Biggest difference is that there is no clear indication that you’ve got enough epoxy on. It basically looks the same wet or dry. Prewet what you put it on, and measure out the correct amount of epoxy as well. It’s much stiffer than glass, but for something like this compounded plywood with framing probably wouldn’t need it. It does allow you to reduce framing though. I didn’t want 2 by 4s overhead. I’ll likely cf tape or glue an aluminium strip underneath to make a sandwich of sorts.Dan_Smullen wrote: ↑Mon Feb 13, 2023 9:43 am Looks good! Did you laminate in a form?
Any notable takeaways after laminating with cf?
C17 in New Zealand.
Re: C17 in New Zealand.
Best way is to add a neat coat over the carbon so any sanding won't hurt it.OneWayTraffic wrote: ↑Mon Feb 13, 2023 11:50 pmBiggest difference is that there is no clear indication that you’ve got enough epoxy on. It basically looks the same wet or dry. Prewet what you put it on, and measure out the correct amount of epoxy as well. It’s much stiffer than glass, but for something like this compounded plywood with framing probably wouldn’t need it. It does allow you to reduce framing though. I didn’t want 2 by 4s overhead. I’ll likely cf tape or glue an aluminium strip underneath to make a sandwich of sorts.Dan_Smullen wrote: ↑Mon Feb 13, 2023 9:43 am Looks good! Did you laminate in a form?
Out of curiosity, I see that your cockpit gunwales and motor well bulkhead look horizontal, you have removed the camber of the original plan, and kept it on the front deck, is that right ? I'm currently considering what camber to use on mine, probably half the original design.
News says you guys are having bad flooding. I hope it is not happening in your area.
That's right. Frame C is pretty much as designed, except that instead of the designed cabin, I had the walls a bit closer to the sides, and about 150mm lower than designed. It's high enough to give shelter from the wind, but low enough that one can stand and cast over, or reach forward to get the anchor. A canvas canopy from the t-top to cover the windscreen is an option for camping, if I want to.OlivierP wrote: ↑Tue Feb 14, 2023 3:23 pm Out of curiosity, I see that your cockpit gunwales and motor well bulkhead look horizontal, you have removed the camber of the original plan, and kept it on the front deck, is that right ? I'm currently considering what camber to use on mine, probably half the original design.
Frame D and the motorwell are cut straight and the gunwale curves between C and D from cambered to horizontal. With the open transom I think this looks better, and it's definitely better for sitting on. The gunwale is a great height to sit on and fish in good weather.
I did lose some storage space in the boat when I cut the transom straight, but it's easier to climb over and fix an auxiliary outboard to, and there's still room there for tote tanks and battery. There's also a little bit of side storage, a compartment under the skippers seat, a 30gallon cooler compartment on the left side (drain out the side), storage under the berths forward, some storage in the consoles, and the anchor locker forward.
Thanks for the concern.
I'm in Canterbury, about halfway down the South Island. We don't normally catch the cyclones here. In general NZ only gets a bad Cyclone once every generation or so. Last time was 1988. This one has certainly casued a lot of widespread damage. Auckland especially can't catch a break with really bad flooding only two weeks ago.
Anyway, so far all we've had is a gentle rain.
Finally contracted sanding fatigue and put two coats of bed liner on. This is Bullyliner, a waterborne rubber coating. Brush or spray on and hides minor scratches and marks. Two coats a day. I’d recommend it for places where you want a tough coating and aren’t afraid of workboat style.
Good US product no VOC's like others. Yours looks good. Did you use the light gray?
Lightning grey yes. I’m using the last of it for another coat today, looking to touch up pinholes first and then wherever I’m expecting extra wear. I brushed up and under the gunwales as well, mostly just for protection vs UV reflection.
Took it out of the tunnel house for a sand and wash prior to paint. Few bits and pieces that I’d like to fill first. At the moment it’s a ten foot finish.
