Make a 3/8" radius gauge.
Take a small piece of plywood scrap.
Make an intersecting line with 90s.
Drill a tiny hole on the intersection.
Drill a 3/4" hole. Cut with an oscillating tool and keep 1/4 of two sides of the thing. Throw the other 2 away.
new build GT Cruiser 23
Re: new build GT Cruiser 23
Cool thank you.
Fiberglass applied wrong is mighty tough. I’m pondering getting a variable speed belt sander. Any thoughts.
Nnnoooooooo!
Big mistake.
The best tool for grinding glass is a Festool Rotex sander which can also be used for fairing and sanding paint.
The other option is a Festool RTS400 or supercedes.
Use 40 grit paper only for removal. The Festool and any papers, for that matter, lose their edge fast in glass and epoxy..lotsa paper changes are needed.
I have a couple rts400s.
All Festools are repairable, but not cheap.
I am a seasoned user of tools and would NEVER use a belt sander to do that job. Not ever.
Big mistake.
What are you using now?
Probably nothing suitable.
Lots of rotary sanders won't keep turning and are useless, but a belt sander will ruin plywood and is considered an implement of destruction.
fallguy while the Festool is the Gold standard many boats have been built here with random orbit sanders a 6" is best but 5" is fine if that is what you have. Make sure you have a quality one. Sandpaper is readily available and cheaper than the Festool and a dust collection system works very well. While your correct to give your opinion give other options also. Tom
Also when a lot needs to be removed over a big area then the angle grinder and or belt sanders can do a nice job and like Fuzz has stated more than once, it's a delicate touch, paraphrasing. I have used both on my build and they are very handy tools to have in the tool shed. But like any tool, you need to know how to use them correctly.
Pictured is a 0-3000rpm sander/grinder. With 36 grit 3M green disks it will move glass like no random orbit sander will. With a careful touch it is a champ. But it can be a WMD if given a chance. The ZEC disk shown is a whole other level. It make the green disk seem like it is hand sanding! Either one will cure your problem but I must stress to use at your own peril
Most ros do not have a continual drive, so as soon as you press down; they stop.TomW1 wrote: ↑Thu Dec 08, 2022 11:41 am fallguy while the Festool is the Gold standard many boats have been built here with random orbit sanders a 6" is best but 5" is fine if that is what you have. Make sure you have a quality one. Sandpaper is readily available and cheaper than the Festool and a dust collection system works very well. While your correct to give your opinion give other options also. Tom
And therein lies the rub. Most ros do not hog glass. I thought she said she had one already.
Fuzz's variable speed grinder is much better than ros and can be done lower cost.
- BarraMan
I built my boat with 2 x A$100 Bosch 6" random orbit sanders!
I agree with Fuzz that if you really want to remove something a 3M sanding disc on an angle grinder is the way to go, but as a WoMD needs to wielded with considerable finesse!
I laid 5m2 of glass with bubbles, two layers. In the end a diamond blade on a oscillating tool and heatgun was the easiest and cleanest by far. But for that little bit a grinder will do fine. As soon as you have a solid surface just glass over the whole lot. You do need to make a bigger radius at the chine. Other thing you can do just before taping is prime the plywood with neat epoxy. Then lay a little putty over the joint, and also any imperfections, dips hollows etc. Put the glass on that straightaway. This will not only help to fill any voids but also give the glass something to sit in at the joint. It helped me a lot when I was relaying that glass.
