Bertram 25. Help me evaluate transom now that keyholes are open
Re: Bertram 25. Help me evaluate transom now that keyholes are open
Never tried to cooking thing so I have no advice there. I do know when I cut plugs out of two different transoms it was clear one was good and one was not. If the plug looks like brand new wood you are good. If the plug is black, wet or soft it needs to come out. Down low or close to openings are the suspect spots.
Works even better the way you suggest and less migration to hull sides.ttownthomas wrote: ↑Mon Nov 16, 2020 11:36 am I like the heat idea. Why not sand off the whole inside layer of glass and if it is in moderately good condition use your heat technique to dry it out. Then epoxy over the bare wood and let it soak up the resin? Or does the fact that it is pretty buttoned up allow it to heat up in a way that an opened transom wont allow?
Make sure to not walk away!
I have one of those laser temperature guns. Ill be sure to babysit it and closely monitor the temperature. It's gonna take awhile to sand off all that glass. (wonder if I can chisel it away from the ply without too much damage.) THis way, I assume, If the plywood is in decent shape I can re-soak it in resin to stiffen it up.
Ok. after exposing some of the core I decided to replace the core with coosa. Did the engine bed while I was at it. The transom was 1.5" thick and the engine bed was 1"
transom - 1 by ttownthomas, on Flickr
transom - 1 (1) by ttownthomas, on Flickr
transom - 1 (2) by ttownthomas, on Flickr
transom - 1 (3) by ttownthomas, on Flickr
transom - 1 (4) by ttownthomas, on Flickr
transom - 1 (5) by ttownthomas, on Flickr
transom - 1 (6) by ttownthomas, on Flickr
transom - 1 (7) by ttownthomas, on Flickr
transom - 1 (8) by ttownthomas, on Flickr
transom - 1 (9) by ttownthomas, on Flickr
transom - 1 (10) by ttownthomas, on Flickr
transom - 1 (11) by ttownthomas, on Flickr
transom - 1 (12) by ttownthomas, on Flickr
transom - 1 (13) by ttownthomas, on Flickr
transom - 1 (14) by ttownthomas, on Flickr
Glass plans? Things look good.
Yes, glass is next-ish. I got tired of sitting in the bilge and moved onto the topsides. Must have filled 200 holes already on the front deck, the top of the forward area in front of the helm and the top of the gunnels. The patching is nearly complete, and Im re-constructing all the original side panels that were made of malamine
Now, how do the engines mount? I see no engine mount/stringer.
They are inline 6's So fairly long. The aft end of the engine mounts on 2 pegs that are part of the inner transom plate and forward they have adjustable stands that screw down to the engine bed that is the flat part on the forward end of the bilge.
Interesting there is no aft mount. Carry on!
