Skoota windshield lines poll
Questions and Answers about the Woods Designs, multihulls and others.
fallguy1000
Post by fallguy1000 »
I have had too much time sitting here with mystery illness and wanted to ask you guys a question about the windshield.
The roof has a slope of about 1" every 18" or so. Roughly a 8" drop iirc from the aft to forward edge.
My question is rather simple, but you need the story first.
I plan to install a cage or a windshield/hardtop above the roof because my eyes burn so bad from wind that I can't operate the boat in the evenings is really terrible. And I am in Minnesota and it is so fargin cold here; driving fast in 49 degree weather tends to burn eyes as well and I can heat an enclosure.
The enclosure will run from roughly 2 feet forward of the aft cabin edge and probably about 4 feet or at least 30" aft. That area behind is the bench and standing room at the helm is all. So, the top is about 4.5 to 6 feet longs.
Do I
A) Maintain the same pitch of the roof? This would mean I start the roof 2 feet into the cabin and the aft portion of the rooftop is roughly 3" higher.
or
B) Design the hardtop roof with only a very slight pitch closer to DWL
C) Some alternative like start with A and then chop it down hard at the back so it doesn't look like a spacecraft launchpad
Pros and cons
A
Pros
Looks the same as the roof
Any error in the boats final waterline is not revealed
Cons
Makes the hardtop pitch up really high for only aesthetics
(the roof will be about 9 feet or higher above the cockpit
B
Pros
Is lower at the back, but only by 3-5".
Cons
Could show errors in DWL only correctable by ballasting
Best I got is a link to a file.
https://www.facebook.com/richard.woods. ... ookaside=1
viewtopic.php?f=12&t=62495
fallguy1000
Re: Skoota windshield lines poll
Best view of current stuff no windshield.
Also wondering ? 27" head clearance enough for my big fat head?
Fuzz
Post by Fuzz »
I like the idea of starting the windshield a couple feet forward of the aft bulkhead. I think it should follow the roof line. One question, is this going to cause any height problem when it comes to moving it down the road?
fallguy1000
Fuzz wrote: Wed Apr 15, 2020 5:16 pm I like the idea of starting the windshield a couple feet forward of the aft bulkhead. I think it should follow the roof line. One question, is this going to cause any height problem when it comes to moving it down the road?
All has to be removable and demountable.
I just realized if I build it flat, water will run all over the friggin place.
Has to have the sheer of the roof. But I will make it flat; it would be silly to bend it
Fuzz
Post by Fuzz »
You should think about drainage a lot. It really sucks to have water either dripping on you or worse coming off all at once and soaking you.
fallguy1000
Fuzz wrote: Wed Apr 15, 2020 6:23 pm You should think about drainage a lot. It really sucks to have water either dripping on you or worse coming off all at once and soaking you.
Yeah. I am planning to reduce the helm enclosure so it can warm up better and that means the windshield is helm only. I don't care about the looks (much). But by doing that any rain/spray will blast off the top of the roofdeck and onto the cockpit. For that reason alone, the wider and aesthetically more pleasing, heavier all the way across option would be nicer. But, boats get wet.
We have put some thought into other areas. There is a gap between the hulls and cabin that will waterspout in the shit. To avoid waterspouts, my current plan is to build some filler piece and wrap in black neoprene silencing. But it will really require some ingenuity. Parts like these aren't in the drawings for prototypes. You just know you need them as the build progresses.
fallguy1000
Any opinion on my windshield/helm enclosure?
fallguy1000
This is a sketch of just the helm at say 42" wide.Going all the way across would be about 98". Lot more cost for the colder enclosure and all I get is one bench covered really.
Fuzz
Post by Fuzz »
I like the idea of making a place for another person to sit and visit in comfort with the helmsman. And if a person is a little prone to getting sea sick being there might make much better for them.
fallguy1000
Fuzz wrote: Wed Apr 15, 2020 9:10 pm I like the idea of making a place for another person to sit and visit in comfort with the helmsman. And if a person is a little prone to getting sea sick being there might make much better for them.
That is a double bench.
