wrote: ↑Fri May 28, 2021 7:24 pm
Too bad about the Z. There is one here in town that's pretty nice, modernized a bit. If I was gonna do a car, it would be a late 70's Toyota 4x4. May yet!
Re: Jeffs FS14 LS
Posted: Sun May 30, 2021 7:55 am
by bamaguy0
VT_Jeff wrote: ↑Sat May 29, 2021 3:16 pm
It was a learning experience. I learned rust repair was not for me!
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 5:52 pm
by VT_Jeff
Getting vaxxed wont save you from the need to mask in my workshop!
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:09 pm
by bamaguy0
Now that's clean. How'd you cut the radii in the tape?
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:24 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon May 31, 2021 9:09 pm
Thanks. It's not as clean as it looks in the photos but the non-skid will be the same color as the deck so small imperfections shouldn't matter.
I used a variety of objects for radius templates, marked the radius on the tape with a pencil, and then used an exacto knife to cut along the line. Had my best results when I didnt try to get the cut to flow: short cuts with my palm on the deck, turning slightly after each jab. Short like a few mm per jab. This kept me on the line. It took about 7 hours start to finish for the whole mask, but none of it was difficult so the time flew. I need a lot more grit for this method, only got one lb. and could not do a whole coat with it. In this method, you put on a coat, load it with grit, let it dry, then sweep off the excess and repeat. Takes a lot of grit to load it properly, at least for me.
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:33 pm
by bamaguy0
Oh OK, so you're cutting with the tape in place? I was nervous about that because I wouldn't want to cut into the paint. Will you do a final coat with straight paint?
That's interesting on the application process. I think I saw that somewhere...what's the reason to do it that way over just mixing the grit into the paint?
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:46 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon May 31, 2021 9:33 pm
I'm definitely cutting into the paint but those cuts are immediately getting refilled with paint when I coat it so I'm not too worried. Theres a layer of glass and epoxy so I'm not getting near the wood.
I read good things about this method over adding the grit to the paint and I liked the idea. I did it the other way with my driftboat and it didnt turn out well at all, but it may have been user error. I wanted this deck really gritty for the dog and this seemed like the best bet, time will tell and I'll keep you posted, literally.
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:49 pm
by VT_Jeff
For the hinge radii, I can see where you could precut the tape and then put it on the deck. But for all the corners, I cant see it, it would be a real chore imo.
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 9:54 pm
by bamaguy0
VT_Jeff wrote: ↑Mon May 31, 2021 9:49 pm
No I totally agree. That's what I was dreading!
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 10:06 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon May 31, 2021 9:54 pm
Btw, this is the Z I mentioned. I tend to prefer more original looking stuff but I really dig this for whatever reason. Actually not sure if it's a 260 or 280.
Re: Jeffs FS14 LS
Posted: Mon May 31, 2021 10:09 pm
by bamaguy0
That's slick! I like it. I had aspirations of something similar. Little blend of new with old.
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 10:33 am
by VT_Jeff
Front view of the non skid mask. I'm not thrilled with the shape near the bow but it's going to be under a TM mounting plate.
This boat is going into service for july 4th weekend come hell or low water(Lake Ontario is quite low atm) so I'm forging ahead and living with some imperfections, like the symmetry issue with this mask on the front deck.
I got the dash about done and mounted to the console, will be quick to wire once the console is installed.
Got the seat cushion remade and the backrest made, getting these installed in the console over the next day or two.
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 10:36 am
by bamaguy0
Crunch time! Looking good!
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 2:15 pm
by cracked_ribs
Man you're really moving on her now!
I like the anti-skid layout, that's tough to do well, I think.
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 2:27 pm
by Jeff
Really well done VT_Jeff!!!
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 3:25 pm
by TomW1
Looking nice Jeff. Keep up the good work.
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 5:58 pm
by Dan_Smullen
cracked_ribs wrote: ↑Tue Jun 01, 2021 2:15 pm
I watched a time lapse video on FB recently of a guy doing this on a large sail boat, and thought, damn that’s a lot of work. Has to be a challenge.
Definitely in site of the finish line, and she’s looking great, but hurry up! Clock is tickin’!
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 6:05 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Jun 01, 2021 5:58 pm
I'm glad I didn't see that video or I may have changed my mind and just covered the entire deck without taping. I've seen that done here and it's not a bad way to go.
Thanks for noting the ticking clock, I had forgotten for 3.5 seconds.
Before I started boatbuilding, a month would be about the longest I would expect any project to take. With this, a month is barely enough time for the last minute stuff!
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 6:11 pm
by VT_Jeff
bamaguy0 wrote: ↑Tue Jun 01, 2021 10:36 am
TomW1 wrote: ↑Tue Jun 01, 2021 3:25 pm
Jeff wrote: ↑Tue Jun 01, 2021 2:27 pm
Appreciate y'all staying tuned, thanks very much!
Re: Jeffs FS14 LS
Posted: Tue Jun 01, 2021 9:13 pm
by PapaDave
Looking wonderful Jeff. The final sprint always seems to take a lot of time but the to do list is getting near the end for you. Really looking forward to seeing you on the water with your family and sporting a big smile. Keep the momentum rolling!
Dave
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 1:17 pm
by VT_Jeff
PapaDave wrote: ↑Tue Jun 01, 2021 9:13 pm
Dave
Thanks a lot Dave, appreciate the encouragement and will most def post some pics of splash day!
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 2:03 pm
by VT_Jeff
Opinions sought on size/positioning/color/etc for boat name before I order the letters. I'm really a bit at a loss.
The boat is oyster white/largo blue with some DougFir trim. I'm so far thinking silver with black shadow but I'm really indecisive on it. Also really not sure how far forward back, and how high/low to put the decal.
If I can't decide on something I'm really happy with I may just forgoe the name altogether, which would be a shame since a friend spent a fair amount of time developing that custom font for me from an Allman Brothers album. I'm a bit of a fan of that band, that song, and of blue skies in general.
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 7:55 pm
by Fuzz
Most boats in this area have the name up close to the bow. But I am not sure there is a bad place to put the name.
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 8:06 pm
by Jaysen
Fuzz wrote: ↑Fri Jun 04, 2021 7:55 pm
I thought the “proper location” was on the transom over the port of origin. Other locations are just out of convenience for other to hail over the radio.
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 8:32 pm
by TomW1
I think most of us put the name on the rear sides since we use outboard motors. I know that is where mine are and a lot of the other boats I have seen have been. In most states they require that the numbers and license be on the bow on each side so that sort of blows that. For the 14 LS I would say no more than 6" or they will be in the water.
Really just measure the distance between the rail and water line and decide on a height you would like and decide where it would look good, cut out some paper letters and tape them to the side. Depending on the length of the name and since it is the FS14 I would probably start about a foot from the transom.
Re: Jeffs FS14 LS
Posted: Fri Jun 04, 2021 11:28 pm
by Fuzz
Jaysen wrote: ↑Fri Jun 04, 2021 8:06 pm
I am pretty sure you are correct Jaysen. Transom, port and starboard bow are what you see on documented vessels.
Re: Jeffs FS14 LS
Posted: Sat Jun 05, 2021 8:53 am
by bamaguy0
I think scooting it back maybe 1/4-1/2 of the distance to the transom would be good.
Also if the goal is for it to be shown completely and to maximize it's size, you might wanna hold off and take some tape with you on her first splash. Mark it in the water so you know how she sits.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 1:33 am
by TomW1
Jeff all of us can suggest positions till we are blue in the face and it won't do you any good. Just cut out some paper that is a size you think you would be happy with and tape it to the side. If that does not rattle your chimes move it and try again. You will eventually find a place or give up. My favorite is some where from center of the boat back, but that is me. I don't know how much free board you have between the water line and the rail, but figure out what size lettering would look good between them and use that for your test paper cut out whether it be 7-9". Then just cut the paper to the length of the lettering you will have.
That is all I can suggest to you to help you make a decision. Yea it means a little work on your part but it will be worth it.
Take care guy and good luck. You are the one who has to be happy, Not any one here.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 7:30 am
by VT_Jeff
Ok, I'm going to pull it back towards the transom and try centering it in the blue strip, all of which should be well out of the water. Transom doesnt really work and it's not going to be documented so theres no requirements.
There are no boats like this around southern vt or lake ontario so I figured I'd let the people who see them weigh in on the topic. I dont want to get it to FL at some point and find out I've made some embarrassing faux pas that's going to have the locals snickering at the boat ramp. Like wearing white after labor day or whatever.
I got the blow boat splashed. I let the yard clean/wax/bottom paint it out of pure generosity and not because I was feeling lazy. Safe to say they did a much better job than I ever did on it, it looks really good.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 8:43 am
by Jaysen
My condolences for having a boat registered in NY.
What is she again? My eyeball-ID-foo is questionable even when the maker and model are printing in day glow pink.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 8:57 am
by VT_Jeff
Jaysen wrote: ↑Sun Jun 06, 2021 8:43 am
83 c&c 29 Mkii
And yes, compared to vt, at least, ny is a royal pita in terms of registration. I'd be pushing my luck registering the sailboat in vt since it spends 365 days in ny.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 12:45 pm
by cape man
We wear white anytime we can here in Florida. Reflects the sun and heat. I like the name right where you mocked it up.
Re: Jeffs FS14 LS
Posted: Sun Jun 06, 2021 4:14 pm
by Dan_Smullen
Typical convention for small boats in the South East is boat name on the transom, boat builder name on the side, up high, just forward of the stern. I always assumed I would make the name more square in orientation so it fits on the transom adjacent to the outboard. But with that font, you can’t go wrong. It will be a shame not to splash that bling on there somewhere.
“Good ol’ Sunday morning, bells are ringing everywhere”
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 8:52 am
by VT_Jeff
cape man wrote: ↑Sun Jun 06, 2021 12:45 pm
After a few hot days here, finally, I can believe it!
Appreciate it!
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 8:59 am
by VT_Jeff
Dan_Smullen wrote: ↑Sun Jun 06, 2021 4:14 pm
Great point there Dan. Nothing says that Blue Sky is the name, maybe it is the builder, like PiheraCraft. That's another reason I have no problem putting it on the side where the builder name usually goes. With that in mind, I'm now thinking I'll go a little smaller than I had orginally planned and maybe a little subtler in color to blur the line a little more between name/builder.
"Goin' to Carolina won't be long till I'll be there!"
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 9:02 am
by Dan_Smullen
Blue Sky Boatworks definitely has ring to it!
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 9:04 am
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jun 07, 2021 9:02 am
My thoughts exactly!
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 9:19 am
by Mojosmantra
yes it does.
I think the location is good Jeff and agree, a little smaller.
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 6:00 pm
by bamaguy0
Someone should register trademark that one!
Re: Jeffs FS14 LS
Posted: Mon Jun 07, 2021 6:12 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon Jun 07, 2021 6:00 pm
Yeah, unfortunately, our mutual friend, EJ, already has, though Elaine thought they had stopped production on those.
Re: Jeffs FS14 LS
Posted: Tue Jun 08, 2021 8:30 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Jun 07, 2021 6:12 pm
Ahhhh. Forgot about that one.
Re: Jeffs FS14 LS
Posted: Tue Jun 08, 2021 12:04 pm
by VT_Jeff
'Bow manning the nav station on our first excursion after splash. I didnt get a chance to get the rig re-tuned so we just motored around a bit in the bay, did some casting, and 'Bow took his first ever swim, which was amazeballs. Pup loves the sailboat as much as the driftboats, really great news!
Re: Jeffs FS14 LS
Posted: Tue Jun 08, 2021 12:20 pm
by Jeff
Good looking pup!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Jun 13, 2021 11:06 pm
by VT_Jeff
Here's the Rub(rail)
I spent friday night, sat morning and much of today getting my bright fir verrtical rub rails attached. What a chore! The first thing I needed to do was to cut, per side, 73 different shims to get the existing rub rails vertical. I think Dan S. used a similar approach for his strakes and I think Trent used a few similar shims to get his rub rails vertical. I put them on continuously from bow to stern, it was a fair amount of work. Once I got them all cut and lined up I pre-coated the existing rail and the shims with neat epoxy, held each in place and checked for fit with a square, then drove a staple through the shim to hold it in place. Very tedious but the best I could come up with.
Once all the shims were cured in place I went back over with a chisel to remove any high spots that would prevent the rub rail from sitting flush against the deck. Next I applied neat epoxy to the shims and the mating face of the fir rib rail, let that setup bit, then laid a pretty good bead of thickened epoxy along the length of the fir rubrail mating face, and then used my 6 hands to clamp it in place. The port side went pretty smoothly as I could start at midship and then work fore and aft, letting it extaden past the bow and transom. ON the starboard side, I needed to get it up flush at the bow, which meant I needed to clamp from the bow to the stern, and that was a LOT more difficult. Took hours today to just get that one rubrail into place and there were defintiely more gaps than on the poret side. I'll fill the gaps with goo so not a big issue but it was a frustrating job that didn't end with a lot of satisfaction due to those gaps.
I don't have greta photos but this is a shot of the 'staged" shims. I would cut them 2 at a time, measering the angle between the 2 next shim positions and assuming that that measurement would always be good enough for 2 shims. Once I got them staged I numberde them all so that when I inevitbaly knocked a bunch on the floor, I knew where they went.
This is the glue up: kind of pita to clamp and many times I considered saying "screw it!" quite literally and adding some screws, but in the end I never did.
this is the almost-finished port-side product, it needs a little planing and cleanup. Also need to be flush-cut at the bow and transom.
This is a shot of the starboard side shims staged up and ready to go and the overhang of the port bow.
There's probably a good chance that this wide piece of dog fir will move on me and crack or check and that I'll have to circular saw it off and replace it with painted plywood or an extrusion or something, time will tell. I can live with it, its cosmetic. After seeing the amount of time and effort it took to get them on, if I had to do it again, I probably would. Definitely worth the hassle.
Re: Jeffs FS14 LS
Posted: Mon Jun 14, 2021 6:02 am
by Dan_Smullen
No question, 74 shims per side to coat and fit is extremely tedious, but as you said, worth the hassle.
Maybe I missed it in a previous post, but what bay are you in with the sail boat?
Re: Jeffs FS14 LS
Posted: Mon Jun 14, 2021 9:31 am
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jun 14, 2021 6:02 am
Henderson Bay, NY. The mooring is in Henderson Harbor, we rent a seasonal cottage at a marina at the end of the harbor(Harbors End Marina), this is like our 16th year there. The prevailing wind is SW so Henderson Bay is ideal: it can be blowing pretty good and the bay is still relatively quiet. It's about a 6 hour sail to Kingston, ON, 3.5 to the mouth of the St Lawrence on the US side.
There is also whitewater in the Black River in Watertown all summer long, which is the original reason we started going there. Originally there were 2 really good playspots; 1 (Route 3 wave) got wrecked in a flood a few years back but the city of Watertown has just approved like 75k to fix it, again. You have probably seen IG posts from the other spot, Hole brothers, which is more of a hole than a wave depending on levels. Between the sailing, fishing, whitewater, affordability, lack of crowds, it's a pretty amazing place, if you're into that sort of thing.
Re: Jeffs FS14 LS
Posted: Sun Jun 20, 2021 10:05 pm
by VT_Jeff
Plot point sat afternoon getting the FS out of the basement into the garage.
I had more than 1/2" of clearance on both sides and I lucked out on the trailer height matching perfectly to where I was able to effortlessly winch it off its cradle and onto the trailer. I had to relocate a deck post temporarily but it was a simple task. I had fretted about this for quite a while but in the end it was a nothingburger.
Still some meat on the bone but going to splash next weekend.
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 1:50 am
by TomW1
Dang that boat looks good.
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 7:10 am
by Jeff
Nice VT_Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 8:03 am
by Mojosmantra
Now that’s a milestone! Nice to see her from that angle and in the light of day. She looks great.
Congrats
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 10:59 am
by VT_Jeff
Mojosmantra wrote: ↑Mon Jun 21, 2021 8:03 am
Congrats
Jeff wrote: ↑Mon Jun 21, 2021 7:10 am
TomW1 wrote: ↑Mon Jun 21, 2021 1:50 am
Much thanks Gents!
Tackling the interior trim after work today, I think I finally figured out how to get it attached, will be using a screw on the 2 forward corners were clamping is...difficult.
I got the console glued in. I glued it such that it will be simple to remove it with a dremel. Not sure why but I wasn't ready to "send" it, maybe subconsciously there's something I know I forgot.
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 11:02 am
by narfi
It's looking great!
fun/frustrating prediciment to be in..... almost ready to go, but want to make everything just 'perfect' before calling it done
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 4:36 pm
by TomW1
VT_Jeff wrote: ↑Mon Jun 14, 2021 9:31 am
Dang Jeff that looks like a great and nice place to spend a few weeks. Tom
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 7:21 pm
by VT_Jeff
Registration application sent back because the sales tax I already paid on all the materials is immaterial, I need to pay full use and sales tax. And because the person acquired from and date acquired was blank.
<descending slide whistle sound>
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 7:44 pm
by VT_Jeff
That will probably delay my splash by 2-4 weeks.
Normally, I could drive to the dmv and have it done in a day. Due to covid, it's by appt only, next appt is july 20th. So I'm gonna put it back in the mail and wait, again.
I've been pretty blessed in a lot of ways and am.in no position to gripe about a first world problem such as this when there are so many people who have been devastated by the effects of covid, physically, financially, psychologically, etc. That said, !@#%%$$#@!##$$%%$$#@@#$%$#@$^&**^%$#@!#^&*^%$$#%&%$&&%$##!!!!!!!!@@@!!!!!!!!!!!!!!!!!!!!!@!!!!!!!!!!!!!!!!!!!!
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 9:14 pm
by Mojosmantra
I'd splash anyway - no question. What are the chances and what's the harm? It's not like you're running square grouper (that's an assumption on my part
Maybe it's different up there but I haven't seen the boat police on the water in over a year. Just sayin'.
Re: Jeffs FS14 LS
Posted: Mon Jun 21, 2021 10:27 pm
by VT_Jeff
Mojosmantra wrote: ↑Mon Jun 21, 2021 9:14 pm
Tempting, believe me!
Vt is pretty mellow, esp near my house, but lake Ontario in ny is oppressive between the cg, sheriff, state police and d.e.c.
Re: Jeffs FS14 LS
Posted: Tue Jun 22, 2021 2:29 pm
by Dan_Smullen
VT_Jeff wrote: ↑Sun Jun 20, 2021 10:05 pm
She emerges!
Good luck getting legal/resisting the temptation to splash before so.
She looks good, Jeff. I can't wait to see the on the water pics!
Re: Jeffs FS14 LS
Posted: Tue Jun 22, 2021 4:12 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Jun 22, 2021 2:29 pm
Thanks brother!
Maybe this built-in delay will be a blessing in disguise, I'm actually already feeling less pressure to get things done.
Re: Jeffs FS14 LS
Posted: Tue Jun 22, 2021 7:41 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Jun 22, 2021 4:12 pm
Thanks brother!
There you go. Silver linings!
Re: Jeffs FS14 LS
Posted: Tue Jun 22, 2021 10:53 pm
by bamaguy0
Take the motor off and throw a kayak paddle in there. She's legal with no registration then, right?
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 11:08 am
by VT_Jeff
Not sure it will splash today but its more or less ready. Non skid could use some help but blowing it off, time to fish!
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 11:12 am
by bamaguy0
Woohoo!
I've already commited to no cooler seat, but that looks really good!
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 12:53 pm
by narfi
woop! woop!
Have fun!
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 1:00 pm
by cape man
I'd launch it and take my chance on talking my way out of a ticket or paying it. That girl wants to fly!
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 2:03 pm
by Jeff
Very nice!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 3:12 pm
by VT_Jeff
cape man wrote: ↑Sat Jun 26, 2021 1:00 pm
Thanks. I'm planning on it, just clearing some other stuff of the schedule(whitewater paddling, it's a release weekend). Maybe tonight or tomorrow. I filled it up with gas so its ready.
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 3:16 pm
by VT_Jeff
Jeff wrote: ↑Sat Jun 26, 2021 2:03 pm
Very nice!!!! Jeff
narfi wrote: ↑Sat Jun 26, 2021 12:53 pm
woop! woop!
Have fun!
bamaguy0 wrote: ↑Sat Jun 26, 2021 11:12 am
Woohoo!
Thanks all, it's been a long trip, I'm nearing the next phase: usage. I'll post some splash pics soon, Lord willing.
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 10:15 pm
by Fuzz
I am a little confused
I see a steering wheel and a tiller. how does that work?
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 10:20 pm
by VT_Jeff
Fuzz wrote: ↑Sat Jun 26, 2021 10:15 pm
Good observation. Its tricky, but not much worse than my century cheetah controls.
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 11:06 pm
by VT_Jeff
I did drop the boat in down the street for a few hours tonight. Everything worked flawlessly, boat ran great and smooth, planes great, handled the light chop effortlessly. Not a speed demon but planes quickly and fast enough, I'll get speed specs later.
The trolling motor worked amazing and even with a pretty good breeze, was simple to keep on track and facing the preffered direction. Om accustomed to fighting and swearing in any kind of breeze due to the wind age of the driftboat. Huge difference!
I stayed at the controls and elaine fished, she boated 4 fish in 90 minutes on a fly she tied. Nothing trophy worthy, but they got the stink off the boat.
Overall, could not be more pleased, it's so far exceeded about all expectations, cant wait to get back out.
Once again, huge thanks to all for advice and encougement, it's meant a lot.
I did not get great photos, I'll fix that soon.
Re: Jeffs FS14 LS
Posted: Sat Jun 26, 2021 11:33 pm
by Fuzz
Great stuff!
And you let momma do the catching, smart man.
When it is time to fill the freezer that is my wife's job. She is a catching machine
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 6:57 am
by bamaguy0
That's awesome! Good to get it out and get some fish slime on it's maiden voyage no less.
Is that a GPS trolling motor? I bought an older minnkota with the copilot module burnt out in it. Got an Ipilot upgrade kit sitting in my office. I'm super excited about spot lock.
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 7:16 am
by Jeff
Again, great stuff!!!! Congrats, Jeff
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 8:40 am
by Dan_Smullen
Nice job, yall! Has to be sign of great things to come, knocking the skunk off on the maiden voyage!
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 9:37 am
by VT_Jeff
bamaguy0 wrote: ↑Sun Jun 27, 2021 6:57 am
It's not, I didnt spring for that one or they were out if stock, I cant recall. It would be nice though, I can see that already.
I was using the wireless handheld while Elaine fished and I was shocked at how easy it was to get in/hold position. My grady 19 had a trolling motor but it was a struggle to get/keep the boat where I wanted it due to wind age and weight. The Fs14 is a magic carpet!
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 8:20 pm
by PapaDave
That is looking really nice Jeff. Glad to see you out on the water and catching fish.
Re: Jeffs FS14 LS
Posted: Sun Jun 27, 2021 8:33 pm
by VT_Jeff
PapaDave wrote: ↑Sun Jun 27, 2021 8:20 pm
Thanks Dave, it was a blast. Hoping to get better photos and video next time out. Saw your post of the outrigger, I'm going to try to get to that boat show in August, maybe see you there.
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 2:46 pm
by VT_Jeff
Some more photos. Ignore the Makers Mark, it was a gift from a visiting kayaker who arrived as I was finishing up.
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 2:55 pm
by Jeff
Really nice work Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 3:01 pm
by Jaysen
If you need to get rid of the makers mark I know a guy who would take it off your hands along with a couple winches.
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 3:39 pm
by VT_Jeff
Jaysen wrote: ↑Mon Jun 28, 2021 3:01 pm
Have not forgotten, just post-covid busy....like everyone.
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 4:17 pm
by Jaysen
VT_Jeff wrote: ↑Mon Jun 28, 2021 3:39 pm
I know. Was just poking you in the eye for fun.
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 4:18 pm
by VT_Jeff
Jaysen wrote: ↑Mon Jun 28, 2021 4:17 pm
No problem, ever!
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 5:06 pm
by cracked_ribs
Boy that looks great! Congratulations on the successful run!
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 5:28 pm
by VT_Jeff
cracked_ribs wrote: ↑Mon Jun 28, 2021 5:06 pm
Thanks CR!
Re: Jeffs FS14 LS
Posted: Mon Jun 28, 2021 9:19 pm
by Dan_Smullen
A bottle of MM is perfectly appropriate to be found sitting on a recently completed skiff. Honestly, would be disappointed if there wasn’t one close.
The brite fir and paint combo is crisp!
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 6:44 am
by cape man
Congratulations on a beautiful boat and first trip! Where is your throttle and shift?
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 7:33 am
by VT_Jeff
cape man wrote: ↑Tue Jun 29, 2021 6:44 am
Thanks Cape man. Controls are on the tiller, its a calculated compromise. I may at some point either spend the (crazy) money to switch to forward controls or else replace the wheel with a grab bar. Or maybe find that it works and leave it, its a bit experimental. I got a great deal on the tiller motor and bought it before I considered a wheel, and then bought the wheel before I realized that a zero feedback helm meant that you cant steer from the tiller, I assumed that I would be able to and that the wheel would just be a convenience. I later learned that even a feedback helm is near impossible to steer from the tiller, so I didnt bother swapping it out.
So, time will tell if it stays like this
When i get it to the marina this week, where manuevering is tight, I'll see how feasible it is. I am a "wonder if this will work" guy and not a "this is how its done" guy. With some successes and some failures, but so far no surgeries or broken bones at 53.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 10:20 am
by cape man
So how hard it is to have a hand on the throttle (tiller) and a hand on the wheel? I can see how it would work most of the time, but a lot of times I'm holding on tight to the helm and the binnacle.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 10:40 am
by VT_Jeff
cape man wrote: ↑Tue Jun 29, 2021 10:20 am
The throttle is lockable so once you set it, you don't need to hold it, same as a forward-control throttle.
Just for some background, cause I knew this was going to raise some eyebrows:
My '68 Century Ski boat had, by design, a vernier throttle on the dash, shifter stick on the column and a huge, late 60's luxury car wheel. And it was an inboard with insane prop-walk. So the FS14 is childs-play compared to that thing around a dock/slip. My previous sail boa (Leisure 22) was, by design, tiller steer with the throttle/shifter located down by your feet. Sailboat before that (Precision 18) had, by design, a steerable outboard that you had to face backwards and reach through the lifelines and down over the transom to shift. My current sailboat (C&C 29MKII) has, by design, traditional controls on the binnacle: shifter on the left, throttle on the right. Without fail, when someone new is at the controls, they inevitable shift it with the throttle up, and it's even possible that I've done it myself.
So if you're coming from the world of fishing skiffs, my setup may seem odd. From my perspective, it's perfectly normal.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 11:08 am
by Dan_Smullen
VT_Jeff wrote: ↑Tue Jun 29, 2021 10:40 am
You wouldn't know how to behave with a single binnacle and wheel.
The console/seat looks cool, but if over time, steering and throttle as they are cumbersome, the helm could be converted to a grab bar, you could steer via tiller and still be in fine shape without a lot of expensive mods.
It's impossible to imagine these custom boats we build to be in their highest form upon completion. I hope they are an evolution toward perfection, which will always be "Just. One. Small. Tweak." away.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 11:53 am
by VT_Jeff
Dan_Smullen wrote: ↑Tue Jun 29, 2021 11:08 am
Barely know how to behave period!
Exactly Right: that particular mod is about 8 counter-clockwise revolutions of a single locking-nut away. The Grab bar may look suspiciously like a steering wheel when the mod is complete.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 12:00 pm
by Dan_Smullen
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 12:45 pm
by Jaysen
The gymnastics VTJ mentions on sailboats is why I was actually happy to find an outboard that had the throne and transmission as a single control. One hand on tiller to rudder, on on tiller to outboard and it’s all covered. With a 2’ extension I have no body parts outside the boat.
At least not until the mrs tosses me over the rail anyway…
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 1:04 pm
by VT_Jeff
Jaysen wrote: ↑Tue Jun 29, 2021 12:45 pm
A gentleman would jump so his lady doesn't throw out her back in the process.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 1:34 pm
by Fuzz
On my 9.9 Suzuki the cost to convert from tiller to remote control was crazy. I looked around and found a used 8 hp Yamaha remote for very little more than what it would have cost to do the conversion.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 5:43 pm
by VT_Jeff
Fuzz wrote: ↑Tue Jun 29, 2021 1:34 pm
Agreed on the crazy cost to convert. I do live at a marina in the summer and the mechanic is a good friend who is always willing to help out with interesting projects, and they're a Honda dealer, so you never know, the stars may align. I'm not going to bother looking for a different motor, I got a great deal on this one and it runs perfectly.
Re: Jeffs FS14 LS
Posted: Tue Jun 29, 2021 8:18 pm
by Mojosmantra
Jeff - congrats! The boat looks great.
As for how you control the thing - you’re obviously a better captain than I’ll ever be. Unless , of course, you keep that bottle of MM at the helm. In that case, I could drive that thing through a hurricane
Seriously - cool boat. Hope you get lots of good use out of her.
Re: Jeffs FS14 LS
Posted: Wed Jun 30, 2021 2:19 pm
by VT_Jeff
Just going to add some slightly better photos, hold your applause.
Re: Jeffs FS14 LS
Posted: Wed Jun 30, 2021 2:37 pm
by Jaysen
Re: Jeffs FS14 LS
Posted: Thu Jul 01, 2021 3:01 pm
by Dan_Smullen
Serious flex!
Happy 4th of July, Campbells!
Re: Jeffs FS14 LS
Posted: Thu Jul 01, 2021 3:54 pm
by VT_Jeff
Dan_Smullen wrote: ↑Thu Jul 01, 2021 3:01 pm
Serious flex!
Thanks Dan, you and your clan too!
Re: Jeffs FS14 LS
Posted: Mon Jul 05, 2021 10:24 pm
by VT_Jeff
Took a chance and headed to the shoals to hunt carp and drum on the fly. We saw some fish but no bites. it's a tricky business and we've lots to learn.
A neighbor saw my boat and offered the use of a pole for the season, thank you Nick!
Here's elaine while she waits for me to stop taking photos and pole effectively.
Re: Jeffs FS14 LS
Posted: Mon Jul 05, 2021 10:27 pm
by bamaguy0
Do you know what pole it is? What's the length? I'll be looking to get one before too long.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 12:59 am
by Fuzz
I might have missed it but how does it run?
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 7:32 am
by Mojosmantra
Hey Jeff - it looks like she sits pretty level. What’s the draft?
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 8:23 am
by VT_Jeff
bamaguy0 wrote: ↑Mon Jul 05, 2021 10:27 pm
My neighbor said he built it form a kit, I'll ask him for the details. It's probably 20' or so, pretty damned long!
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 8:46 am
by bamaguy0
Sounds like the MHX kit. I was looking at that one.
https://www.mudhole.com/MHX-Carbon-Fiber-Push-Poles
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 8:56 am
by VT_Jeff
Mojosmantra wrote: ↑Tue Jul 06, 2021 7:32 am
Yeah, I was actually afraid it was TOO level and wouldn't drain but we had a mini-monsoon last night and this morning it was basically dry, which is remarkable.
I believe I marked my waterline at 4" up from the lowest point of the vee(I don't have a skeg) and it sits 1/4" deeper than that unloaded. Cameron calculated the PPI of a +10% at 260#. Elaine and I weigh 300# together, so figure another 1.5 inches with us both on, 2" with the dog. I am heavier so when I'm on the stern poling and she's on the bow, it's a little stern heavy, so somewhere around 7" is probably a safe bet. I'll mark/measure next time out and see how close I am.
Very glad I went for the deeper hull, btw. We need to cross Henderson Bay to get to fishing grounds and it can chop up pretty good, flat hull would have been murder yesterday.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 9:00 am
by VT_Jeff
Fuzz wrote: ↑Tue Jul 06, 2021 12:59 am
Runs great Fuzz, not super-fast top speed but planes effortlessly and my extra large rubrails make the ride completely dry, in a pretty decent chop, it's insane! I'll get a top speed one of these days, need to get a glassy hour in the bay.
Re: Jeffs FS14 LS
by VT_Jeff
Sounds exactly like what he described.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 9:52 am
by VT_Jeff
BTW, unloaded my boat is heavy: motor is 130#, 5 gallon alum gas tank(full), trolling motor and 35 AH trolling battery, motorcycle battery for starting battery, sole running bow to stern, console, steering gear, bear-proof cooler, anchor/rode. Built to spec with just a 2-stroke 20hp OB and portable tank, I suspect it would levitate and go 30mph.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:10 am
by bamaguy0
Motorcycle batt to start a 4 stroke 20hp? What's the specified MCAs for that motor? I was trying to find the smallest batt for my 2 stroke Tohatsu and it still required like a Group 34.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:23 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Jul 06, 2021 10:10 am
My DRZ400 has a 33hp 4 stroke and a MC battery works fine for that, but I suspect the starter gearing on the outboard is higher cause if the battery is a little low, it struggles. My intention was to use the battery for tilt and to provide a load for the alternator and otherwise pull start it.
Manual just says 35AH min.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:28 am
by bamaguy0
Yeah I was on the fence about underpowering it and pull start as needed...still am I guess. I guess the only thing I have to consider is that I plan to run livewell and fishfinder off it as well. Might be worth keeping a bigger batt in there.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:33 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Jul 06, 2021 10:28 am
The problem with under-powering, per my understanding, is that it's not good for the starter, and repeated low-battery starts can result in a flat spot on the starter. The generator on my previous RV had that issue and my MB Sprinter RV currently has that issue(joy!). So if I were still shopping for a battery, I'd get something bigger and save weight elsewhere.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:44 am
by bamaguy0
Yeah I think I'm gonna stick with a Group 34 and just get the lightest I can find. Optima Bluetop here I come!
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:46 am
by bamaguy0
I know you're off enjoying it now, but are you planning any sort of post mortem analysis? I was thinking of doing that, but I should probably jot down a list of my stuff before I forget them all.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:54 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Jul 06, 2021 10:44 am
Wow, they're not giving those away!
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 10:57 am
by bamaguy0
VT_Jeff wrote: ↑Tue Jul 06, 2021 10:54 am
You shoulda seen the bill for the 100AH lithium I got for my trolling motor.
Re: Jeffs FS14 LS
Posted: Tue Jul 06, 2021 11:00 am
by VT_Jeff
bamaguy0 wrote: ↑Tue Jul 06, 2021 10:57 am
Don't even want to know!
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 10:24 am
by VT_Jeff
Top speed 23mph on glass with elaine and I on the boat. No complaints! Zero porpoiseing or anything else, corners pretty well at speed. I need to get on plane a little gradually or else the prop slips. If I just hammer it from a stop it just slips and spins.
I'm just trimming it all the way down and leaving it, seems to work fine in that position.
Definitely feels like the prop is steep enough or possibly a tiny bit too steep, I suspect it may not be hitting max rpm at max speed. Going to borrow a strap-on tach from the mechanic here and see what I'm getting, one of these days.
Tough conditions last night for sight-fishing, windy and dusky by the time we got to the shoal. We saw a fish or two but we were on top of them before we could see them, will keep at it.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 1:49 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Jul 05, 2021 10:24 pm
Great shot, Jeff! That's BBC cover photo worthy.
I'm interested to hear what the guys who know more about propellers have to say about the slipping. I wonder what changes in pitch would prevent that, or, is it just the way it goes. If anything, it speaks to the responsiveness of the outboard.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 2:43 pm
by Fuzz
Getting the tach is the best thing you can do. Need to know what the engine is doing before you go prop hunting.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 3:23 pm
by TomW1
Dan_Smullen wrote: ↑Wed Jul 07, 2021 1:49 pm
Jeff give me a holler about the prop. I will need. The slipping can be caused by a couple of things, not enough grip by the prop is one.
The weight of the boat with you and Elaine on it as it sits on the water, Do not include the motor, instead give me the brand and HP of the motor as I willl nead to look up the specs for it from the manufacturer and will get the weight from them and also the prop weight.
Also let me know what your current prop size is.
Regards, Tom
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 3:48 pm
by VT_Jeff
TomW1 wrote: ↑Wed Jul 07, 2021 3:23 pm
Regards, Tom
Thanks Tom, I'll see if I can get the boat to a scale and will get you the other info once I do. I could guess at the hull weight but that won't help much in calculating ideals.
23 mph seems like a pretty acceptable top end based on some of the other performance data I've seen on here, I was hoping for at least 20 as I know I am way-overbuilt. As far as the slipping at hole-shot, I really need to do some more testing/fooling around when we're not in a huge hurry to get to the fishing grounds. I want to ensure I'm not hub-spinning, for one, though I suspect I'm not. I'll grab some video and post it.
Appreciate the offer, as always!
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 4:00 pm
by VT_Jeff
Thanks Dan, that's close to the shot I had in mind when I started building. A seriously bent rod or better yet a big fish in hand would improve it dramatically!
Yeah, I suspect if I pitch down I'll slip less at the cost of some top end, but I don't know a ton about how that stuff is supposed to work. A quick search revealed guys saying that some slippage is good because it allows the motor to spin up to rpm quicker, so who knows. Well, I guess someone does. Besides pitch there is diameter, blade count, cup, etc etc, all things I know nothing about, so I'll also be interested in what the experts say. I need to get a spare prop at least so if there is room for improvement, I'm game to try.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 5:28 pm
by Fuzz
Hard to tell with no tach but here is what it sounds like to me. I think you have too much pitch. The prop is just spinning and not grabbing water when coming out of the hole. And after you get going you are not reaching full RPM so that is slowing you down, plus it is real hard on the engine. Where is the cav plate in relation to the bottom. Maybe post a picture of that.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 7:21 pm
by VT_Jeff
Fuzz wrote: ↑Wed Jul 07, 2021 5:28 pm
I suspect you're right. The honda 20 is just a 15 with a higher rpm limit, so probably be good to ensure I'm hitting it and not lugging.
Cav plate was way too low. I just moved it up. Still maybe an inch too low but much better. With just the clamps, I'm out of adjustment room. Honda transom height is 22.7. Go figure. Black bottom makes it tough to see.
I also think I was trimmed down too far. This is all the way down, how I was running.
I think this is how I should be, with the prop perpendicular to the waterline. It looks high in the photo but the boat isn't level, it's a little bow down.
- 20210707_190512.jpg (235.75 KiB) Viewed 142017 times
Once the weather improves I'll see what difference that makes and get a tach reading. There is a scale nearby where I can weigh the boat, so should have that info soon.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 7:37 pm
by VT_Jeff
In other news, vt dmv cashed my check, so as far as I'm concerned, I am registered and 100% legal. I figure a photo of the cancelled check is my "get out of a ticket free" card. Now if it would just stop raining/blowing for 5 friggin minutes! I'm all for rain, but prefer it at night. And I'm all for wind, just preferably when I'm keen to sail. First world problems.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 8:18 pm
by TomW1
Jeff I have your motor figured out It is the Honda 20 with the standard aluminum 4-blade 9.25D x 10P Solas Amita prop. Ir is one of the best on the market for aluminum props. Once I get your weight numbers if we need to we can go up 1 pitch or down as many as three. Check also if your Honda dealer will change for free. Or we can go to a more efficient SS prop with rake and ptich, which is more dollars and will be up to you.
One question for you do you have the 15 or 20 inch shaft. It only makes a difference in a few pounds.
So I have all specs for the motor.
One thing you do need to do is get a Tini Tach or some other type of temporary tach to make sure your running at 5000-6000 rpm's. And preferably in the upper range at full throttle. It sounds like your doning that so good.
PS: Congrats for getting her Regitistered.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 9:38 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Jul 07, 2021 4:00 pm
I hope you can get that pic in the marsh come October, but in the meantime, just get her snagged on a stump!
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 9:50 pm
by Fuzz
I have started out way too low on a couple of boats. Getting the motor up where it should be will make a huge difference.
Even with it raised up now it might be too low. If you do not have any room left to come up one of the manual jack plates might be the easy answer. Get the height right and a proper prop that thing might run like a scalded cat.
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 10:44 pm
by VT_Jeff
TomW1 wrote: ↑Wed Jul 07, 2021 8:18 pm
Impressive detective work! 20" shaft
I'll verify the prop but I'm sure you're right!
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 10:46 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Jul 07, 2021 9:38 pm
Definitely feeling the call of the marsh, let me know if there are specific patterns so I can crack the whip on elaine to start tying. Stump is a superb idea!
Re: Jeffs FS14 LS
Posted: Wed Jul 07, 2021 10:48 pm
by VT_Jeff
Fuzz wrote: ↑Wed Jul 07, 2021 9:50 pm
Scalded cat would be ideal! There is more room to move up, just not with clamps alone. Plan is to bolt ultimately anyway so I should be able to get the cav plate dead even, if that's the goal.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 9:41 am
by VT_Jeff
1620 -335 (trailer)= 1285#
Heavy!
Standard FS14LS design specs:
- Capture.PNG (16.99 KiB) Viewed 133850 times
Here's some guesses at
Motor 130
Fuel tank and fuel 40
Starting battery 10
Troll battery 20
Troll motor 40
Cooler 15
Anchor/Rode 25
Steering gear 25
Total = 305
1285-305 = 980 hull weight
Something feels off. 4 of us lifted this boat fairly effortlessly and I don't think any of us is capable of lifting 250#
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:30 am
by bamaguy0
1285lbs with a displacement of 260lb/in would get you around a 5 inch draft. I agree something seems weird, but the sanity check checks out.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:42 am
by VT_Jeff
bamaguy0 wrote: ↑Thu Jul 08, 2021 10:30 am
That's very interesting. We've discussed/debated if it's linear but I'm not sure we considered the first few inches, only the PPI over the DWL. I suspect the curve is a lot steeper up to that point due to the reduced surface area of the Vee, you think?
But yeah, going back to the lift in the basement: myself, Elaine, and another couple. All of us in decent shape but the girls were up front lifting with their fingertips under the rubrails, Jayson and I were at the stern also lifting with fingertips under the rub rail as I recall, so there's just no humanly way we wer each lifting much over 100# I would think. Lifting the 130# motor by myself is murder, and lifting the boat was not too taxing.
I wonder if the scale is properly calibrated for low weights or if there is some weirdness because of the position on the scale. The max payload of the trailer is 1250 and it definitely does not look/seem taxed.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:53 am
by bamaguy0
It isn't linear but I thought the 260 was an average. Id have the check my numbers again.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 11:20 am
by Jeff
VT_Jeff, I agree, something is really wrong with that scale. I don't think there is any possibility that she is that heavy!!! Jeff
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 11:27 am
by bamaguy0
You sure the trailer is 335? My aluminum one is listed at 400.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 11:43 am
by VT_Jeff
bamaguy0 wrote: ↑Thu Jul 08, 2021 11:27 am
That's Definitely what Karavan says.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 11:47 am
by VT_Jeff
bamaguy0 wrote: ↑Thu Jul 08, 2021 10:53 am
I'm going to try another scale tomorrow, found one that is a single platform, maybe it will give a different result.
JM says 610#@5" draft
That's a PPI of 120 for the first 5", then 200PPI after that.
If we apply that to my +10% using your PPI factor of 260, we'd get 157 PPI for the first 5"
157*5 = 785
785-305 = 480
480 make sense for the hull weight.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 12:09 pm
by VT_Jeff
Jeff wrote: ↑Thu Jul 08, 2021 11:20 am
Agreed. I'll get to the bottom of it!
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 12:10 pm
by VT_Jeff
9-1/4X10", says Honda on it.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 1:26 pm
by VT_Jeff
Here's the spec:
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 2:31 pm
by TomW1
VT_Jeff wrote: ↑Thu Jul 08, 2021 12:10 pm
Yep 9.25 or 9 1/4 are the same.
On another note the weight. It would be almost be impossible for your boat to weigh that much. I know you said you built it heavy but over 1000 lbs I think not. I know you have added the console and trolling motor, but that won't add that much to Jaccques 610lb DWL. Good luck on your next weighing.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 5:30 pm
by bamaguy0
VT_Jeff wrote: ↑Thu Jul 08, 2021 11:47 am
157*5 = 785
785-305 = 480
Based on my model and calcs an all up weight of 923lbs will draft 5 inches. 791lbs gets you drafting 4.5 inches, so there's some room for interpretation here I'd say. Also could be in how it's measured. I took the lowest point of the transom when level.
3" - 421.18lbs
4" - 662.29lbs
5" - 923.65lbs
6" - 1198.41lbs
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 5:42 pm
by VT_Jeff
bamaguy0 wrote: ↑Thu Jul 08, 2021 5:30 pm
157*5 = 785
785-305 = 480
3" - 421.18lbs
4" - 662.29lbs
5" - 923.65lbs
Thanks for running that Cameron.
So if the scale is right and 260ppi is right, I'd be drafting 6.5 at the dock @ 1285 and close to 8 @1585 with us on it.
Will re weigh tomorrow.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 6:01 pm
by bamaguy0
I'm wondering if something with taking the trailer off is doing it. Looks like the hitch is not over the scale?
I believe the typical method for trailer weight is tow vehicle plus trailer then tow vehicle alone. Then you subtract.
There is no doubt some error with such a light load. Those are calibrated to a certain range. It would not surprise me that under 1 ton is less accurate.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 6:47 pm
by TomW1
157*5 = 785
785-305 = 480
3" - 421.18lbs
4" - 662.29lbs
5" - 923.65lbs
6" - 1198.41lbs
Guys no, Jasques has calculaated and given the water line and draft and PPI for the boat. The PPI is not linear. At 1" it may be 25lbs and then goes to 200 at DWL per Jacques calculations at 5" with a load at 610lbs at DWL. All are calculated numbers through his Boat Desigh Programs. They are not guesses. Now if you raise the draft to 6" the PPI will increase to something over 200lbs and the DWL also increases and the Displacement at DWL increases. bamoguy0 you need to go back and check your calculations, they are way to high, what model did you use? Your model should have been the same as Jacques at 5" or within a reaonaable variation, not 300lbs off.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 6:52 pm
by bamaguy0
I modeled the boat based on the plans and then scaled it up 10% to mimic Jeff's boat.
With my nominal model, 5 inches of draft displaces 796lbs. This is no doubt above Jacques published numbers but at this point the PPI is around 220lbs. I would say the error is in what the DWL actually looks like. I cut my slices at a level deck and measured off the transom low point. The forward vee around Frame B is actually slightly lower with the deck level. It's about an inch on the plan size, so then maybe what I call 4" is Jacques' 5" which would put me at 574. Again, off but for what I'm using these calcs for, in the ballpark.
Doing this simplified my estimations drastically, but no doubt added some error into the mix.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 9:58 pm
by bamaguy0
So I did a little digging into my model. With the per plan model first.
5" Draft from the lowest point of the hull, nearish to Frame B, results in a displaced volume of 16811 in^3. Multiply that by the density of water we get...605lbs! For reference, that's 4.15" to the low point of the transom.
I'd say I'm within a reasonable margin of error given I'm recreating a 3D model based on 2D plans. Oh and BTW, this does not include the thickness of the hull panels, so feasibly, you'd displace slightly more weight at the same draft. I don't care enough to remodel though.
So, if we go by that measurement point, Jeff, here's what I see for a +10% boat.
4" - 406.08lbs
5" - 654.22lbs
6" - 916.4lbs
7" - 1218.65lbs
Realistically, though, I'm betting most boats like this sit in the water about to the point where the 2 measurement points in question are level which makes the deck low in the back. I'm betting mine will for sure!
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:28 pm
by VT_Jeff
bamaguy0 wrote: ↑Thu Jul 08, 2021 9:58 pm
4" - 406.08lbs
5" - 654.22lbs
6" - 916.4lbs
7" - 1218.65lbs
Great stuff, Cameron! I'm going to re weigh and at some point measure the draft from the low point you r referenced and see if things jive. If its .85" from the bottom of the transom to the low point, can I safely assume .85 + .085 in my case?
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:40 pm
by bamaguy0
Probably close enough, but I can check in the morning. I think it would be some trigonometric function of 110% of some other frame dimension, so not exactly, but it'd be within the noise. I'd venture to say with this kinda stuff if you're within a quarter inch you're doing swell.
That point was 100% an eyeball selection. I don't think Fusion360 has an extremum function like Catia where I can pick a curve and say give me a point the farthest away from this other object that lies on this curve. If it's there I haven't found it yet.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 10:55 pm
by TomW1
4" - 406.08lbs
5" - 654.22lbs
6" - 916.4lbs
7" - 1218.65lbs
Those look much better. More along the lines of a 13' 6" base boat increased by 10%. I would not worry about running them again.
Re: Jeffs FS14 LS
Posted: Thu Jul 08, 2021 11:03 pm
by bamaguy0
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 7:35 am
by bamaguy0
VT_Jeff wrote: ↑Thu Jul 08, 2021 10:28 pm
4" - 406.08lbs
5" - 654.22lbs
6" - 916.4lbs
7" - 1218.65lbs
I measure .92, so pretty close. I'd just round to an inch and call it good.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 8:38 am
by VT_Jeff
1020 makes a LOT more sense.
That puts my hull weight around 380, which is right in the ballpark of what I expected, roughly twice the design weight.
Elaine and I plus modest gear weigh about the same as the trailer(335) so that number, 1020, is about exactly right for use in prop calcs.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 8:51 am
by bamaguy0
Makes more sense!
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 9:36 am
by VT_Jeff
Because of the .85" difference between the low point at the bow and the bottom of the transom, you (and Trent) could add a tapered skeg with a working height of nearly .85" that does not add any draft. You could probably easily draw it in on your model and generate the offsets to mark/cut it. That, I think, would be pretty slick.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 9:40 am
by bamaguy0
That's true. It's too late for me. Mine is hopefully right side up for the rest of its life!
If Trent's interested I could draw up something.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 9:47 am
by Jaysen
You’ll eventually flip her. Almost always for a paint or repair after snaking something unexpectedly. Even if you just lift her for a paint/repair job you can still get a sort on there.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 9:52 am
by VT_Jeff
I love it when my hobbies dovetail like that!
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 10:19 am
by bamaguy0
Jaysen wrote: ↑Fri Jul 09, 2021 9:47 am
That's true. We'll have to see how much I slip and slide with what I got.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 12:32 pm
by VT_Jeff
Here's some data on weight/BOM/waste etc.
The design weight of the FS14 hull is listed at 190. Mine is +10% and weighs around 380, about double the design weight. I plugged some numbers into Excel to see how the BOM and design weight correlate:
I used a lot more epoxy than the BOM and used all the fabric+. I'll assume that a nomimal, competent builder would also use all the epoxy and glass, meaning the waste needs to essentially come out of the wood.
110 lbs of wasted plywood would be, roughly, 4 full sheets of 6mm and 1 full sheet of 9mm. I don't have nearly that much plywood in my shop, by a LONG shot.
I'm wondering if the design weight is supposed to be 290 and not 190. That would make me feel a little better about my fat-assed 380.
As always, quite possible that I am out in left field on this and more than happy to be brought back to reality.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 12:40 pm
by Jaysen
I think you will find that glass and epoxy use would be exponential increase not linear. Also the trend is to add more glass/epoxy for strength to make up for greater spans between frames. Add extra fairing (epoxy).
And before you feel too bad… Lil Bit is built to plan with a bit of glass for oyster defense. She’s clinically obese at 2x the spec weight. And that’s the BARE hull.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 1:00 pm
by VT_Jeff
Jaysen wrote: ↑Fri Jul 09, 2021 12:40 pm
Maybe "Big Bit" would have been more appropriate?
I actually don't feel bad or embarrased about the weight, truthfully. End of the day, I built the boat I wanted to build and it weighs exactly as much as the sum of the parts that I wanted in it. but 380/190 does feel pretty far out for a +10 with a few extras. 380/290 seems a lot more reasonable.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 1:54 pm
by TomW1
Jeff I would not worry about the weight if that is what it came out to. You added a foot in length and 6" in width, more fiberglass and epoxy and wood all around. It all depends on how efficient you were in applying the epoxy the other coatings, etc. If it came out weighing 380 it weighs 380. Don't sweat it. You have a Great looking boat and are enjoying.
In the mean time I will run your numbers with your Honda and see what prop you need to change to.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 2:15 pm
by VT_Jeff
TomW1 wrote: ↑Fri Jul 09, 2021 1:54 pm
Thanks Tom. As I told Jaysen, not really worried about it at all, it is what it is, just interesting to note the design weight vs the BOM weight. Even hefty and without any tweaking I'm already beating my hoped for speeds so I'm quite satisfied. And the ride it gives is amaze-balls, so huge kudos to the designer for drawing a hull that rides perfectly like that.
Speaking of which, does the #1020 "all up" weight give you any indication of what pitch I should be running on that? Not sure how soon I'll be able to get a tach on it but I'd be curious to see what you think I should theoretically get for a top end and with which prop.
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 5:59 pm
by TomW1
VT_Jeff wrote: ↑Fri Jul 09, 2021 2:15 pm
Speaking of which, does the #1020 "all up" weight give you any indication of what pitch I should be running on that? Not sure how soon I'll be able to get a tach on it but I'd be curious to see what you think I should theoretically get for a top end and with which prop.s Jeff
Yes Jeff that gives me all I need to run through my calculators. I started as soon as I saw them this morning. Your prop seems to be the right size but needs to have some rake and cup added to it. This allows the water to hold on and will reduce the slipping. This means going to a SS prop, unless you have a good prop shop near by and they can add some rake, cup to your prop. Aluminum props are easily reworked. Another suggestion would be is go to a stronger SS prop. I have recommended Pt Tech props and every one has been pleased in the past. You will need a Class A SRT 4-blade. Phone 800 736 7767 Tell them that you have the Amita 4 blade 9 2/5 x 10 from Honda. That will give you the Aluminum as a spare if you hit something. With the increased rake and cup you may need to go down to a 9 pitch but that is hard to determine without a tach or see if it slows you down much.
Well I hopes that helps you out. One thing else the SS is a more efficient prop and you may get a mile or two mph speed increase.
One last thing if you ever get a tach we really need to check that you are running in the 5500-6000 range at full throttle.
Regards, Tom
Re: Jeffs FS14 LS
Posted: Fri Jul 09, 2021 7:52 pm
by Dan_Smullen
Re: Jeffs FS14 LS
Posted: Sat Jul 10, 2021 10:13 am
by VT_Jeff
TomW1 wrote: ↑Fri Jul 09, 2021 5:59 pm
Regards, Tom
I squeaked out 25.5 mph today in glass with just me. Calculating the rpm from that with a 10" pitch, I think I'm pretty close to the max depending on the efficiency factor you want to use.
Gear ratio is 2.08
90% = 5984 rpm
83% = 6488 rpm
I'm not sure what is considered typical effiecency for a stock alum prop.
Re: Jeffs FS14 LS
Posted: Sat Jul 10, 2021 12:39 pm
by TomW1
VT_Jeff wrote: ↑Sat Jul 10, 2021 10:13 am
Regards, Tom
Gear ratio is 2.08
90% = 5984 rpm
83% = 6488 rpm
That is outstanding. An aluminum props efficiency is usually no more than 80% but the Amita's are a little higher say 81-83%. If you were at 6488 rpm you should have hit the rev limiter if your Honda has one. Most newer motors do. The two worst things you can do is over rev or lug the motor. To determine that you need some kind of tach. Here is the Tini Tach, I mentioned before
https://www.tinytach.com/gasoline-tinytach there phone number is at the bottom of the page to make sure you get the right one. I think the basic one at $49 will work for you but call to make sure. Or the one with the longer wires.
I would at this time stay with the prop you have and learn to handle it to prevent the slip. If you want at some time in the future you want me to work with you to find a SS with more rake and some cup, I will be glad to do so. I have checked iboats and they have a second Honda Amita prop 58130-ZWg-V32Za it is $50 more than your base Honda Amita. I can't tell what the difference is between the two are. Check to see with your dealer if it would correct your slip. Other wise as above a good prop shop can add a little cup to your prop to reduce your slip if it bothers you.
Regards, Tom
Re: Jeffs FS14 LS
Posted: Mon Jul 12, 2021 12:50 pm
by VT_Jeff
TomW1 wrote: ↑Sat Jul 10, 2021 12:39 pm
Regards, Tom
Gear ratio is 2.08
90% = 5984 rpm
83% = 6488 rpm
Regards, Tom
Here's something weird:
My top speed and pitch are indicating a prop efficiency of over 90%. Top RPM is 6000. Maybe my GPS is wrong.
RPM equation: = mph / 60 * 5280 * 12 / pitch * gear ratio
Re: Jeffs FS14 LS
Posted: Mon Jul 12, 2021 6:03 pm
by TomW1
Jeff every formula is going to show you something different. You can find one that will show you what you want. Mine are tried and true going back 15 years or more. Get a tach that will show you what is really going on. Until then you will never know. Those numbers are ridiculous.
Until you get a tach keep your speed down to the 23mph range. I feel that is good by my calculations, but I can't tell unless I know what your rpms are. I sure don't want you over revving as well as I don't want you in the lower rev part of the motor.
Well let me know where we go from here.
Regards, Tom
Re: Jeffs FS14 LS
Posted: Mon Jul 12, 2021 8:19 pm
by Dan_Smullen
I love some excel math.
What cells are input and which are calculated? Where did you find the formula for calculating efficiency?
Apologies in advance. I'm more of an asker than a seeker.
Re: Jeffs FS14 LS
Posted: Mon Jul 12, 2021 9:27 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jul 12, 2021 8:19 pm
Speed, pitch and gear ratio are inputs and my formula above gives a no-'slip-rpm from those. Divide that by any efficiency factor to get a theoretical true rpm, theres no real formula for that.
Tom is right, I need to validate with a tach, but I'm also a sucker for math games.
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 5:52 pm
by VT_Jeff
Couple fish scored on the fs14ls+10%, "Blue Sky". Elaine and my nephew miguel doing the angling. Elaine owes me a new trout net but the concenus is she's good for it.
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 5:59 pm
by bamaguy0
What a chunk of a smallie!
Did you ever get a tach and check the motor or have you been too busy enjoying the boat?
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 6:03 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Aug 07, 2021 5:59 pm
Yeah, nothing small about that fish but its mouth! No testing yet, had family visiting, boating, life etc, maybe in the coming weeks though. Speed is plenty adequate and with the chop here in lake ontario we are often running slow anyway.
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 8:36 pm
by bamaguy0
How'd it run with 3 folks on board?
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 9:01 pm
by VT_Jeff
bamaguy0 wrote: ↑Sat Aug 07, 2021 8:36 pm
Seperate trips so no data on that. I'm going to enforce the "2 persons max" rule pretty rigidly, it really doesnt work for 3 people.
Re: Jeffs FS14 LS
Posted: Sat Aug 07, 2021 9:08 pm
by bamaguy0
That's probably for the best.
Re: Jeffs FS14 LS
Posted: Thu Aug 12, 2021 8:15 pm
by VT_Jeff
Cup holders, pole holders, battery disconnect switch and stern nav light off the to-do list. Keeping the deck clean is beyond me, have stopped worrying about it, boat gets used nearly daily. Still need to raise motor.
Re: Jeffs FS14 LS
Posted: Thu Aug 12, 2021 9:59 pm
by cracked_ribs
Awesome that you're getting to use her now - sure a great feeling to see them on the water at last eh?
Re: Jeffs FS14 LS
Posted: Thu Aug 12, 2021 10:51 pm
by VT_Jeff
cracked_ribs wrote: ↑Thu Aug 12, 2021 9:59 pm
You said it CR! Initially there were some jitters that tempered the joy a little bit(Is the transom gonna fall off? Is the slightly used motor gonna start everytime? etc) but now it's like a comfortable ball glove, a real pleasure to be on and enjoy.
There are some stress cracks that I need to address, I'll post about those at some point, but I've definitely learned that fairing compound needs to be used sparingly and thinly, it's not structural. I knew this in theory before, I now know it in practice.
Re: Jeffs FS14 LS
Posted: Thu Aug 12, 2021 11:57 pm
by TomW1
VT_Jeff wrote: ↑Thu Aug 12, 2021 10:51 pm
So glad your enjoying her Jeff. Just throw some paint on the stress cracks till you get a chance to fix them and don't worry about them.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 12:58 am
by narfi
Once I let the cleanless obsession go on our fs17 it became more fun. Leaves and gravel and sand in the bottom right now but it's ready to go
It was hard to let go though...... So much time into something you want it to look nice.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 1:29 am
by Fuzz
One of the problems we all seem to have is making the boat too pretty to use. There is something to be said for a work boat finish. Little boo-boos don't hurt as much
Now if you were like me it is a good excuse for never really getting to the pretty stage
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 7:06 am
by bamaguy0
Could I maybe get a preview? It would be good to understand where you're seeing them so I can watch those areas while building.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 8:59 am
by VT_Jeff
bamaguy0 wrote: ↑Fri Aug 13, 2021 7:06 am
Yes, good call. One is where the deck meets the transom and should probably not be any surprise. Maybe should have hung the motor and pre'stessed this before filling. There is a clamp glued to the transom and the deck sits on that, so it's not in any danger of going anywhere, and the transom is still locked into the stringers etc so no concern there. At least not yet...I trailer with the motor all the way down to reduce bouncing and flexing as much as possible. My transom is doubled from spec.
The other spot is where I needed to fill the gap between the radius I cut in the deck and the radius that my bent-lam settled at. One corner is worse than the rest. I need to dig through photos to see what I did there. I know i used some wood and some fill, i cant tell which seam the crack is forming.
I was a little obsessed with stress cracks on the deck and v-grooved all the joints and filled with a strong mixture to avoid any hard lines. These have held up, no signs of cracks at any of those joints yet.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:36 am
by VT_Jeff
TomW1 wrote: ↑Thu Aug 12, 2021 11:57 pm
Thanks Tom and that's my plan, they'll need to wait until boating season turns back into boat-building season before any major surgery happens. Monitor and use in the meantime.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:44 am
by VT_Jeff
narfi wrote: ↑Fri Aug 13, 2021 12:58 am
Absolutely! the amount of time I spent taping off the deck for the non-skid, applying the non-skid, trying to get it all looking pretty and perfect, and it's all really just for that pre-launch photo! I have honestly not really tried that hard yet to get the deck clean again: I hit it quickly with an electric powerwasher before some guests came but have not suds-soaked it yet, which is really what it needs, I'll do that next crappy day and see what it looks like.
It's weedy here, and we are constantly dragging weeds onto the deck with flies/lures/paddle/trolling motor/push pole. The weeds are dirty and the deck doesn't really have a chance. Oh Well, Elaine is still walking on clouds from the stout small-mouth she bagged so it's all worth it!
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:46 am
by VT_Jeff
Fuzz wrote: ↑Fri Aug 13, 2021 1:29 am
Agree, Fuzz, a work-boat finish is really the only one that makes logical sense. But we all know that building your own boat first requires the setting aside of all logical thought: there is no greater distance between needing a boat and having a boat than building a boat.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:52 am
by bamaguy0
Thanks! That's a good point with the transom. I have a tilt n trim bracket that I'm installing so that will add an additional moment arm to the weight of the motor on the transom.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:53 am
by bamaguy0
VT_Jeff wrote: ↑Fri Aug 13, 2021 9:46 am
Ooof. Right in the feels.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 9:55 am
by VT_Jeff
bamaguy0 wrote: ↑Fri Aug 13, 2021 9:52 am
Yeah, not to reinvent the wheel, but I'm wondering if a flexible fill is the way to go there. Walking around the marina, I see glass boats with stress-cracks at the transom/deck joint.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:00 am
by bamaguy0
VT_Jeff wrote: ↑Fri Aug 13, 2021 9:55 am
I doubt the paint will be flexible enough to follow it even if the fill was. I'll do some digging.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:06 am
by VT_Jeff
bamaguy0 wrote: ↑Fri Aug 13, 2021 10:00 am
My thought was to just dremel out the transom crack and back-fill with a bead of 4200 or 5200(can never keep those straight) and no paint, it will not really stand out on my boat with the oyster white.
BTW, I have really come around to liking the Oyster White, a lot: I thought it was way too beige in the light of my basement but it's actually a really nice, cool (as in temperature, if a color can have a temperature) off-white. Very glad I decided against re-painting with a pure white.
Also, with my non-skid, the white deck is not a glare issue at all and stays quite cool on the feet/paws even when it's stupid hot out.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:10 am
by bamaguy0
Oh I follow. That makes sense.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:20 am
by narfi
I am struggling to follow the issue and solution here....
The deck to transom joint is cracked? or just the paint?
What was the original layup like?
Cleat epoxied to transom, deck epoxied to cleat, thickened epoxy fillet in joint, fiberglass tape over fillet, fairing(none, little or a lot) then paint?
If you have a good layer of glass tape, I don't know why it is cracking.... maybe sand back and lay in a couple layers of 12oz tape over the joint to strengthen any potential weakness?
(I don't think epoxy or glue are strong enough for joints, you need the strength of glass...... but that's just my 'feelings', I don't really know.....)
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:55 am
by VT_Jeff
narfi wrote: ↑Fri Aug 13, 2021 10:20 am
Good quesions Narfi.
There is about no fillet on that joint. I can't for the life of me say what I was thinking on that joint but it appears that it was a total brain-fart, one of a few so far. I don't have any photos to see exactly what I did with the glass there. Seems odd since I was perpetually concerned with the transom coming off.
I think you're right about taking it back, adding some biax tape over a good fillet and re-fairing. Small job in the scheme of things. For the now, going to use some flexible stuff to seal the crack.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 10:59 am
by bamaguy0
Your transom extends above the deck as well where mine will be flush and slightly below at the motor.
I'll have my own set of problems, but the story is clear...be sure of your tie ins there.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 11:08 am
by VT_Jeff
bamaguy0 wrote: ↑Fri Aug 13, 2021 10:59 am
Your transom extends above the deck as well where mine will be flush and slightly below at the model.
I probably never thought of that joint as overly-structural since many boats don't even have a rear-deck to tie into, quick example here:
viewtopic.php?f=1&t=61397&start=110
So I probably got lazy(recurring theme with me) and just concerned myself with a clean joint and didn't consider the ramifications of the transom flexing.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 4:47 pm
by Dan_Smullen
VT_Jeff wrote: ↑Fri Aug 13, 2021 11:08 am
Laziness is not the culprit with a guy who has more than one boat build and several project boats under his belt, with more in the future. I don't buy it.
I think the biax tape back there will make all of your problems go away and leave you confident once again, that your transom is not going to fall off. Probably...
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 7:01 pm
by TomW1
Yep if you don't have tape on the tape on the transom, put some on the joints along the bottom and the sides, No more flex.
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 8:20 pm
by VT_Jeff
TomW1 wrote: ↑Fri Aug 13, 2021 7:01 pm
So in defense of my omission, I'd like the record to reflect the fact that the plans definitely do not call for any glass on the deck or on that joint. Doesnt mean it's not a good idea, but not specified. So I suspect it is not intended to be a transom-holding joint.
That said, I'll be adding some biax on a fillet. At some point......
Re: Jeffs FS14 LS
Posted: Fri Aug 13, 2021 11:43 pm
by VT_Jeff
Dan_Smullen wrote: ↑Fri Aug 13, 2021 4:47 pm
That's quite kind! Agreed on the biax, I'm convinced!
Re: Jeffs FS14 LS
Posted: Sat Aug 14, 2021 9:36 am
by VT_Jeff
After a good scrub.
Lake is rocking, plan is to do some ww paddling and then sail to the next bay for some SUP fishing. Summer's running out already!
Re: Jeffs FS14 LS
Posted: Thu Aug 19, 2021 8:40 pm
by VT_Jeff
Quick vid of the fs in some small chop. You can hear a few pretty good hull slaps. Probably 2/3 throttle.
https://youtube.com/shorts/cR4yB6V3L84?feature=share
Re: Jeffs FS14 LS
Posted: Thu Aug 19, 2021 8:52 pm
by bamaguy0
Very nice!
Re: Jeffs FS14 LS
Posted: Fri Aug 20, 2021 12:27 am
by TomW1
Cool Jeff!
Re: Jeffs FS14 LS
Posted: Tue Aug 31, 2021 2:12 pm
by VT_Jeff
Boat continues to deliver. A friend took this old-as sounder/plotter off his searay, perfect, free pickup for me. The gps is hopeless compared to my droid but the fishfinder is spot-on.
Re: Jeffs FS14 LS
Posted: Tue Aug 31, 2021 2:41 pm
by cracked_ribs
She's a producer!
Re: Jeffs FS14 LS
Posted: Tue Aug 31, 2021 3:12 pm
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 11:44 am
by VT_Jeff
Here we go again!
This jig is for my glued lapstrake oar and sail boat. Not a JM design but hopefully I can log it here, I'll continue getting whatever supplies I can from Mr. Morrow.
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 1:31 pm
by Fuzz
Virus is strong in this one. May need a booster shot
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 1:35 pm
by VT_Jeff
Fuzz wrote: ↑Wed Sep 15, 2021 1:31 pm
Agreed. I think I mentioned it elsewhere but the thought of a VT winter without a boat to build is truly chilling. This one will provide relief for the next 2-3 winters by the time I get it sail-able.
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 1:46 pm
by Fuzz
I am just happy to know I am not the only one whose sanity is in question
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 1:59 pm
by Jeff
Thank you Jeff!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 2:04 pm
by VT_Jeff
Fuzz wrote: ↑Wed Sep 15, 2021 1:46 pm
Definitely not, you're in very "good" company here. Good-n-Crazy! Though you're now in the 30'-40' crazy, I'm in <16' crazy.
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 2:34 pm
by Jaysen
VT_Jeff wrote: ↑Wed Sep 15, 2021 2:04 pm
no one ever questioned fuzz's sanity... we all assumed it's been missing for decades.
And I don't think you (VTJ) can say "<16' crazy". Add up all your linear boatage and you are in the same boat as fuzz (metaphorically). At least until he adds up his total footage. If he does that, there will be serious questions asked.
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 3:24 pm
by VT_Jeff
Jaysen wrote: ↑Wed Sep 15, 2021 2:34 pm
That puts me at about 60' without any whitewater boats or SUP's. I've definitely got B.O.A.T.S.
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 4:50 pm
by Fuzz
There is no way I am going to cop to total footage
Re: Jeffs FS14 LS
Posted: Wed Sep 15, 2021 6:11 pm
by bamaguy0
All you with your room for multiple boats. I'm lucky to be able to do the one I got in my garage.
I hate HOAs...
Re: Jeffs FS14 LS
Posted: Thu Sep 16, 2021 9:35 am
by VT_Jeff
bamaguy0 wrote: ↑Wed Sep 15, 2021 6:11 pm
I hate HOAs...
How about you guys that get to use your boats 12 months/year? At least that's my impression, maybe the heat index makes that less likely.
Re: Jeffs FS14 LS
Posted: Thu Sep 16, 2021 9:52 pm
by bamaguy0
Middle of the summer at high noon can be a bit rough. It's bearable as long as you're catching fish.
Re: Jeffs FS14 LS
Posted: Mon Sep 20, 2021 6:49 pm
by PapaDave
Hi Jeff,
Great to see you putting another boat together. Nice looking strong back. I like how you tapered the 2x4 legs at the floor.
Enjoy the process,
Dave
Re: Jeffs FS14 LS
Posted: Thu Sep 30, 2021 8:12 am
by VT_Jeff
About ready to hit the road for a week of drum-hunting in Chesapeake Bay under the expert tutelage of local builder Dan "The Man" Smullen, Mr. C19 himself!
I had to do a last minute starter swap on the RV. No one could get me in so I braved the underside of the sprinter myself armed with nothing but a YouTube video and an E14 torx socket. It went miraculously smoothly, at least so far.
If all goes to.plan Elaine should be humble-bragging photos of speckled trout by sundown tomorrow. What could possibly go wrong?
Re: Jeffs FS14 LS
Posted: Thu Sep 30, 2021 11:39 am
by Dougster
Wow! I think the forum would enjoy a video of me backing that rig down the ramp!
Dougster
Re: Jeffs FS14 LS
Posted: Thu Sep 30, 2021 11:47 am
by VT_Jeff
Dougster wrote: ↑Thu Sep 30, 2021 11:39 am
Dougster
Ha! Speaking of which, I was at Lake George last weekend with this rig and the ramp there, at Rogers Rock, is a CLIFF! I am pretty confident when it comes to backing up trailers with the RV, been doing it a long time, but this definitely had my full attention! Did NOT want to end up on youtube!
Re: Jeffs FS14 LS
Posted: Thu Sep 30, 2021 3:19 pm
by TomW1
Nice looking rig there Jeff. You can go about anywhere with that.
Re: Jeffs FS14 LS
Posted: Thu Sep 30, 2021 7:06 pm
by Jeff
Have a great trip!!!! Jeff
Re: Jeffs FS14 LS
Posted: Fri Oct 01, 2021 8:37 pm
by bamaguy0
VT_Jeff wrote: ↑Thu Sep 30, 2021 11:47 am
Dougster
I am currently addicted to the Miami Boat Ramps channel on Youtube. If you ever need a personal confidence booster, that's what you need to watch.
Re: Jeffs FS14 LS
Posted: Sun Oct 03, 2021 4:57 pm
by Dan_Smullen
The boat is awesome, Jeff. Great evening eating and drinking, and an even better morning on the water talking boats, fish and life.
I’m not surprised that you and Elaine proved more effective at finding fish on your own than me showing you around. I’m hoping you two can a find a few more throughout the week!
Holla if you need anything or want to make a day trip into the city!
Re: Jeffs FS14 LS
Posted: Sun Oct 03, 2021 7:29 pm
by Jeff
Nice guys!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Oct 03, 2021 7:30 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Oct 03, 2021 4:57 pm
Thanks so much Dan, great to finally link up!
For the record, Dan told us where to go, what to look for, how to fish, and using his step by step instructions, elaine had a drum on the fly within a few hours of launching the fs14. Wasn't huge, but legit. Dan showed me a rig this morning that didnt produce at the time(soft plastic under a float), but I copied this afternoon and lost count of the speckled trout it got me. It also got me hooked up with a monster that half spooled me and then broke my line, we'll find it tomorrow and get the jewelry back.
So thanks for the info, for trailering the boat so Elaine could get her beauty sleep during dawn patrol, and for the expert local knowledge, incredible trip already, plenty left to go!
Also, I know a guy who's brother has a boat scrap yard who may have some serviceable hardware(cleats etc), I'll keep you posted on progress on that front.
Re: Jeffs FS14 LS
Posted: Sun Oct 03, 2021 9:12 pm
by Dan_Smullen
So the popping cork did the work today? Nice! It's a great way to fish. Keeps you moving and often yields results!
Re: Jeffs FS14 LS
Posted: Sun Oct 03, 2021 9:15 pm
by Fuzz
That looks like tons of fun! Not fair you guys can fish in tank tops and I am looking for my snow shovel
Re: Jeffs FS14 LS
Posted: Wed Oct 06, 2021 8:40 pm
by VT_Jeff
Fuzz wrote: ↑Sun Oct 03, 2021 9:15 pm
Keep in mind we are in vaca in the southern climes. At home in maple syrup land, its wool hats and socks, though no snow yet......
2 more days and it's back to reality.
Re: Jeffs FS14 LS
Posted: Wed Oct 06, 2021 9:20 pm
by Jeff
Crazy weather, you guys have fun!!! Jeff
Re: Jeffs FS14 LS
Posted: Sat Oct 09, 2021 1:12 pm
by BrianC
I really like the deck hatches with flush hinges. Where did you find the ones you used?
Re: Jeffs FS14 LS
Posted: Mon Oct 11, 2021 9:49 am
by VT_Jeff
BrianC wrote: ↑Sat Oct 09, 2021 1:12 pm
Thanks Brian.
https://www.amazon.com/gp/product/B07QG ... UTF8&psc=1
I had a master cut-off switch, a circuit breaker and a BlueSea USB charger from Amazon all fail on me and am in the process of replacing them, but the hinges have been good, no sign of rust yet.
Re: Jeffs FS14 LS
Posted: Mon Oct 11, 2021 9:52 am
by bamaguy0
I ordered some similar to those. One came in before the rest and the hinge was just straight up crunchy. I cancelled the rest of the order and got some of the cheaper Gemlux hinges. Theyre sheet metal vs cast but super smooth.
Was the circuit breaker bluesea? I've gotten nothing but BlueSea for electrical parts so far. Well except for the TM breaker. I got the MinnKota one which is probably rebranded from something else.
Re: Jeffs FS14 LS
Posted: Mon Oct 11, 2021 11:31 am
by pee wee
Amazon has gotten to be a lot like eBay in that the quality of sellers now includes some sketchy ones, and I think it's more common to get goods that are counterfeit. Not saying that's what you had happen, but under one listing you can have multiple sellers, and some of them might ship the actual product in the photos and some may ship something cheaper. There have been a number of companies mentioned here for a variety of products, I began collecting them in a file, because I can't remember stuff . . . now where did I put that file?
Re: Jeffs FS14 LS
Posted: Mon Oct 11, 2021 11:35 am
by bamaguy0
Yes Amazon has a huge counterfeit problem. It's just way too stinking convenient!
Re: Jeffs FS14 LS
Posted: Mon Oct 11, 2021 11:36 am
by VT_Jeff
pee wee wrote: ↑Mon Oct 11, 2021 11:31 am
Agreed, it's becoming a bit of a crap shoot. Like...."Shoot, this is apiece of crap!"
Re: Jeffs FS14 LS
Posted: Tue Oct 12, 2021 8:47 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Oct 11, 2021 11:36 am
Exactly.
Re: Jeffs FS14 LS
Posted: Wed Oct 20, 2021 7:23 pm
by VT_Jeff
Here's the result of one very hard season with the motor clamped to the transom without any protective plate. I'm over-drilling the mounting holes and will repair the gouges when I fill them.
I used a center punch to mark the bolt locations and then a centering guide to drill the holes but it appears that i still managed to get them off center, unless the lines i drew were off center. Either is as likely.
We've booked a 1-2 month road trip to the south in the spring so my glued lapstrake build is on hold while I get this boat sorted out for that trip. Its usable as-is but there are a bunch of small things to fix or upgrade that came to light in Virginia. Mounting the motor properly has been top of the list since I launched it but fishing kept getting in the way.
Re: Jeffs FS14 LS
Posted: Wed Oct 20, 2021 7:57 pm
by Mojosmantra
A couple of questions. What’s the big hole? A scupper? And curious how your graphite has held up and if you would do it again?
Re: Jeffs FS14 LS
Posted: Wed Oct 20, 2021 8:05 pm
by VT_Jeff
Mojosmantra wrote: ↑Wed Oct 20, 2021 7:57 pm
Yes, it's a scupper. I put one in the center to drain the space between the stringers where they are tall. I have a sole running bow to stern, no bilge, so the scuppers are key.
Graphite looks perfect, I'd not only do it again but will probably redo my driftboat bottom the same.
Re: Jeffs FS14 LS
Posted: Wed Oct 20, 2021 8:32 pm
by bamaguy0
Ooof! That's pretty chowdered up.
You think a lot if that is vibration from trailering or no? Did you use a transom saver?
Re: Jeffs FS14 LS
Posted: Wed Oct 20, 2021 8:46 pm
by VT_Jeff
bamaguy0 wrote: ↑Wed Oct 20, 2021 8:32 pm
The motor has some "teeth" that bite the transom, by design, and much of the damage is from those, and from raising the motor with a jack to adjust the plate location: those teeth raked the transom. I may use a sacrificial layer when I remount.
I dont use a transom saver because I trailer with the motor all the way down. You're not gonna be able to do that with your keel dragging the pavement in your quest to keep your hubs dry.
Edit: I'd love to keep my hubs dry but it's not in the cards for me, more on that later.....
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 9:31 am
by Dan_Smullen
Even a layer of 1/4" laminated to the hull would act as the sacrificial layer. Doesn't even have to be marine ply. Maybe just a piece of underlayment or luan. Scrape it off when it's time to replace.
Use is hard on boats for sure, and our build method probably results in a more fragile hull than most production boats. Would you agree?
Plenty of time to get ready for the Keys!
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 9:54 am
by VT_Jeff
Dan_Smullen wrote: ↑Thu Oct 21, 2021 9:31 am
You nailed it! Just made that piece this morning actually out of some scrap Okume(if there is such a thing). I'll probably seal the edges and call it good.
Definitely agree, esp the fairing compound as we're discussing in another thread.
My boat went into service probably a little prematurely because I didn't want to lose a season and no regrets there, but it def could have used a few more coats of paint on the deck, I should have added the outboard mounting plate and got the motor mounted correctly the first time to avoid the disaster that is now my transom, should have put a few more coats of varnish on the bright work, should have adjusted the fit of at least one of the hatch covers, etc. But none of those things would have turned the wife into a redfish-on-the-fly-obsessed maniac like actually using the boat in Virginia did, so absolutely no regrets, I did everything exactly right!
Yes........if I use it wisely! The Keys are out, btw, barring a major change. Going to Homosassa and Yankeetown in FL, Brunswick GA, Charleston SC and a few more spots on our way back up, very likely Chesapeake again towards the end of the trip(late april). The cost of RV parks in the keys was just more than we can stomach. $$$$$
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 10:05 am
by Jaysen
VT_Jeff wrote: ↑Thu Oct 21, 2021 9:54 am
Charleston SC
Look up Beaufort SC. I've got parking, ramp access and bad company directly across from the point of Paris Island for a couple of nights if you'd like to do some inshore that isn't fully populated. Reds, trout and flounder are the big ones I get. And we have a spare room if you can stand the company (I'm the problem not the wife... or the dog... or any other thing that might be crawling around down here).
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 10:29 am
by VT_Jeff
Jaysen wrote: ↑Thu Oct 21, 2021 10:05 am
Charleston SC
Ok, absolutely interested in wearing out that invitation! We won't need the spare room as we're bringing a bedroom etc with us but parking, boat ramp and some bad company sound IDEAL! Will probably be in that area 2nd-3rd full week of April, I'll give you fair warning when we have a tighter itinerary. I already have your address thanks to Fuzz's loose lips,
, and from the googles it looks like you are indeed in a very fishy looking area!
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 10:53 am
by Jaysen
VT_Jeff wrote: ↑Thu Oct 21, 2021 10:29 am
Charleston SC
From that google... the red roof due west is the launch. If the water is too rough use the station creek public ramp. If you want to get into more "human structure" fishing we would go to Beaufort downtown or Whitehall. Eddings point is closed, but there are other launches to get into the St Helena sound if you don't want to just motor up there. In April, even I catch fish.
I think you all are lure types. I can lay up some bait in the freezer if you tell me what you want to use. Right now is ideal as we have everything running in the Port Royal Sound. I also may be able to get you on a nearshore/offshore boat if you want to give that a run. Mostly reef fishing that time of year.
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 11:32 am
by VT_Jeff
Jaysen wrote: ↑Thu Oct 21, 2021 10:53 am
Thanks, I'll start sat-scouting! We're pretty fly-oriented so don't sweat the bait. Appreciate the offer on the boat-ride but we'll probably stick to the skiff and shallow stuff, at least out of the gate. We're treating this as a scouting mission(we treat just about everything like that) so not looking to set the world on fire, just want to learn some areas, see what works etc. Goal is to do a trip each spring and get some stops dialed in, St Helena looks like it def has long-term potential!
Glad to hear that April is popping there, that's great news!
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 2:03 pm
by VT_Jeff
Here's the sacrificial board for the motor mount. Its low-precision but should do the job fine. I feel like I say that a lot.......
- 20211021_135633.jpg (197.64 KiB) Viewed 132587 times
I was not well prepared for removing the motor and dinged the transom in the process. For the reinstall, I located the proper lifting hooks and made some dedicated straps.
With these, a come-along hung from the garage rafters, and a turn-buckle for fine-tuning the height, the re-install should be pretty drama free, we'll see
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 7:16 pm
by bamaguy0
Hey Yankeetown is a smidge under 2 hours for me. Hit me up if that ends up being a stop. Shoot, almost anywhere along that central gulf coast.
I'll have a baby to work around, but maybe I could grab a day pass with some good graces!
Re: Jeffs FS14 LS
Posted: Thu Oct 21, 2021 10:14 pm
by VT_Jeff
bamaguy0 wrote: ↑Thu Oct 21, 2021 7:16 pm
Hecks ya! Start earning those credits now! We're already reserved in homosassa and yankee town so barring something like the Delta 1000 variant, we'll be there, I'll pm you some details.
Re: Jeffs FS14 LS
Posted: Fri Oct 22, 2021 6:26 am
by Browndog
You will be coming right by me as well. Happy to host you for a few days along the way. I’m located just off Exit 67 on Interstate 95. 30 miles North of Brunswick, GA and 40 miles South of Savannah.
Got plenty of room at the house or at my In Laws condo. Lots to do and see around here. The fishing though is what the area is known for and one of the main reasons I retired here.
Re: Jeffs FS14 LS
Posted: Fri Oct 22, 2021 8:26 am
by Mojosmantra
What are you're parking requirements?
Re: Jeffs FS14 LS
Posted: Fri Oct 22, 2021 8:35 am
by VT_Jeff
Browndog wrote: ↑Fri Oct 22, 2021 6:26 am
That's great to hear Browndog, very much appreciated! We're going to visit an uncle in Cumming, GA and are looking to stay at Lake Lanier for a few nights, then either head down to the coast from there or head straight to FLA, we're still working that out, but I'll keep your offer in mind and see if it's in the cards, really appreciate it!
Re: Jeffs FS14 LS
Posted: Fri Oct 22, 2021 8:59 am
by VT_Jeff
Mojosmantra wrote: ↑Fri Oct 22, 2021 8:26 am
We roll a 24' RV with one slide and we tow the boat so we just need room for those. We're self-contained for up to a week or so as long as we can run the Genny for AC etc. Timing there would be 3rd week of march if you actually have room and feel like some company.
I had PM'd you some questions about the keys last week but I'm guessing you didn't see it since it's still in my outbox. It was more related to the fishing near Long Key near the park we were looking at, which turned out to be out of our budget for this trip. Would have been looking at a few grand for about a week, which is a little nuts but may have been do-able before I decided to pull the trigger on a new toy.......more on that later.
Re: Jeffs FS14 LS
Posted: Fri Oct 22, 2021 10:00 am
by Mojosmantra
Didn’t notice the PM’s - will check that out and get back to you
Re: Jeffs FS14 LS
Posted: Thu Oct 28, 2021 9:50 pm
by VT_Jeff
As trout season nears to a close and the leaves are about done falling, fly-fishing season morphs into fly-tying season for the Mrs, and boating season turns back to boat-building season for me.
We're in full-on prep mode for the spring trip, the one that's been pushed off for 2 seasons already. Elaine is studying up on salt species, patterns, habitats and techniques, and hitting the home gym to get tuned up for the 10k casts she's planning. I'm making some fairly major mods to the skiff, will post some updates when I have some progress.
These are Elaine's first few Red patterns, I suspect she'll be filling a good number of boxes before we head out.
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 5:52 am
by Jaysen
Tell her “shrimp, mullet and mud minnow”. Those are the three main dishes down here.
In April the shrimp will be 3-4”. We fish them under a rattle cork at the edges of the grass or over flats. That or we got trialing red right between the eyes with them.
Mullet should be under 3” over over 6”. These are held about 4” off the bottom right in the weeds I’d drifted on sand bottoms. That time of year… no flounder so weeds. If you see a tailing red hit them right between the eyes with it.
Mud Minnows are 2”-3”. If you think there is a fish stick on there. Trout are more likely to hit these on an out going tide within 3’ of a grass line or 3’ off the lee side of an oyster rake. Red fish… aim for the spot right between the eyes.
If she needs photos to help with patterns, let me know. Can get each pretty easy just need to head into the drink to sang them for you.
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 6:41 am
by bamaguy0
Seems Jaysen has it down pat. I think on the Atlantic side they use some crab patterns as well. Not sure how useful they are on the Gulf.
Once I wrap the boat up getting back in to fly tying seems like the logical thing to do. I did it a little bit as a kid because my dad would paint and tie poppers, but I never got very good at it.
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 8:33 am
by Dan_Smullen
Time we’ll spent for both of you!
Pop ‘n fly is another trick the locals like. Scaled down version of a popping cork.
Can’t wait to see what you’re cooking up on the boat!
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 9:24 am
by VT_Jeff
Jaysen wrote: ↑Fri Oct 29, 2021 5:52 am
Great info! Has been passed to the tier, feathers will soon be flying!
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 9:29 am
by VT_Jeff
bamaguy0 wrote: ↑Fri Oct 29, 2021 6:41 am
You'll be the Dad painting poppers soon enough!
I tried a few flies 25-30 years ago, shelved it along with fly-fishing for whitewater kayaking, which I found much better suited to my patience level at the time.
Re: Jeffs FS14 LS
Posted: Fri Oct 29, 2021 9:31 am
by VT_Jeff
Dan_Smullen wrote: ↑Fri Oct 29, 2021 8:33 am
Agreed! I'm like a kid on Christmas eve waiting for a few new "parts" come in!
Re: Jeffs FS14 LS
Posted: Thu Dec 09, 2021 4:40 pm
by Mojosmantra
Jeff - what's the shaft length on your trolling motor? Would you want it to be longer or shorter?
Re: Jeffs FS14 LS
Posted: Thu Dec 09, 2021 4:48 pm
by VT_Jeff
Mojosmantra wrote: ↑Thu Dec 09, 2021 4:40 pm
It's 48" and I'm pretty happy with it. Could be shorter, maybe as much as a foot shorter and still work fine, probably more so if your boat is not +10% like mine. The whole thing is a fly-line magnet but that comes with territory.
https://www.amazon.com/gp/product/B01HB ... UTF8&psc=1
I pm'd you again on the locks, good to go.
Re: Jeffs FS14 LS
Posted: Thu Dec 09, 2021 4:55 pm
by Mojosmantra
VT_Jeff wrote: ↑Thu Dec 09, 2021 4:48 pm
Good to know. I'm looking at 48" - but good to know 42" would work as well. I've been trying to tell myself that I don't need one, but the truth is I don't think I'd know what to do without one. I do a lot of solo fishing and poling platforms and push poles are pretty useless when your alone.
Re: Jeffs FS14 LS
Posted: Thu Dec 09, 2021 5:05 pm
by VT_Jeff
Mojosmantra wrote: ↑Thu Dec 09, 2021 4:55 pm
Yeah, we use ours constantly. It was out of service for a short time due to a bad breaker and it was brutal. I also use a SUP paddle quite a bit. Whatever it takes to get near the fish and not get yelled at for spooking them.
The way it mounts, on a puck, makes it really, really easy to un-mount/re-mount. I put the battery in the anchor locker for a very short cable run. The motor and the battery help balance the boat. Hard to make a case to go without, imo, just way too handy.
Re: Jeffs FS14 LS
Posted: Thu Dec 09, 2021 6:26 pm
by bamaguy0
Mine is 48" as well. Was thinking of cutting the shaft down to 36". I also have the quick release mount and a plug in the deck so I can strip it off if I know I don't want it for whatever reason.
Re: Jeffs FS14 LS
Posted: Mon Mar 07, 2022 1:57 pm
by VT_Jeff
Rv was STINKING every time we flushed. Scratched my head, did a quick search, found the issue. Mud wasps!
Re: Jeffs FS14 LS
Posted: Mon Mar 07, 2022 2:18 pm
by bamaguy0
Such an anti-climactic post! I've been on the lookout for an upgrade post pre trip.
Glad you resolved your smelly situation!
Re: Jeffs FS14 LS
Posted: Mon Mar 07, 2022 2:34 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon Mar 07, 2022 2:18 pm
I'm overdue for sure. Wanted to see how things worked before broadcasting too much. I can now say that my Franken-trailer appears to be a success. Got the boat and the shuttle-bike from VT to GA with no real issues. My customized boat cover also performed well.
Re: Jeffs FS14 LS
Posted: Mon Mar 07, 2022 2:38 pm
by bamaguy0
Digging the cover! I need info!
Re: Jeffs FS14 LS
Posted: Mon Mar 07, 2022 2:46 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon Mar 07, 2022 2:38 pm
I started with this:
https://www.amazon.com/gp/product/B019I ... UTF8&psc=1
I added the loops you see and then a continuous, 1" webbing "drawstring" so I can pull it tight around the protrusive rub rail. I added reinforced holes for the TM, the pole and for fender ropes so I can leave the cover on at the dock and still have fenders out.
Re: Jeffs FS14 LS
Posted: Tue Mar 08, 2022 7:13 am
by bamaguy0
That's awesome. Not sure if our sewing machine would be up for that.
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 10:33 am
by VT_Jeff
Here's a better shot of the cover mods.
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 10:39 am
by Jeff
Really nice job with the cover!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 1:35 pm
by Mojosmantra
That's some sweet work on the cover. Who's the seemstress - you or Elaine?
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 1:41 pm
by VT_Jeff
Mojosmantra wrote: ↑Wed Mar 09, 2022 1:35 pm
Thanks! That'd be me, Elaine's craft is cooking and fly-tying. I'm a terrible tailor, but that's all that's required for this stuff.
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 7:19 pm
by VT_Jeff
Storage and organization has been a big theme.i added some homemade rod holders to the console, swapped legs for a box to support the guest seat, dedicated pfd storage, binocular holders, and added a humongous forward control for the new motor I don't have yet.
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 7:22 pm
by VT_Jeff
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 7:26 pm
by VT_Jeff
More storage/organization. This is an old photo, it's not c-clamped on anymore.
Re: Jeffs FS14 LS
Posted: Wed Mar 09, 2022 7:39 pm
by VT_Jeff
Last one for now, scours honor!
Poling platform top and mounted. I'm using stays for racking resistance to keep the weight to an absolute minimum. Seems to support me fine. It is very light and cost was negligible. Took some time to do the bent-lam trim but that's interesting, fun work.
View with the stays attached
Re: Jeffs FS14 LS
Posted: Fri Mar 11, 2022 5:07 pm
by Dan_Smullen
Jeff, I commend your perseverance, completing the upgrades before your trip. Both of you will enjoy the time on the water that much more, and probably return to VT with a fresh list of necessary upgrades!
Re: Jeffs FS14 LS
Posted: Fri Mar 11, 2022 5:20 pm
by bamaguy0
Can't wait to see it in a couple weeks!
Re: Jeffs FS14 LS
Posted: Thu Mar 17, 2022 12:48 pm
by VT_Jeff
My sister Meg having a laugh...
Re: Jeffs FS14 LS
Posted: Thu Mar 17, 2022 1:04 pm
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Thu Mar 17, 2022 2:07 pm
by TomW1
Have fun on your trip Jeff. Tom
Re: Jeffs FS14 LS
Posted: Thu Mar 17, 2022 5:20 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu Mar 17, 2022 12:48 pm
Good to be loved! Right?
Re: Jeffs FS14 LS
Posted: Fri Mar 18, 2022 10:00 am
by VT_Jeff
TomW1 wrote: ↑Thu Mar 17, 2022 2:07 pm
Thanks Tom! So far things are great, just getting to homosassa today. Pics to come.
Re: Jeffs FS14 LS
Posted: Fri Mar 18, 2022 10:01 am
by VT_Jeff
Dan_Smullen wrote: ↑Thu Mar 17, 2022 5:20 pm
You said it bud! I am extremely fortunate to have a large, close family. True wealth!
Re: Jeffs FS14 LS
Posted: Fri Mar 18, 2022 10:05 am
by VT_Jeff
Couple pics from the trip so far. Lake Seminole State Park in ga is a great spot!
Re: Jeffs FS14 LS
Posted: Fri Mar 18, 2022 11:16 am
by VT_Jeff
Skiff pulling diuble-duty as cargo trailer. Learned this from my dad who would load his O'Day Javelin to the gills with camping equipment for yearly trips to Sebego Lake State Park in maine, half a century ago, foreal.
Re: Jeffs FS14 LS
Posted: Fri Mar 18, 2022 11:34 am
by Jeff
Nice!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Apr 13, 2022 2:37 pm
by VT_Jeff
Spare time has been very hard to come by since we hit the road 3 or 5 or 6 weeks back(it's all a blur at this point)....it's wake, work, fish, eat, repeat. Seizing the day is a big time commitment!
But.....I wanted to take a moment and mention the incredible hospitality we got from Trent and his family in the keys last week. Their generosity even outshined his boat finish, and that boat holds up to very, very, very close scrutiny! I kept hoping I'd find a flaw somewhere to make me feel better but it was not to be, it's a true gem! He was also kind enough to keep our spare time filled up by having us searching for a pin-fish trap which was not actually in the water. I'll post a photo of my tracks at some point. Trent is sure that I ran over it, and I'm not convinced I didn't. Apparently they do get stolen occasionally, which sucks royal balls.
Also, Trent told us exactly where to find juvi tarpon. We went there, and there they were. Elaine hooked and jumped a few. Nothing boated to due my limitless ineptness but that's ok.
Also, in addition to being a talented fisherman, cook and boatbuilder, Trent is also a talented six-strummer and a vocal dead-ringer for Eddie Vedder! We had a great jam session after eating all the deliciuos snapper that he and his family caught-n-cooked for us. Great, great time!
We're in Yankeetown this week and ozello next week. Looking forward to meeting up with Cameron this weekend so we can console each other about Trent's FS14LS winning the coveted Seaslug award, and maybe do some fishing and oyster-bed-dodging together.
Till later,
Re: Jeffs FS14 LS
Posted: Wed Apr 13, 2022 5:15 pm
by Dan_Smullen
Awesome report, Jeff!
Re: Jeffs FS14 LS
Posted: Thu Apr 14, 2022 5:51 pm
by bamaguy0
What I'm hearing is we have to the battle to the death for 2nd place!
Re: Jeffs FS14 LS
Posted: Thu Apr 14, 2022 5:57 pm
by VT_Jeff
bamaguy0 wrote: ↑Thu Apr 14, 2022 5:51 pm
Listen, I love my boat(most days) but because of <insert myriad excuses here> it's just not up to the standards that yours and Trents are, so I will gladly and humbly accept 3rd place, at least until the next one is finished.
Re: Jeffs FS14 LS
Posted: Fri Apr 15, 2022 5:20 am
by cape man
Your wife should get a cover.
Re: Jeffs FS14 LS
Posted: Fri Apr 15, 2022 9:33 am
by VT_Jeff
cape man wrote: ↑Fri Apr 15, 2022 5:20 am
Ha! Agreed, here is my submission: she got this on a fly she tied over the winter, chaotic fight in 8" of water.
Re: Jeffs FS14 LS
Posted: Fri Apr 15, 2022 11:36 pm
by Fuzz
I keep thinking if your gal and mine ever got together no fish on the planet would be safe. Mine keeps asking to go fishing and I ask her would it be ok if we let the ice melt first
Re: Jeffs FS14 LS
Posted: Sun Apr 17, 2022 7:32 am
by VT_Jeff
Fuzz wrote: ↑Fri Apr 15, 2022 11:36 pm
No doubt Fuzz! Maybe one of these years we'll make the overland journey and come back by ferry as some friends have done., Maybe Narfis airplane will be done and "Lost My Mind" will be done and splashed. In the meantime, drill some holes in the ice so your missus can get a quick fix!
Re: Jeffs FS14 LS
Posted: Mon Apr 18, 2022 6:27 am
by glossieblack
Curious about your build of Iain Oughtred's beautiful all-rounder, Tammie Norrie. How far have you got?
Re: Jeffs FS14 LS
Posted: Mon Apr 18, 2022 2:59 pm
by VT_Jeff
glossieblack wrote: ↑Mon Apr 18, 2022 6:27 am
I built the strongback and redrew the transom for 6mm ply with some help from Ian. That's about it, hopefully this winter I'll get some traction on it depending on how many mods I have to make on the FS.
Re: Jeffs FS14 LS
Posted: Mon Apr 18, 2022 3:40 pm
by Mojosmantra
What Jeff isn't telling you all is that the "Blue Sky" has been fished more often and harder in one year than a lot of boats see in a lifetime...and it's holding it's own. Those guys have a "just fish" mentality. If it ain't broke, don't fix it...until it starts snowing
Re: Jeffs FS14 LS
Posted: Mon Apr 18, 2022 8:12 pm
by VT_Jeff
Mojosmantra wrote: ↑Mon Apr 18, 2022 3:40 pm
This boat has indeed been absolutely abused since it got splashed. "Ridden hard and put away wet", over and over. It got us on a few snook tonight in ozello.
Re: Jeffs FS14 LS
Posted: Wed Apr 20, 2022 8:29 pm
by VT_Jeff
Elaine's first red on the trip! Ozello, some nameless key near the mouth of st martins river.
Re: Jeffs FS14 LS
Posted: Thu Apr 21, 2022 9:32 am
by Jeff
Looks like you guys are having a great time!! Jeff
Re: Jeffs FS14 LS
Posted: Thu Apr 21, 2022 9:42 am
by Mojosmantra
What's next on the bucket list?
Re: Jeffs FS14 LS
Posted: Thu Apr 21, 2022 10:20 am
by VT_Jeff
Mojosmantra wrote: ↑Thu Apr 21, 2022 9:42 am
We'd like to cook one! Elaine had promised the fishing gods that she would not keep her first slot red, which I'm guessing this was though we didn't measure it. We're headed to St Helena Island next in SC to visit our esteemed site Admin Jaysen for a few days and from our research and some info Jaysen has provided, there should be some reds to be had there, maybe we can get one in the pan. Jaysen has some intriguing preparation ideas, would love to give them a try. After that we're headed to Richmond so Elaine can do some WW kayaking and I can do some QC on Dan Smullens C19, make sure it's up to your standards and not merely mine!
And then, bitter-sweetly, home.
BTW, Cameron came down to meet us in Yankeetown and led the way to Rocky Cove where I got a nice red, no photo of the red but here's bamaguy styling his very excellent FS14LS build.
Much like Trents, the build quality and finish is beyond incredible! Cameron has also become my technical assistant, solving myriad plotter issues and helping me shop and spend my money on high-priced trolling motors.
We didn't get a ton of time since he's got a baby and has his priorities straight, but we had a fun time navigating some chop and some shallows and have planned a weekend in Ozello next year.
Some quick review info for this area:
Ozello Keys Marina and Campground is a great, great place!. Just a few nice camp sites with dockage attached to a marina. Easy access to St Martins River and the gulf, taco truck on-site, peaceful surroundings, fishing guides coming and going all day with info to share.
Camp-n-Water in Homosassa was very nice also, much more of an RV park feel and a longer run to the Gulf but also a lot more going on as far as restaurants/attractions if you need that stuff.
B's Marina and Campground in Yankeetown served us well for a week. Not appropriate for a honeymoon but a decent fish-camp. It's idle/minimum wake speed to the gulf this time of year so it can take some time. Yankeetown has some drainage issues so bring some mud boots if there's any rain in the forecast. Our first day in the Withlacoochee we saw Dolphins, gators, bald eagles, manatees and maybe got a snook or two so no complaints there!
Lake Seminole State Park in GA is an awesome spot if you like to bass fish. Beautiful park, can leave your boat in the water at your site, really nice.
We have already reserved in Ozello and Big Pine Key for next year, will most likely hit Lake Seminole on our way down again. So, as far as a scouting mission, 100% success already!
Re: Jeffs FS14 LS
Posted: Thu Apr 21, 2022 10:21 am
by VT_Jeff
Jeff wrote: ↑Thu Apr 21, 2022 9:32 am
Most definitely! Took us 2-3 years longer than expected to get here but has been well worth the wait!
Re: Jeffs FS14 LS
Posted: Sun May 08, 2022 5:07 pm
by bamaguy0
Enjoyed the time on the water. Wish I could have hung around camp a bit. I'm definitely looking forward to the weekend at Ozello Keys next year. Seems like a great place!
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 2:32 pm
by VT_Jeff
Going to attempt to mount my new 30hp tonight. For fun, because math is fun......
6000 rpm / 2.08 ratio * 12" pitch * 00095(inches per minute to mph) = 32.88 mph theoretical top speed.
I'm taking bets on actual top speed, closest to the pin wins accolades.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 2:38 pm
by Fuzz
28.04
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 2:47 pm
by VT_Jeff
Fuzz wrote: ↑Wed Jun 29, 2022 2:38 pm28.04
Ok, that's about a 15% loss (100 - ((28.04/32.88) * 100)), which seems pretty reasonable, I wish you luck!
Now you have to watch out for the "1 mph" and the "28.05" wise-asses.
This is an absolute-value contest, btw, so closest/over is fine.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 4:30 pm
by bamaguy0
30!
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 5:52 pm
by Mojosmantra
32.89 - I’m hopeful for you.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 7:02 pm
by TomW1
If weight is 900lds all in as it leaves the dock, 38mph. Jacques warned of overpowering this boat. A 25hp would give the low 30's. In the study study plans he lists a 5" draft at 610lb diplacement with a PPI of 200lbs. So, if you're under 900lbs your speed will go up.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 7:05 pm
by VT_Jeff
TomW1 wrote: ↑Wed Jun 29, 2022 7:02 pm
38. Booked.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 7:09 pm
by VT_Jeff
That's about my guess. We'll have to share the prize.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 8:55 pm
by VT_Jeff
Mojosmantra wrote: ↑Wed Jun 29, 2022 5:52 pm
My bottom may just be slick enough for some negative slip, we'll see. I do like the confidence! Catch another fish yet?
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 9:34 pm
by cape man
32.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 9:57 pm
by VT_Jeff
32 for Craig, in the book, good luck.
The square pegs at the end of my controller harness do not fit in the round hole on the engine harness, an adapter is needed, so I may be sol for 4th weekend barring a miracle. Putting the 20 back on is not an attractive option at this point. Luckily the sailboat got splashed this morning so I'm not completely without boating options,just fishing options.
First world problems!
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 10:08 pm
by bamaguy0
This weekend is when the crazies come out anyway! Staying away from the water is my kinda fun.
Re: Jeffs FS14 LS
Posted: Wed Jun 29, 2022 10:32 pm
by VT_Jeff
bamaguy0 wrote: ↑Wed Jun 29, 2022 10:08 pm
Yeah, amateur hour, like drunk people on new years eve! The pros stay home!
Re: Jeffs FS14 LS
Posted: Thu Jun 30, 2022 3:59 am
by OneWayTraffic
Reckon you'll get 33mph going downhill. Just find a good current.
Re: Jeffs FS14 LS
Posted: Thu Jun 30, 2022 8:30 am
by VT_Jeff
OneWayTraffic wrote: ↑Thu Jun 30, 2022 3:59 am
While in FL we did find some pretty decent slopes, here in Lake Ontario it tends to be a little flatter but I'll see if I can find a nice downwinder for ya!
Re: Jeffs FS14 LS
Posted: Fri Jul 01, 2022 9:30 am
by VT_Jeff
Still breaking it in so have not hit full throttle yet but a few things are clear already:
1. It's going to do at least 30. I've hit 28/29 already without pinning it.
2. The 20 was definitely underpowered for this build: I was regularly twisting the grip past it's stop looking for more power/speed. With the 30hp, I can cruise 24mph at like 3/4 throttle. With the 20, 24mph was top speed downwind. Adding pitch to the 20 was not an option as it struggled to hit max rpm with the three of us on it(Elaine, myself and the dog).
3. Having full remote controls is an insane upgrade over the split controls I had before. Docking is a breeze now. Also, the 30hp has tilt/trim, the 20hp only had tilt, so that is super-nice.
No regrets on starting out with the slightly-used 20hp/tiller, it was a great deal and I got a full trade-in(or close, I was supposed to trade it in before I put a few hundred salt hours on it
) on it and it got me out on the water when my budget was tight.
Fuzz, you're out of the running. Sorry buddy, can't win em all.
Re: Jeffs FS14 LS
Posted: Fri Jul 01, 2022 10:24 pm
by TomW1
I expect you to be at 5900 t0 6000 rpm's when you record top speed.
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 12:22 pm
by Fuzz
VT_Jeff wrote: ↑Fri Jul 01, 2022 9:30 am
Oh well can't win them all. And higher the speed is mo better for you
Over 30 in that small of a boat has to feel like you are flying.
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 12:35 pm
by bamaguy0
30 is about as fast as I'd care to go in mine for sure!
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 2:48 pm
by VT_Jeff
I got it pinned momentarily and it was right at 30. Was not glass but I think it's gonna be 30-31 max.
For 3 years we've been trying to get a freshwater drum on the fly in Lake Ontario. Finally happened today. Fly was a "mop" tied from a piece of rain-x sponge. Elaine did the tying and the catching, I drove the boat.
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 3:20 pm
by TomW1
Congrats that is a nice drum, they are hard enough to catch on live bait but on a fly, wow.
What rpms were you at when you pegged top speed?
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 3:35 pm
by Jaysen
bamaguy0 wrote: ↑Sat Jul 02, 2022 12:35 pm
As evidenced by his next post (and what I’m sure we both noticed in person) VTJeff isn’t the one setting the boat requirements.
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 8:41 pm
by bamaguy0
Jaysen wrote: ↑Sat Jul 02, 2022 3:35 pm
Elaine was nice enough to lend me Jeff for the day when we met up! He actually got to fish.
Re: Jeffs FS14 LS
Posted: Sat Jul 02, 2022 10:16 pm
by VT_Jeff
TomW1 wrote: ↑Sat Jul 02, 2022 3:20 pm
Thanks!
No tach but safe to assume it was the design max of 6000.
Re: Jeffs FS14 LS
Posted: Sun Jul 03, 2022 6:33 am
by cape man
Come on. You can get one more little mile per hour and hit my 32!
Alone my dory hits 31 with a 70. I slow it down right away...usually.
30mph in that boat is flying. Bet you're happy!
Re: Jeffs FS14 LS
Posted: Sun Jul 03, 2022 6:50 am
by Dan_Smullen
Stoked for y’all on the upgrade! Nice of you to give her a new heart on her birthday.
How’s it feel at 30+, Jeff?
Re: Jeffs FS14 LS
Posted: Sun Jul 03, 2022 10:05 am
by VT_Jeff
Fuzz wrote: ↑Sat Jul 02, 2022 12:22 pm
Yeah, 30 feels a bit excessive......Jon Davis does 45 in his....
Re: Jeffs FS14 LS
Posted: Fri Jul 08, 2022 9:22 am
by VT_Jeff
30.3 looks like the max with just me on glass. With Elaine and I, it was 29.2 or so. Both speeds more than fast enough. Cruising effortlessly at 25 is amazing.
Stand-by for latest fish-pic, it's a doozy!
Re: Jeffs FS14 LS
Posted: Fri Jul 08, 2022 9:40 am
by VT_Jeff
Got another monster drum on the fly. I actually think we are getting the hang of it!
Re: Jeffs FS14 LS
Posted: Fri Jul 08, 2022 11:19 am
by Mojosmantra
Nice!
Re: Jeffs FS14 LS
Posted: Fri Jul 08, 2022 12:57 pm
by TomW1
Nice fish. I have an aunt named Elaine that is in her 90's may your wife have a long life also.
Re: Jeffs FS14 LS
Posted: Fri Jul 08, 2022 2:11 pm
by VT_Jeff
TomW1 wrote: ↑Fri Jul 08, 2022 12:57 pm
Good for Auntie Elaine! As long as she outlives me, don't matter!
Re: Jeffs FS14 LS
Posted: Sat Jul 09, 2022 8:10 am
by Jeff
Great catch!!!!! Jeff
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 8:04 am
by Dan_Smullen
Tank!
How long did it take to get that slob to the boat in what weight rod?
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 9:41 am
by VT_Jeff
Dan_Smullen wrote: ↑Sun Jul 10, 2022 8:04 am
Tank!
Ha! Yes, it was a slab. 9 weight rod, 5-8 minutes. Towards the end it kept going under the boat, I had to troll away to get some angle on him without turning the rod into a G clef. She got lashed, again, about a minute in after the first run, we thought we were done for but it worked out. And yes, I use "we" a lot.............but i built the boat!
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 10:26 am
by cape man
She wouldn't have caught it without you. Sinking fly and line?
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 10:44 am
by VT_Jeff
cape man wrote: ↑Sun Jul 10, 2022 10:26 am
Thanks Craig!
This is the fly.
Called a "mop", tied with a #8 jighook from a piece of rain-x sponge. Elaine had been tying these for trout and had a hunch the drum may like them, she was right.
Floating line, no weight, the fish was in a foot of water near the bank. We see a lot at the drop-off but they are impossible to get them to eat. When they are on the shelf, shallow, they seem more willing. It was a true sight-cast, follow, eat, strip-set, just like on the flats. Super-fun!
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 1:55 pm
by Dan_Smullen
Wild stuff! Kind of looks like a mealworm or a maggot pattern.
Re: Jeffs FS14 LS
Posted: Sun Jul 10, 2022 2:25 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Jul 10, 2022 1:55 pm
Mealworm was our read also.
Re: Jeffs FS14 LS
Posted: Mon Jul 11, 2022 9:52 am
by bamaguy0
I was reading up on the Mop...that's a scandalous fly!
Re: Jeffs FS14 LS
Posted: Mon Jul 11, 2022 11:23 am
by VT_Jeff
bamaguy0 wrote: ↑Mon Jul 11, 2022 9:52 am
Yes, a purists nightmare! We ain't no purists!
Re: Jeffs FS14 LS
Posted: Mon Jul 11, 2022 6:32 pm
by bamaguy0
I mean it honestly doesn't sound much different than an easier way to make a wooly bugger. Those are pretty much a universal fly as well.
Seemed a little much to BAN the fly from tournaments.
Re: Jeffs FS14 LS
Posted: Mon Jul 11, 2022 6:43 pm
by VT_Jeff
bamaguy0 wrote: ↑Mon Jul 11, 2022 6:32 pm
I think wooly buggers have a similar "mystique".
Re: Jeffs FS14 LS
Posted: Mon Jul 11, 2022 6:51 pm
by bamaguy0
I'm a wooly bugger kinda guy, so maybe I'm a mop kinda guy too!
Re: Jeffs FS14 LS
Posted: Tue Jul 12, 2022 9:34 am
by VT_Jeff
bamaguy0 wrote: ↑Mon Jul 11, 2022 6:51 pm
I'll have Elaine whip a few up for ya!
Re: Jeffs FS14 LS
Posted: Tue Jul 12, 2022 9:49 am
by cape man
Fishing the Madison and/or Galitin Rivers at the end of the month. Have a 4 day meeting in Bozeman and a friend with a float boat! Last year on the Yellowstone, I saw a guy catching brown trout when nobody else was, using something a lot like that "meal worm" but darker. There's certainly a lot to "match the hatch", but I also think fish aren't as picky if it looks edible.
Really nice drum!
Re: Jeffs FS14 LS
Posted: Wed Jul 13, 2022 2:27 am
by TomW1
cape man wrote: ↑Tue Jul 12, 2022 9:49 am
That is certainly true on the trout up here Craig. If nothing is hatching pick a fly or lure that they may eat. Shoot even artificial scented eggs sometimes work. Enjoy your trip!!!
Re: Jeffs FS14 LS
Posted: Wed Jul 13, 2022 7:13 am
by VT_Jeff
Really nice drum!
Enjoy that trip Craig! We're going to go through that area at the end of our roadtrip next spring and see what we can float. Hope you get some nice weather and some nice fish!
Re: Jeffs FS14 LS
Posted: Wed Jul 13, 2022 8:05 am
by cape man
The Yellowstone is probably still going to be hard to access next spring but floating the Madison near Ennis is beautiful.
Re: Jeffs FS14 LS
Posted: Wed Jul 13, 2022 8:09 am
by VT_Jeff
cape man wrote: ↑Wed Jul 13, 2022 8:05 am
Agreed, we were thinking probably best to just avoid Yellowstone altogether and let them do their work in peace. I'll read up on Madison near Ennis, appreciate the tip.
Re: Jeffs FS14 LS
Posted: Wed Jul 13, 2022 11:20 am
by cape man
The Galatin is also awesome along the north edge of the park. Plenty of places to pull off and walk down to the river that is in a narrow canyon. Smashed small rainbows for several hours one year all on cadis flies, and the scenery is amazing. That's towards the headwaters and the water is VERY cold! No waders, and after a few hours had to stop as I could no longer feel my feet.
Last summer I had a blast with small cuthroat in the Soda Butte which is near the eastern entrance. It flows into the Lamar River which I also fished, but didn't catch, listening to the bison which were about 50 yards away across the river.
Re: Jeffs FS14 LS
Posted: Tue Apr 11, 2023 8:59 pm
by VT_Jeff
Had a grand time in chokoloskee. This is a massive area, lot of water to cover and to learn. Bring a gps! We mostly stuck around the immediate area, though we did do an outside run to Pavillion key, some bights near Plover key and an inside run up the Lopez and down to the mouth of the Huston. Weather has turned so we're bolting a bit early, seriously contemplating a return trip next year, though i will pay closer attention to tides next time, try to time low tides with high sun.
Elaine managed a sight-cast snook, tarpon and sheepshead, a blind cast to a sweet red, and blind casts to myriad trout, ladyfish, snapper etc. I did a lot of poling. I did pickup a nice snook in ozello on a soft plastic, as well as a few bass in columbus and seminole.
Boat worked great, was never actually on fire. Looks like i'm getting around 10 mpg with the honda 30hp. The 40 mile round trip to the huston mouth had us getting pretty low in the 5 gallon tank, we brought a few extra in a jerry.
Met a lot of great folks here including a morning dog walking group, which was fantastic.
Next up is Lake Lanier, then Chesapeake bay to get an early ride on the SS Smullen.
Re: Jeffs FS14 LS
Posted: Tue Apr 11, 2023 9:32 pm
by Jaysen
Nice! Send up a flare as you speed by!
Re: Jeffs FS14 LS
Posted: Tue Apr 11, 2023 10:00 pm
by VT_Jeff
Jaysen wrote: ↑Tue Apr 11, 2023 9:32 pm
Will do bud, hope you are well and warmedt hello to your better half from Elaine and me!
Re: Jeffs FS14 LS
Posted: Wed Apr 12, 2023 8:12 am
by Jeff
Nice Jeff, looks like you guys had a great trip!!! Jeff
Re: Jeffs FS14 LS
Posted: Wed Apr 12, 2023 11:41 am
by TomW1
Really nice Jeff looks like you had a great time to get out of the cold. Tom
Re: Jeffs FS14 LS
Posted: Wed Apr 12, 2023 2:05 pm
by Fuzz
That looks like a great trip!
Makes me want to cry as I sit here watching it f%^& ing snow
Re: Jeffs FS14 LS
Posted: Fri Apr 14, 2023 11:33 am
by Dan_Smullen
Nice work Campbells! I can't wait to show you around the Lower Bay!
Re: Jeffs FS14 LS
Posted: Mon Jan 01, 2024 5:17 pm
by VT_Jeff
Long time no post. Have made good progress on my glued lapstrake Tammie Norrie. Been a fun and challenging process. Ordered a sail kit for it but dont expect to actually sail it till summer '25 based on current schedule.
Re: Jeffs FS14 LS
Posted: Mon Jan 01, 2024 9:51 pm
by cape man
How big is that, and who's design? Loving it already...
Re: Jeffs FS14 LS
Posted: Tue Jan 02, 2024 7:58 am
by VT_Jeff
cape man wrote: ↑Mon Jan 01, 2024 9:51 pm
Thanks CapeMan!
It's an Iain Oughtred Tammie Norrie, 13'6", balanced lug/yawl.
Re: Jeffs FS14 LS
Posted: Tue Jan 02, 2024 12:01 pm
by PapaDave
That is a really interesting boat Jeff. Love the shape of the transom.
Re: Jeffs FS14 LS
Posted: Wed Jan 03, 2024 9:23 am
by cape man
[It's an Iain Oughtred Tammie Norrie, 13'6", balanced lug/yawl.]
I thought it looked similar to Glossieback's pram. I like the lines he has developed, and lapstraking with thin ply is pretty cool.
Re: Jeffs FS14 LS
Posted: Wed Jan 03, 2024 11:55 am
by VT_Jeff
cape man wrote: ↑Wed Jan 03, 2024 9:23 am
Yes, his is an Oughtred Feather Pram, which he did an incredible job with! It takes a good deal of care and planning to bright-finish a glued lapstrake, very impressive. My sheetstrake, stem, transom and 'wales will be bright, along with some thwarts and seats. The hull will otherwise be painted inside and out, hidiing many a screw-hole and myriad other holidays.
The Tammie Norrie, to me, looks much like a Glue-lapstrake adaptation of the Whitehall Pulling boat, at least as it's presented in John Gardeners book "Building Classic Small Craft. The bow at station #1 on both (and probably many others) is "pinched" to avoid a bulbous entry, apparently. Seeing this pinch develop during the planking process was a little unsettling, causing me to check the shape and measurements of my 1st station many times. i THINK it's correct, but regardless, it's there/done!
Re: Jeffs FS14 LS
Posted: Wed Jan 03, 2024 12:00 pm
by VT_Jeff
PapaDave wrote: ↑Tue Jan 02, 2024 12:01 pm
Thanks Dave. It's a true wineglass transom, esp once the skeg gets on there, hopefully soon.
